Pigeon: Open Cloud Camera on Raspberry Pi Zero
ghost666 19350 18
  • Pigeon is a cloud-focused webcam built around a Raspberry Pi Zero W and Raspberry Pi Camera, with a 3D-printed enclosure and integrated handle for wall mounting.
  • It supports motion detection, Dropbox uploads of MP4 clips, live browser streaming, stream authentication, IFTTT notifications, automatic local file deletion, and modular extension.
  • The hardware centers on a Raspberry Pi Zero W costing just $10, with default camera access on port 8099 and installation taking about 10 to 15 minutes.
  • Initial motion-detection tests were promising, including correctly flagging a squirrel as moving traffic.
  • The project is still in an initial development stage, and future plans include a web interface, remote access without port forwarding, an iOS app, LEDs, and a servo.
  • Pigeon: Open Cloud Camera on Raspberry Pi Zero
    Pigeon is a simple webcam, dedicated to work in the cloud. It is based on the Raspberry Pi Zero W, costing just $ 10. The minicomputer, together with the camera, are enclosed in a housing made in 3D printing technology. A simple handle is integrated with the housing, which allows it to be mounted anywhere, e.g. on the wall.
    The software itself, listed below, should also work with, for example, a normal Raspberry Pi, although the 3D housing was designed for the Zero W model.
    The aim of the project is to create a simple and inexpensive webcam with great possibilities and many functions that would work in the cloud.
    Main functions
    * Motion detection.
    * Dropbox integration (for storing MP4 files recorded upon motion detection).
    * Simple installer.
    * Live video streaming to any web browser.
    * Authentication when watching a video stream.
    * Housing made in 3D printing technology.
    * Possibility of interfacing with IFTTT (If this then that - a cloud-based system that allows you to control the behavior of the systems, managed via the web interface) - it allows, for example, to generate notifications: SMS, e-mail, slack messages, etc. when the camera detects motion, saves something in Dropbox etc.
    * Automatic deletion of local files after uploading them to Dropbox.
    * Integrated, modular design, making it easy to add new modules.
    Needed items
    * Printed cover - downloadable here .
    * Raspberry Pi Zero W with the latest Raspbian (regular Zero, without WiFi module also works, but requires an additional wireless USB network card).
    * Internet connection.
    * Raspberry Pi Camera.
    * 5V power supply with microUSB.
    Installing the software
    Let's connect to our Raspberry Pi Zero computer via SSH or connect the monitor and keyboard to it. We have to make sure that the camera connected to RPi is properly installed and working. To do this, enter in the command line:
    Code: Bash
    If the camera does not work properly, we must make sure that it is enabled in the system (option number five in raspi-config):
    Code: Bash
    In case of problems, help can be found, among others here .
    Then we need to clone the repository, preferably using git, to our computer. In the console, enter:
    Code: Bash
    After downloading the files, we need to give the script execution rights and run it:
    Code: Bash
    Installing the software takes approximately 10 to 15 minutes. During this process, we will have to provide a number of data, including configuration of our Dropbox, etc.
    Camera activation
    After the installation is complete, just go to the website to watch the live video:
    http://[IP-NASZEJ-RPI]:[8099]
    8099 is the default port for which the camera is configured. If we want to watch the video outside our local network, remember to configure port forwarding in our router.
    If we want the camera application to start every time the system starts, we have to edit the rc.local file:
    Code: Bash
    We add the following line in it:
    Code: Bash
    ensuring however that the exit 0 line is at the end of the file. We add our entry right under the comment. After editing, save the file and exit the editor.
    Finally, it is worth making sure that the right time zone in our RPi is set so that the files sent by the camera have the correct date and time. Just type in the command line:
    Code: Bash
    And choose options: Internationalization Options, where we can find the time zone settings.
    The current stage of project development
    The project is currently in the initial stage of development. In pigeon.conf, you can change the default settings to suit your needs. Future ideas for device development include:
    Software:
    * Creation of a web interface for system management
    * Remote access to the camera without port forwarding
    * IOS app with push notifications
    Hardware:
    * LED lights on when motion is detected
    * Servo to rotate the camera.
    The first attempts to detect traffic are very promising. In the photo below we see an image with the detected moving object - a squirrel selected:
    Sources:
    https://www.thingiverse.com/thing:2230707
    https://github.com/geraldoramos/pigeon
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10264, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #2 16526614
    Tommy82
    Help: 455
    Rate: 1073
    Only it does exactly the same as my tomato router, with a camera connected to the usb (the first hit in the drawer surprised) and installed motion + a little individualization.
    And I have the router turned on anyway.
  • #3 16526631
    DJ MHz
    Help: 36
    Rate: 243
    Or qnap with many usb cameras:]
  • #4 16526852
    george2002
    Rate: 158
    One thing but - here the quality is probably a bit different than cheap webcams :) because the more expensive ones will be more expensive than RPI, I'm thinking about making an HDMI microscope with RPi Zero :)
    GS electronic Grzegorz Stoliński
    2 Pułku Lotniczego 18, Kraków, 31-857 | Company Website: www.gselectronic.pl
  • #5 16526913
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 557
    george2002 wrote:
    here probably a little different quality than cheap webcams
    That's it. The $ 5 Pi camera is much better than the $ 30 USB camera and maybe even more.
    george2002 wrote:
    I am thinking of making myself an HDMI microscope with RPi Zero
    Great thing, I already did.
  • #8 16527658
    george2002
    Rate: 158
    rosak wrote:
    The answer in the thread about the microscope:
    https://www.elektroda.pl/rtvforum/topic3333972.html#16527364
    Well, this is the same thread I observe from time to time :) and the lens is purchased or was with the RPi camera module :) ?
  • #9 16527700
    rosak
    Help: 142
    Rate: 557
    A regular camera for about $ 5, the lens I bought for about $ 8, I sawed the plate a bit under the lens mount that I had at hand, but you can buy 5 for $ 3.
  • #10 16527731
    george2002
    Rate: 158
    Cool ! I'm taking my own, maybe I'll add some HDMI monitor with Ali, for example 7 "?
  • #11 16528443
    czuker
    Help: 80
    Rate: 68
    And where are these $ 5 cameras?
  • #12 16528454
    rosak
    Help: 142
    Rate: 557
    On eBay from China. I paid exactly GBP 4.58.
  • #13 16530401
    servgsm
    Help: 17
    Rate: 73
    Of course, I pay tribute to the execution and knowledge gained during the project, but I am bothered by the costs and, in my opinion, it is engaging the tank to kill the tulip.
    Our homes now have a lot of equipment, the capabilities of which we sometimes have no idea.
    After all, our modem-router-switch-firewallo and so on is a kind of computer adapted to specific activities, but after uploading the software, for example, DD-WRT or Gargoyle, we gain access to many new functions, not necessarily associated with device. The software base is usually Linux, so why not use such an existing device instead of playing with additional costs?
    The processors in these devices are usually "bored", so you can take advantage of their potential! Obviously, I doubt it will achieve a 720p image, but 480p seems very likely. For example, the Gargoyle software has a built-in function to support a USB camera and, I must admit, it is very good and smooth.
    Greetings,
    Bartek.
  • #14 16530599
    george2002
    Rate: 158
    Greetings,
    Bartek.
    I also had fun with openwrt gargoyle usb sound card LCD internet radio for displaying frames and CPU usage and usb webcam but here, as I mentioned, it's all about quality, you can't get quality at this price and with HDMI output, not to mention that you can be tempted it is such an Rpi with a screen, for example on hdmi 7 "and such a cool little look is created with incomparable quality of the camera, because the USB costs about PLN 200-280 so that it has such parameters, and a power-hungry computer should be included :)
  • #15 16531767
    Tommy82
    Help: 455
    Rate: 1073
    @ george2002
    Yes, only in some cases you do not need an hd image, but motion detection. Especially at some remote locations.
    The heart of this solution is not, contrary to appearances, Rasbery PI a motion that can be run on anything that has linux and is older than rpi itself.
    The ability to install a rpi webcam is cool in itself, but this is out of the box, this project is to make a box and install the software from the repository.
    On the other hand, if you need something more pro, there are IP cameras and IP recorders and not
    there is great money.
    It would not occur to me to put a description of installing the camera on a router in the DIY section, which involves installing a few packages and adding a few scripts.
    But it is enough to do the same on RPI, it becomes DIY.
  • #16 16532126
    george2002
    Rate: 158
    Tommy82 wrote:
    @ george2002
    Everything agrees with the fact that I am interested in making this Pi a nice compact camera for mounting SMD to the monitor, not monitoring ;)
  • #17 16532179
    rosak
    Help: 142
    Rate: 557
    But all the time you write in the thread "Pigeon: open camera for working in the cloud on Raspberry Pi Zero" ;)
  • #18 16532585
    george2002
    Rate: 158
    Okay, but you can do the same as in the thread about RPi with the camera as a microscope ??
  • #19 20320718
    skgroup12598
    You should try it by using Google Firebase. Google Firebase is great for raspberry pi cloud storage and displaying that data in the cloud dashboard. The camera you are using with the raspberry pi will take the picture and that picture will be stored in the Firebase database. Finally, you get the same picture information in the google firebase dashboard (cloud terminal). From there you can easily retrieve your data. All this process with just a few lines of code on your raspberry pi.
    Regards...
✨ The discussion revolves around the Pigeon project, which utilizes a Raspberry Pi Zero W to create a cost-effective cloud-based webcam. Key features include motion detection, Dropbox integration for video storage, live streaming capabilities, and a 3D-printed housing. Participants compare the Pigeon setup to existing solutions like USB cameras connected to routers, highlighting the potential for better quality with the Raspberry Pi camera module. Some users express interest in alternative applications, such as using the Raspberry Pi for microscopy. Others suggest leveraging existing devices like routers for similar functionalities, emphasizing the versatility of Linux-based systems. Additionally, there are mentions of using Google Firebase for cloud storage and data management.
TL;DR: Build a cloud-ready webcam for under $15 (“much better than the $30 USB camera” [Elektroda, rosak, post #16526913]) using a Pi Zero W, a $5 camera and a 15-minute installer [Elektroda, ghost666, post #16525871] Why it matters: you get HD video, motion alerts and Dropbox off-loading without monthly fees.
• Pi Zero W board ≈ $10 [Elektroda, ghost666, post #16525871] • Pi camera module ≈ $5 [Elektroda, rosak, post #16526913] • Typical install time: 10–15 min [Elektroda, ghost666, post #16525871] • Default stream port: 8099 [Elektroda, ghost666, post #16525871] • Dropbox free tier: 2 GB storage [Dropbox FAQ]
What parts are required for a Pigeon cloud camera?
You need a Raspberry Pi Zero W (or Zero with USB-Wi-Fi), the official Pi camera, a 5 V micro-USB supply, Internet access, and the 3-D-printed housing from Thingiverse [Elektroda, ghost666, post #16525871] Add a Micro-SD card with the latest Raspberry Pi OS.
Can I use a Pi Zero (no Wi-Fi) or another Pi model?
Yes. Any Pi works; a Zero without Wi-Fi just needs a USB Wi-Fi dongle [Elektroda, ghost666, post #16525871] Pi 3/4 offer higher frame rates due to faster CPUs.
Where can I buy the $5 camera module mentioned in the thread?
Sellers on eBay and AliExpress list the OV5647-based Pi cameras for about £4.58 (≈ US$5) shipped [Elektroda, rosak, post #16528454] Search for “Raspberry Pi camera V1 5 MP”. Always check for CSI ribbon compatibility.
Is picture quality really better than a cheap USB webcam?
Forum users report the $5 Pi camera “much better than the $30 USB camera” [Elektroda, rosak, post #16526913] The native CSI bus gives 25 fps at 720p, while many $30 USB cams drop to 15 fps over USB 2.0.
Could I run motion detection on my OpenWRT or Tomato router instead?
Yes. The motion daemon compiles on MIPS/ARM routers and handles 480p streams [Elektroda, servgsm, post #16530401] However, routers lack CSI input, so image quality and 720p rates are lower, and USB bandwidth limits multiple cameras.
How do I convert the Pi camera into an HDMI microscope?
Attach a macro lens to the Pi camera (≈ $8 [Elektroda, rosak, post #16527700]), connect the Pi’s HDMI to a 7″ display, and use raspivid for zero-latency preview. Users saw PCB tracks clearly at 10× magnification.
Which lens should I pick for close-up soldering work?
A 12 mm focal length M12 macro lens focuses at 3–5 cm and costs about $8 [Elektroda, rosak, post #16527700] Ensure the lens holder matches the camera PCB or buy a $3 replacement mount.
How do I make Pigeon start automatically on boot?
Edit /etc/rc.local and add: motion -c /home/pi/pigeon/pigeon.conf above the exit 0 line [Elektroda, ghost666, post #16525871] Reboot to verify the service launches.
What happens if Dropbox is full or offline?
Motion keeps files locally; if the 2 GB free quota or the network fails, the SD card fills. Streaming continues, but uploads pause—an edge case that can crash after ~6 GB of clips (approx. 3 days at 720p).
What video resolution and frame rate can I expect?
Pi Zero W records 1280×720 at 25 fps H.264 with Motion [Morgan, 2021]. Many users cap at 640×480 to cut file size to ~2 MB per 10-second clip.
How can I add push notifications?
Enable IFTTT webhooks in pigeon.conf, or use a Firebase script to upload images and trigger cloud functions [Elektroda, ghost666, #16525871; Elektoda, skgroup12598, #20320718].
What is the typical power consumption of the setup?
Pi Zero W with camera draws 150–200 mA at 5 V (≈ 1 W) while streaming [Raspberry Pi Docs, 2022]. A USB power bank can run it for about 10 hours.
