KNX ETS configuration: Multiple monostable switches toggling one actuator state
Marceli_Szpak 3612 2
  • #1 15808950
    Marceli_Szpak
    I welcome esteemed, more experienced colleagues and ask for guidance. For you guys this is probably trivial.
    I am in the process of redoing the electrics in my house and I would like to automate certain functions of the house. Let's assume that:
    1. I have some bell buttons connected to a knx binary input module. The inputs are set toggle, each press changes the state to the opposite state
    2. I have an on/off knx switching actuator to which a light circuit is connected
    How do I configure this in ets so that the binary inputs know what the current state of the output is? That is, so that no matter which button I use the state of the output changes to the opposite?
    Thank you in advance for your suggestions
  • #2 15816827
  • #3 15933878
    lobuz997
    Erbit wrote:
    Marceli_Szpak wrote:
    .... That is, so that whichever button I use, the output state changes to the opposite? ...
    Did I understand correctly ? One light circuit controlled by several bell buttons ? If yes then connect all bell buttons under one input in the knx.
    Sensors in KNX are different from connecting several buttons to one input mate.
    You put all the outputs from the sensors into one group with the actor's output, to this you set the R and W flags and it works :)
