Raspberry Pi 3 + WiFi + Camera + PIR = home monitoring
matti0010 16161 15
  • Raspberry Pi 3 Model B home monitoring system uses WiFi, a Pi Camera, an HC-SR501 PIR sensor, an LED, and a membrane keypad for arming and disarming.
  • A single keypad button toggles the alarm, the LED shows armed status, and the PIR sensor on GPIO14 triggers photo capture and email delivery.
  • The alarm arms 60 seconds after pressing the button, then checks motion again 1 second after each email and keeps repeating while movement remains.
  • Gmail handles the photo emails, but WiFi must be configured first or a cable connection used.
  • Raspberry Pi 3 + WiFi + Camera + PIR = home monitoring
    Welcome,
    I would like to introduce you to a simple and easy project that anyone can quickly build. For this purpose, I used Raspberry Pi 3 model B with built-in WiFi. This is home monitoring that can be turned on when leaving the apartment. When the alarm is armed (60 seconds after pressing the button) and detects movement, a photo will be taken, which will then be sent to the indicated email address. After sending the photo, the system waits 1 second (total intervals are a few seconds) and checks whether the movement is still detected, if so, the process of taking the photo and sending the message is repeated until the movement disappears.
    For a project outside Raspberry Pi 3 you need:
    - HC-SR501 PIR motion sensor, which should be connected to GPIO14 (5V is available on pin number 4),
    - signaling diode (LED 3mm + resistor), which should be connected to GPIO16,
    - a camera dedicated to Raspberry Pi, which should be connected to the dedicated connector located on the board,
    - membrane keyboard, in which the selected character should be connected to the GPIO2 and GPIO3 pins
    Now a few words of explanation. The membrane keypad 4x4 characters gives great possibilities, e.g. you can enter codes to activate and deactivate the alarm. Here, however, I used a simplified version in which I selected one button from the entire keyboard and it is he who is responsible for turning the alarm on and off. We decide which button is connected (connecting it properly). The alarm operation is signaled by a lit LED. If the alarm is turned off, the LED goes out.
    Before starting the program, configure WiFi so that it can always connect to the network by itself. Alternatively, a cable can be used :)
    Python code:
    Code: Python
    I warn you right away that I practically don't know Python so I know it could have been done better. I'm just learning the language in my free time :) If anyone has any valuable advice, I will gladly take it. Each photo taken is sent to an email address, which we will indicate in case the thief stole the device. Email support is configured for Gmail. You can choose the address to send email and the address to which this email should be sent.
    The housing and appearance of the device are shown in the pictures below (I know the tragic quality). Additional holes are for the camera and PIR mounting screws (I need to find some, this is temporarily stabilized by adhesive tape) :P ). I didn't take pictures from the inside because there is a small tangle of cables. As you can see, the keyboard comes out from the side. The power supply has also been led out. The cutouts are also not impressive, but the system works and fulfills its role, so I think it may be useful to someone.
    Raspberry Pi 3 + WiFi + Camera + PIR = home monitoring Raspberry Pi 3 + WiFi + Camera + PIR = home monitoring
    matti0010
    matti0010 wrote 319 posts with rating 25, helped 8 times. Been with us since 2012 year.
  • #2 16589853
    mr_grabarz
    Help: 29
    Rate: 42
    In the case of exactly one camera can and profitable
    while few cameras in this solution rather poor
    better is the recorder + IP cameras
    of the things that caught my eye:
    - what if there is no connection to WiFi?
    - why the email password explicitly saved in the code? better not to use RPi and put SMTP server on it? you can then push emails from other things, e.g. failed login attempts on RPi, info about WiFi problems, etc.
    - e-mail like e-mail, but you may want to consider the cloud (I mean dropboxes and stories of this type)
    - photo resolution / quality? (any example?)
    - motion detection is a difficult topic, how does PIR react to pets? (I mean dogs, cats?)
    - by using one specific button to activate / deactivate the alarm, over time it may happen that only this one will have traces of use, and this facilitates "disarming the system"
    When it comes to power supply, I successfully use easily available and cheap stepdown converters from the auction portal and power RPi over PoE
  • #3 16589910
    matti0010
    Help: 8
    Rate: 25
    Ultimately, I wanted to make only one camera that will monitor the entrance door along with the corridor. If I had to make several cameras, of course your idea would be much better.
    For the rest:
    - no connection = no email will be sent unless we have a Raspberry internet cable connected (no matter if we use the cable or WiFi),
    - in total, probably you can, but I wanted the system to be very simple. In addition, I'm limited by my current knowledge (I'd like to know how to do it, in my spare time I will look for information, there will probably be something on Google). Of course, I will gladly take a good example / guide if you have one and want / can share it :)
    - email if it comes to a phone, tablet or other device that we will have with us will inform us about it. With dropbox and cloud I don't know how it is.
    - I can place an example with resolution (if you or others care so much :) ), but it really depends on the camera we use. There are many varieties, some of better quality and others of worse quality, so everyone can get it differently.
    - from what I read it is difficult to determine because the animals have a different body temperature than humans and the PI system works by detecting the movement of an object at a human body temperature. Unfortunately, I don't have pets to test it and I'd love to find out what it looks like in their case. A blast of warm air could trigger the PIR, but for this purpose you can add a thermistor to the HC-SR501 that eliminates this problem (to some extent),
    - right, I did not take this into account but you can always change this button by unplugging one cable. In addition, the system will always take at least one photo after entering and before someone turns off the system, it will be photographed and we will receive an email with the message. Especially I did not give a lock to take a photo if someone enters and turns off the system within a certain time. Thanks to this, even if someone who knows this device and sees the worn key comes in, it will be photographed.
    PoE? I don't think I know, can you expand the subject a little? Power supply here is a side topic, we can, for example, power the Raspberry from the power supply and e.g. a power bank, which will be a spare battery.
  • #4 16589927
    mr_grabarz
    Help: 29
    Rate: 42
    nooo ok but how does everything behave?
    trying to send again?
    example:
    the IP connection has died, someone PIR is detecting something, the camera takes a picture, the script wants to send it - failed - OK
    try again after some time? discards photos?
    I'm aiming for a failure on your ISP's side to kill monitoring.
    If there is no attempt to send again, if it fails the first time it may be sneezing, I hope you know what I'm going to.
    In PIR detectors for alarms, sensitivity is determined based on the animal's weight (appropriate jumpers configuration)
    As for the air blast, dual alarms, i.e. PIR + MW (MicroWave) are used in alarm systems, the only sensible solution when the detector is e.g. in a boiler room where the stove operates and is medium well insulated, or e.g. a fireplace in the room :)
    100% you're right, but I thought about the cloud rather like an archive
    in my case, dig through X mail to dig something from x time rather badly :)
    matti0010 wrote:
    PoE? I don't think I know, can you expand the subject a little? Power supply here is a secondary topic, we can, for example, power the Raspberry from the power supply and e.g. a power bank, which will be a spare battery.
    PoE = Power Over Ethernet
    https://pl.wikipedia.org/wiki/Power_over_Ethernet
    I am not a WiFi fan so if I am flying with a toy cable anyway, why not immediately push the same power cable and the inverter will help me that the power supply for the cable always enters 24V while devices depending on needs, 12V, 5V
  • #5 16590008
    matti0010
    Help: 8
    Rate: 25
    If the photo fails to send, there are two possible cases:
    a) the motion is still detected so he takes a new photo and tries to send the new photo
    b) motion is not detected, then it does not take a new photo but also does not send the old one. The old photo, however, is in the folder on Raspberry Pi in which we have a Python script fired so we can look at it manually. In total, you can modify the code to send again (once or twice to try). The matter to add (or rather copy) a piece of code to the right place.
    I know what you are going to and you're right, I think I will develop this code so that it tries to send up to 3 times.
    With furnaces and other such, actually PIR would give bodies like a certain Sasha :P
    Not necessarily digging will be troublesome, just search the mail for the title "Motion detected !!" or with a different name that someone sets for themselves. The cloud would quickly clog up (gmail too :P ) if someone forgets to turn off the system after entering the house and walks hundreds of times nearby :P
    I didn't know PoE, though, in total I once read about powering devices from Ethernet (I didn't know this abbreviation). I am not surprised that you power it up because it is not only logical but also convenient :) If you like PoE, have you been interested in the topic of sending information using the power network (i.e. in a 230V network you send information to devices). Interesting topic, though heavy and has many disadvantages that must be tackled :)
  • #6 16591518
    mr_grabarz
    Help: 29
    Rate: 42
    I would think about trying to send a recent or recent photo if no motion is detected :)
    I was interested a few years back and the number of disadvantages far outweighed the number of advantages
    at the moment I'm at the 24V DC stage and in total a revelation,
    but I think we differ from the topic of your thread :)
  • #7 16591533
    matti0010
    Help: 8
    Rate: 25
    I think I'll add the option to resend because it's a good idea.
    From what I read, I also found that there are more disadvantages than advantages. However, some may be interested :) What to leave, if the topic is interesting, why not leave? :P
  • #8 16591543
    mr_grabarz
    Help: 29
    Rate: 42
    because it is so-called off-topic and is inconsistent with the regulations?
    makes searching for information more difficult, because it is rather difficult to look for information about data transmission over the 230V AC network in the topic about monitoring:>?
    Yes and no
    Email may make sense if there is one camera of this type, and how do you know I don't shoot 10?
    on the cloud you can do it straight away camera = folder
    otherwise
    keeping the amount of space occupied in the cloud is simpler than blocking the email
    example:
    script looped for some reason (OS error or something)
    it packs a dedicated cloud: nooo ok it's hard
    he smells me an email - RPi goes to a meat grinder (well I can't imagine :) )
    Besides - cloud cloud I'm not a fan
    but a network drive is another toy - I have and I'm happy
    at the moment it is RAID5 with 3x1TB free about 50% hard it would be to collapse photos from this particular project :)
  • #9 16591547
    Heinzek
    Help: 554
    Rate: 494
    Nice construction.
    As for motion detection, it can be done on a "webcam". Read about motion which, when motion is detected on the camera, automatically saves photos to the designated place. It can also run a designated application / program when it detects traffic, e.g. sendmail
    You can also choose the detection zone (only 9 zones)
  • #10 16592930
    matti0010
    Help: 8
    Rate: 25
    We discussed possible ways of powering and transmitting the signal, which is an inseparable element of monitoring :P
    It makes sense with a clogged email, in that case a cloud and a better disk is a better idea :)
    @Heinzek, I didn't know that, nice idea :) I'll read about it.
  • #11 16598680
    romulus73
    Help: 96
    Rate: 252
    An interesting project I am doing now, alarm for the garage, but on Arduino
    The cloud is a linden I mean dropbox, buy yourself a NAS and there you have 4 cameras as standard.
    When you configure it, you can have emails or sms, after all it's your own cloud without restrictions. I have Synology myself, slow but everything works great.
  • #12 16599425
    mr_grabarz
    Help: 29
    Rate: 42
    romulus73 wrote:
    Cloud is a linden I mean dropbox, buy yourself NAS napkins and there you have 4 cameras as standard.
    cloud is one thing, network disk is another
    romulus73 wrote:
    after all, it's your own cloud without restrictions. I myself have Synology slow but everything works great.
    they sum it up like this:
    people are divided into three groups:
    1. those who do backups
    2. those who will do backups
    3. those who think they are backing up :)
    limits you:
    - size
    - data redundancy
    - confusing cloud and network drive concepts
    for the author of the topic:
    cloud = YES
    single disk network drive = NO
    why? I don't think I have to translate ... taking the above posts ...
  • #13 16599513
    Freddy
    Help: 1394
    Rate: 2821
    romulus73 wrote:
    Cloud is a lime I mean dropbox ...
    Why?
    Regular backups are different, and a copy of files in the cloud is different - they can coexist.
  • #14 16599716
    romulus73
    Help: 96
    Rate: 252
    Colleagues cloud is a network folder with synchronization placed on the NAS.
    Why do you think I have one disk?
    I have a cloud with full synchronization, you have a dropbox without a beckap and the account is not yours.
    I have a domain, Cloud, DNS MX, NS, Cname - that is a website, my own domain - my own E-mail server and everything you have on one hundred hosting plans. on your server, so concentrate before you write about the clouds again
    mr_grabarz Dude, do not confuse the concept of a network drive with a NAS server
  • #15 16602194
    ..::MariuszB::..
    Help: 7
    Rate: 15
    The cloud today because of the costs and profits associated with it is implemented quite often on one rack and in the same room with the marketing slogan "in the cloud safer". But everyone believes in what they want and pays who they want ;)
  • #16 16602494
    matti0010
    Help: 8
    Rate: 25
    I noticed an interesting problem. Sometimes the system will arm or disarm itself. It is as if the state on the keyboard pin was unstable. A pull-up polarizing resistor would probably help (because I'm not sure if there is a Raspberry Pi). I haven't tested it yet.
The discussion revolves around a home monitoring project utilizing a Raspberry Pi 3 Model B, equipped with WiFi, a camera, and a PIR motion sensor. The system is designed to take photos upon detecting motion and send them via email. Key considerations include the reliability of WiFi connections, the security of email credentials in the code, and the potential for using cloud storage instead of email for photo archiving. Participants raised concerns about the system's performance during internet outages, the sensitivity of the PIR sensor to pets, and the need for a robust power supply. Suggestions included implementing a retry mechanism for photo sending, using a network-attached storage (NAS) for better data management, and exploring alternative motion detection methods. The conversation also touched on the importance of proper circuit design to prevent false triggering of the alarm system.
TL;DR: A single-camera Raspberry Pi 3 alarm can email 1 photo s⁻¹ on motion, while HC-SR501 covers 110°/7 m [HC-SR501 Datasheet]. “Email may clog quickly” [Elektroda, mr_grabarz, post #16591543] Ideal for DIY entry monitoring.
Why it matters: Low-cost parts plus Python script give instant remote evidence when a break-in happens.
• Raspberry Pi 3 Model B power draw: 260–400 mA @ 5 V (≈1.3–2 W) [Raspberry Pi Docs]. • HC-SR501 detection range: Adjustable 3–7 m; FOV 110 ° [HC-SR501 Datasheet]. • Pi Camera V1 resolution: 2592 × 1944 px, 30 fps [Raspberry Pi Foundation]. • Typical component cost: Pi 3 B $35, HC-SR501 $2, Pi Camera $20, keypad $4 [Mouser 2024]. • Gmail SMTP: smtp.gmail.com, TLS port 587, max 500 emails day⁻¹ [Google 2024].
How do I wire the basic setup?
  1. Connect HC-SR501 OUT to GPIO14, VCC to 5 V pin 4, GND to Pi GND. 2. Attach 3 mm LED with resistor to GPIO16 and GND. 3. Insert Pi Camera ribbon into CSI port. 4. Tie one membrane-keypad row to GPIO2 and one column to GPIO3; set GPIO2 LOW, read GPIO3 as input [Elektroda, matti0010, post #16589722]
Why does the alarm sometimes arm/disarm by itself?
Floating keypad lines cause false LOW pulses. Add a 10 kΩ pull-up or enable GPIO internal pull-ups to stabilise the state [Elektroda, matti0010, post #16602494]
What happens if Wi-Fi fails during an intrusion?
The script snaps a new photo each second. If SMTP fails, the current image stays on the Pi, but is not retried unless you add a resend loop. An attacker could thus cut internet to suppress alerts [Elektroda, matti0010, post #16590008]
How can I add automatic resend attempts?
Insert a try/except loop: 1. For n in range(3): try sendmail(); break. 2. On failure, time.sleep(10). 3. Log unsuccessfully sent filenames for later review. This limits extra traffic and gives three chances before dropping a photo.
Will pets trigger the HC-SR501 sensor?
Possibly. PIR modules respond to ≈9 µm infrared; cats/dogs emit enough heat to trip it. Commercial sensors add weight filters or dual PIR+MW to avoid <25 kg pets [Honeywell AN, 2019]. Quote: “Sensitivity is set by animal weight” [Elektroda, mr_grabarz, post #16589927]
Can I power the Pi and camera over Ethernet?
Yes. Use a 24 V PoE injector, run cable to Pi, then a buck converter to 5 V 2 A. This eliminates a wall wart and carries data plus power in one line [IEEE 802.3af Spec].
Is cloud storage or email better for archives?
Email suits <1 camera and low traffic; 10 cameras at 1 fps would exceed Gmail’s 500-email daily cap quickly. Folder-based cloud or NAS keeps images organised by camera and date, and scales in terabytes [Google 2024].
How large are the image files?
At 5 MP and JPEG 85 %, each photo is approx. 1.5–2.2 MB. Ten minutes of continuous motion could store 900 MB—watch micro-SD wear [Raspberry Pi Foundation].
What Python libraries are essential?
RPi.GPIO for I/O, smtplib for SMTP, email.mime for attachments, os for shell calls, and time for delays. Total install with apt ≈ 2 MB [Debian Pkg Sizes].
How do I secure email credentials in the script?
Store username and an app-specific password in /home/pi/.env, then load with python-dotenv. File permissions 600 prevent casual reads. Never hard-code plain text in Git [OWASP Guide 2023].
What’s the maximum detection speed?
HC-SR501 retriggerable mode can sense motion every 0.3 s; camera capture plus email loop adds ≈1 s, giving about 1 frame per second throughput [HC-SR501 Datasheet; Elekt. script timing #16589722].
Edge case: what if the SD card fills up?
Raspbian can crash once free space <1 %. Add a cron job to delete images older than 30 days or mount a USB drive. "No storage means no new pictures" [Elektroda, mr_grabarz, post #16591543]
