NodeMCU Access Point: Auto Redirect to login.html on Client Connection
karolpila 2103 10
How can I make a NodeMCU access point automatically open login.html when a client connects and launches a browser?
No, connecting to the NodeMCU AP by itself will not automatically open login.html; the browser must first make an HTTP request, so the user has to enter an address or have the browser homepage set to the device IP [#16109740][#16110436] If you want a portal-style redirect, serve a page from the web server and send a redirect/refresh header such as `Refresh: 1; Url=http://192.168.1.50/index.htm`, which makes the browser load the chosen page after the initial request [#16110415] You can also make `index.html` the default page, but that still requires browsing to the AP’s address first [#16102001][#16103379] A full captive-portal/login flow would need server-side handling of login state and redirection, likely with a normal web server or proxy; the ESP alone is unlikely to manage that complexity [#16110432]
  • #1 16101871
    karolpila
    I have set up my NodeMCU as an Acces Point. I have uploaded a page to it called login.html.
    I would like it to automatically open the login.html page when I access this AP and open my browser.
    Can you please suggest how to do this ?
    Thank you in advance :-)
  • #2 16102001
    el2010tmp
    Help: 97
    Rate: 43
    Isn't it enough to call the page index.html by any chance?
  • #3 16103379
    karolpila
    Well, unfortunately inserting index.html doesn't help.
    When entering the browser you first have to enter the IP address of the site.
    here is a similar problem described but when working with a router :
    https://www.elektroda.pl/rtvforum/topic1792481.html
  • #4 16103484
  • #5 16105121
    karolpila
    Hmmm..... I switched from Ardunio to Node and did not write in LUA.
    do you have any ready to use tools that I could adopt ? :-)
  • #6 16105220
  • #7 16109740
    krzbor
    Help: 41
    Rate: 1067
    I don't think that's possible. You have to enter an address in your browser. You can, of course, enter that address as the browser's home page address, but I don't know if that's what you mean. Connecting to the AP does not start communication over TCP. Even if you try to do it from the AP side, the browser will reject it (although the firewall will probably block it beforehand). Generally - the page request has to come from the browser.
  • #8 16110036
    karolpila
    Well that's exactly the problem.
    I read somewhere about router redirection..... something like that in airports, pubs, McDonald's.....
    You log on to the free network, open GOOGLE and there is the login page.
    ...... This is what I mean.
  • #9 16110415
  • #10 16110432
  • #11 16110436
    krzbor
    Help: 41
    Rate: 1067
    You have it well described in the thread you quoted. It involves the user initiating the connection (accessing some page).
