ESP8266 - problem comparing strings in commands from phone
BuildEver 2754 13
Why does comparing a command string received from my phone with another string in my ESP8266 code not work, even though the received command prints correctly on Serial?
Your comparison fails because the received command likely contains hidden line-ending characters such as `\r` and `\n`, so `
  • #1 16000167
    BuildEver
    Hello forum,
    i have this problem :
    I download a command from my phone under the form of a string, when I want to compare this command to some other string nothing happens :/
    The best thing is that the recived: command displays on the serial. That is, the command received is correct. The comparison if(command == "cos") doesn't work anymore. Does anyone have any suggestions for a solution?
    Full code here at the very bottom.
    Piece of code:
    Code: C / C++
  • #2 16000237
    krisRaba
    Help: 94
    Rate: 434
    Eeee, hmm... because that's not how you compare strings ;) That's how you can compare numbers, single characters (it works for you e.g. checking the last character in the "c" variable) etc. For strings you should use for example strcmp
    https://pl.wikibooks.org/wiki/C/strcmp
  • #3 16000263
    BuildEver
    Thanks, I didn't know about that. Although I've been comparing like that forever and it usually works :/
  • #4 16000299
  • #5 16001434
    krisRaba
    Help: 94
    Rate: 434
    And you see, I got distracted because in the header of the code frame is "Code: c" ;) Somehow that obscured the syntax visible further down :D
    I also thought that the strings were not properly terminated by incorrectly adding consecutive characters (no null), but it looks ok though.... hmm.
  • #6 16002098
    BuildEver
    I know, it's a bit hard. I'm agonising over it a lot, I can't find the error for anything :/
  • #7 16002752
    nolens_volens
    Help: 10
    And don't you happen to have one string as "Info" and the other as "info"?
    Just a thought...
  • #8 16002781
    BuildEver
    No, all commands are always in lower case. I even angered the newline character '\n' and it didn't do anything either :/
  • #9 16003072
    oskar777
    Help: 76
    Rate: 243
    Maybe start with a single character, then you will know if the comparison works at all.
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
    ppc
    Help: 28
    Rate: 120
    You have special characters in the string(\nmaybe also \r) and that's probably why it doesn't work. Try this:
    Code: C / C++
    krisRaba
    Help: 94
    Rate: 434
    And you don't happen to be using a terminal that terminates lines by /r/n? Then when you compare "info" and the received "info/r" (and followed by the /n you are checking), you have different strings.... Add yourself a character counter to verify this, or use a terminal like TeraTerm for example, which displays CR and LF characters....
    Edit: I bookmarked myself and in the meantime fellow ppc added his post, so I'm late :-) I gave a helpful post, because according to me this is the solution :-)
  • #12 16003393
    BuildEver
    Indeed, the culprit was the sign \r (what does this sign mean?). Now everything works, thank you very much.
    ppc
    Help: 28
    Rate: 120
    \carriage return(Carriage Return, CR)
    \new line (Line Feed, LF)
    Depending on the operating system, terminal program, etc., the end of a line is encoded differently. This also applies to text files. You can read more about this here:
    https://pl.wikipedia.org/wiki/Koniec_linii
    https://pl.wikipedia.org/wiki/CRLF
    You can find a list of control characters in the C and C++ languages here:
    https://en.wikipedia.org/wiki/Escape_sequences_in_C
  • #14 16177053
    BuildEver
    Thank you for all your answers.
