[Solved] ESP8266 ADS1015 LUA module.
piterek-23 2361 8
  • #1 16043931
    piterek-23
    Help: 162
    Rate: 427
    Hey,
    Just a quick question...
    How do I read the ADS1015 module in ESP8266 (i2c connection) in LUA?
    I would be most happy to accept a ready-made :)
  • #2 16044057
    inot
    Help: 441
    Rate: 803
    If you searched, you'd find .
    Link
  • #3 16044071
    piterek-23
    Help: 162
    Rate: 427
    inot wrote:
    If you searched, you would find .
    Link
    Believe I did a lot of searching....
    The example you provided a link to is in C, and I need it in LUA.
    inot
    Help: 441
    Rate: 803
    Here, it is all about examples that use I2C type libraries.
    There is also an I2C library in LUA , so I don't see a big problem to adapt this program accordingly.
  • #5 16044194
    piterek-23
    Help: 162
    Rate: 427
    inot wrote:
    so I don't see much of a problem adjusting this program accordingly.
    If I knew how to do this I wouldn't be asking stupid questions on the forum.
    Anyway, thanks for trying to help ;)
    inot
    Help: 441
    Rate: 803
    As far as I can tell, nicht has yet created an ADS1x15 module in LUA ("nodemcu" open project).
    piotr411
    Help: 43
    Rate: 45
    inot wrote:
    As far as I can tell, in LUA (the open source "nodemcu" project) nicht yet created the ADS1x15 module.
    Lua is not Arduino !!!
    Lua has much richer references it allows free programming, which you won't find in Arduino - the environment for testing modules.
    Lua has a similar syntax to Pascal, Basic, so just find an example for these languages, and you will be able to port it to LUA without problems
    Another thing, the example posted for Arduino is plagiarism, an available version written in Proton 24!!!
    http://www.protonbasic.co.uk/vbdownloads.php?do=download&downloadid=61
    Have fun :)
    inot
    Help: 441
    Rate: 803
    just find an example for these languages and you will be able to port this to LUA without problems
    This is also what I wrote at the beginning.
  • #9 17253393
    piterek-23
    Help: 162
    Rate: 427
    Electrode has asked to close the topic so I am closing ;)
