How to Read POST Data and URL Parameters on ESP8266 Using Arduino IDE and ESP8266WebServer
marcin1301993 3483 2
  • #1 15983801
    marcin1301993
    Rate: 14
    Hello, please help me to add POST support.
    When I programmed ESP in NODEMC in LUA there was no problem, I checked the payload content and looked for what I was interested in.
    Here it is no longer so rosy.
    I currently use ESP to control relays using GET, but sending text from a WEB page to a server that sits on ESP requires reading it (the text) from a URL, unfortunately I don't know how to read it in the program.
    How to read the POST in the Arduino I don't know either, can you help me?
    Here is the code:
    Code: C / C++
    [/code]
    suser222
    Help: 74
    Rate: 84
    I solved the POST handling like this:
    Code: C / C++
  • #3 15984583
    marcin1301993
    Rate: 14
    Fellow Suser, this is exactly what I needed. It's even simpler than in LUA because you can send several values at once without fiddling around. Thanks a lot again.
    I'm starting to like Arduino more and more, no need to reinvent the wheel :)
    I'll leave the topic open for a while if anyone has any questions, but I think user code suser222 explains everything.
