Home automation with QNAP TS-251+-8G server and OpenRemote - is it possible?
horba89 3783 14
Can I use a QNAP TS-251+-8G server with OpenRemote or a similar system to build a wired home-automation setup for a detached house?
Yes—your QNAP can host a home-automation hub such as openHAB, but the safer approach is to let alarms, heating and other critical systems work autonomously and use the hub only for supervision and control [#15848801] [#15855149] [#15855754] openHAB was reported running on QNAP, and one user also recommended iobroker as an alternative platform to review for features and limitations [#15848801] [#15852694] A practical integration example given was openHAB connected to a Satel alarm (status reading plus arming), a boiler via Modbus, about 20 1Wire temperature sensors, mysensors devices, LED dimmers, AV equipment via IP/IR, roller shutters, and IP cameras via Zoneminder [#15855754] For the gate and garage door, posters suggested using dedicated controllers and simply short-circuiting the input, with status from limit switches; for cameras, a DVR or IP cameras is more useful than the cameras alone [#15848891] [#15855827] Several replies stressed that you should plan independent circuits and keep emergency/manual bypasses so the house still works if the automation server fails [#15855149] [#15856042]
  • #1 15848713
    horba89
    I am planning to build a detached house and am therefore considering automating it. When looking for useful information on the subject, I have not found specific answers to some questions. I still have some time, but I would like to start planning calmly already.
    Let me start by saying that I am in the process of buying a QNAP TS-251+-8G us server for my media centre. Is there any possibility of using/relying on it for home automation? There is something like OpenRemote, but I don't know if this is the right solution. Obviously I would like the solution to be as much as possible based on wired connections.
    I envisage automation in such a way that there is a touch panel on the wall with which I can control and read out information. I would also like to be able to access the same functions from other devices both on and off the local network. Access from mobile devices should require the device to be added to trusted or similar security.
    The panel on the wall should:
    -show the temperature from one maximum of two sensors in the house
    -show the temperature as it is on the cooker (Is it even possible to connect/control the cooker? The cooker will be a pellet / eco-pea cooker with a feeder)
    -show the temperature outside
    -interact with the video intercom
    -control the gate, garage door
    -view one or two cameras from outside
    -etc
    In addition, a couple of sensors for smoke, flooding, open doors, etc. Ideally, the solution should be flexible and relatively programmable so that I can adjust it to my requirements during implementation, e.g. when opening the garage door the light inside the garage will switch on if a certain condition is met, etc.
    I would very much appreciate your help in finding the devices, protocols and general method of implementing the main ideas.
  • #2 15848801
    Stefan_2000
    Help: 36
    Rate: 39
    You should be able to safely put openHAB on QNAP - read up on it, it might be the solution for you.
  • #3 15848820
    sosarek
    Help: 9320
    Rate: 15527
    If you write yourself software to integrate different sensors and systems then why not....
    Z
    Pka, Poznań, 60-850
  • #4 15848883
    Stefan_2000
    Help: 36
    Rate: 39
    openHAB - Features
    Some things are supported. But I'm betting that actually quite a lot of stuff would have to be carved out yourself.
    :arrow: sosarek
    Are you able to suggest any other solution of this type? Open source or inexpensive?
  • #5 15848891
    sosarek
    Help: 9320
    Rate: 15527
    I'm guessing you're going to insure the house - then a real alarm system. You can connect different types of sensors to it, ethernet module....
    As far as the image from cameras is concerned - you can use a DVR (or IP cameras) to display the image on the alarm system keypad (in addition to the network preview).
    Read about Integra 64, for example.
    Another interesting solution is Fibaro.
    And finally, there is still Ardunio.
    Z
    Pka, Poznań, 60-850
  • #6 15852694
    pawel3110
    Rate: 25
    No need to write everything yourself;)
    Nice overview of home automation systems: https://www.mysensors.org/controller/
    I personally recommend iobroker. However, it is worth reviewing what system what capabilities / shortcomings it has.
  • #7 15854493
  • #8 15854667
    Zbigniew 400
    Help: 283
    Rate: 794
    A reminder to persistently secure the main circuits with the possibility of emergency control bypassing the system.
  • #9 15855149
  • #10 15855754
    enceladuse
    As already written here - certain systems should be able to operate autonomously and be integrated with home automation, e.g:
    - Alarm - for the reasons written about (insurance) and its importance - it is a great source of data for automation by the way.
    - CH/CWU - such systems have their own logic (even simple thermostats) and should operate autonomously - home automation should at most change the settings and nothing more.
    At home, I run OpenHab, which I integrate with:
    - alarm (Satel) - parameter reading + arming, however disarming is only possible from Satel itself + gate control
    - boiler (via MODBUS) - change of parameters such as set temperature, operation mode
    - with 1Wire sensors - about 20 sensors on the bus - room temperatures + additional measurements on the CH/CWU installation
    - with mysensors - measurements where I couldn't reach after 1wire + current measurement at the entrance to the building
    - lED light control - own dimmers with Homie library
    - control of audio/video devices in the living room - integration via IP + infrared transmitter also controlled via IP
    - roller shutter controller - I am testing a bleBox - if it works I will install another one
    - iP cameras - (zoneminder) - OpenHab is only used to display the current image
    In the plans:
    - radiator thermostats - I don't know what kind and what integration
    Basic assumption when building - if OH stops working, it should be possible to function in the house.
  • #11 15855827
    wowka
    Help: 49
    Rate: 247
    A DVR would be useful for the cameras - cameras alone are pointless.
    For a gate it's a dedicated controller - you can control it by short-circuiting the input and get the open/close status from the limit switch.
    The control can be done e.g. with RM85 or bistable relays - then all you need is a control cable to e.g. light switches.
    Automated heating - if you have a small house, there's no point, you adjust the radiators once and don't have to change them for the whole winter, or you can regulate the temperature with, for example, a four-way valve. If you have a coal-fired cooker, you still need to check it at least once a day, so you can adjust the temperature on occasion.
    The last thing which almost nobody remembers is the fire safety of the boiler room.
    Type "sprinkler" into Olx and install two or more, as it costs next to nothing, and I've seen a lot of houses burn down because of boiler rooms, which is why I'm reminding you of this.
  • #12 15855979
    Zbigniew 400
    Help: 283
    Rate: 794
    enceladuse , are you able to manually switch on the lights , directly in the power circuits, bypassing the controls/?
  • #13 15856042
    enceladuse
    Yes. Because I was basing it on the existing installation I did it the simplest way possible - for the time being at the expense of functionality. I didn't rework the existing installation, the controller is plugged in behind a normal wall switch, which cuts off power to it.
    The dimmer/transmitter goes high when starting and if it doesn't connect to the control system then the light is on - it can only be turned off with the power switch - we are not dependent on the control system. This has some disadvantages - when the system is running I cannot turn the light on from this switch.
    For this reason, I am now testing a solution with short reboot detection and relay/dimmer status stored on Flash (I use ESP). That is - if I quickly switch off/on the power to the module then the controller state will change to the opposite state at the same time informing the control panel. If there is no control panel available - everything works normally. Only the switch on the wall will have to be changed to a monostable.
    I am still thinking about this. If the system does not pass my wife's acceptance tests - I will switch to z-wave.
    Added after 1 [hour] 37 [minutes]:
    And one more general remark - if you don't have a technical jam, don't load yourself up with proprietary home automation games - buy a ready-made solution. You'll spend more money, there won't be as much satisfaction, but your family won't curse you :)
  • #14 15856544
  • #15 15870273
    palacz997
    I suggest you read https://plcstore.pl/ and phone or skype. I have appliances from them and they helped me design the installation.
