ESP8266-01: The module does not respond to AT commands when connected to 3.3V
wachcio 3567 12
Why does my ESP8266-01 flash successfully but not respond to AT commands or run NodeMCU firmware after it was briefly connected to 5V?
Your ESP-01 is probably damaged, most likely its flash memory, after the accidental 5V connection; the chip can still talk to the flashing tool, but AT firmware and NodeMCU won’t run correctly if the flash is bad [#16069139] Make sure the module is wired for normal boot with CH-PD, GPIO0, RESET, and VCC connected properly, and do not leave RESET tied to GND [#16066738] To rule out a firmware issue, try uploading a known simple sketch such as WiFiScan from the Arduino IDE with ESP8266 support installed [#16068455]
  • #1 16065250
    wachcio
    Help: 61
    Rate: 73
    I bought a black ESP8266-01 module from the Chinese some time ago and I wanted to use it to collect information wirelessly from the DS temperature sensor. I connected the pins according to the schematic, but since I didn't have a meter at hand I mistakenly chose the wrong goldpin on the USB-RS232 adapter and got 5V for a while. I thought that I had sent him to "the land of the eternal hunt" at the start. I connected correctly to 3.3V and to my surprise the module allows firmware upload (blue LED blinks merrily). The upload is successful but although I have tried various firmware versions it is mostly ESP silent on RS232 or the blue LED blinks like crazy and rubbish (on all standard speeds) or errors are sent. These are the ones I have managed to capture:
    ets Jan 8 2013,rst cause:2, boot mode:( 3,6)
    load 0x40100000, len 25576, room 16
    tail 8
    chksum 0x6b
    load 0x3ffe8000, len 2196, room 0
    tail 4
    chksum 0x3d
    load 0x3ffe8894, len 8, room 4
    tail 4
    chksum 0x1e
    csum 0x1e
    rf_cal[0] !=0x05,is 0xFF
    epc1=0x40240558, epc2=0x000000, epc3=0x000000, excvaddr=0x000000, depc=0x000000
    Fatal exception (0):
    epc1=0x40210c00, epc2=0x00000000, epc3=0x000000, excvaddr=0x000000, depc=0x000000
    No AT commands work.
    Am I doing something wrong, or did I just break it?
  • #2 16065267
    piotrva
    Help: 625
    Rate: 735
    does it communicate with the flashing tool?
  • #3 16065952
    wachcio
    Help: 61
    Rate: 73
    It communicates with the flashing tool. Even with several tools. I upload different firmware and the program does not report errors but unfortunately ESP does not respond to AT commands and does not communicate with ESPlorer for NodeMcu firmware
  • #4 16066738
    piotr411
    Help: 43
    Rate: 45
    Show how you have the module connected.
    CH-PD, GPIO0, RESET, VCC should be together.
  • #5 16067249
    wachcio
    Help: 61
    Rate: 73
    I had RESET to GND. After connecting it under VCC on the 74880 speed I get:
    tail 8
    chksum 0x6b
    tail 4
    chksum 0x3d
    tail 4
    chksum 0x1e
    csum 0x1e
  • #6 16067474
    marek2k
    Here Link is described probably the same problem and a solution given. Might be worth checking out...
  • #7 16068202
    wachcio
    Help: 61
    Rate: 73
    After installing the firmware from this page I get a very similar error on the same frequency:
    load 0x40100000, len 31900, room 16
    tail 12
    chksum 0x49
    ho 0 tail 12 room 4
    load 0x3ffe8000, len 3064, room 12
    tail 12
    chksum 0x74
    ho 0 tail 12 room 4
    load 0x3ffe8bf8, len 8, room 12
    tail 8
    chksum 0x12
    csum 0x12
    R
  • #8 16068296
    marek2k
    And have you tried programming this module under Arduino? You could then rule out whether it's a problem with the NodeMcu firmware itself.
  • #9 16068396
    wachcio
    Help: 61
    Rate: 73
    Physically connect to the Arduino and only program or just use the Arduino IDE?
  • #10 16068455
    marek2k
    Use an Arduino IDE with ESP8266 support installed. Connect the ESP module via a USB-RS232 adapter and program it like a regular Arduino.
    You can try uploading a ready-made program, e.g. WiFiScan, and see if it throws something up on the console.
  • #11 16068981
    wachcio
    Help: 61
    Rate: 73
    The esp programming does not reach the end. I hear the familiar USB disconnect sound in the speakers. I think I have something faulty though....
  • #12 16069139
    marek2k
    Maybe the FLASH memory has been damaged.
    I also once inadvertently misplaced a jumper in the programmer and connected the ESP-01 to 5V. The memory burnt out and the ESP8266 chip is still working today ;)
  • #13 16069258
    wachcio
    Help: 61
    Rate: 73
    Perhaps it could be replaced....
