Nodemcu v3 with CH340 - espcomm_sync, espcomm_open, espcomm_upload_mem errors
EDbwkOUOyUIOwOziQA9t 1857 3
  • #1 16689701
    Hello, I have purchased a Nodemcu v3 chip with CH340. When trying to upload the program via arduino ide 3 messages pop up:
    warning: espcomm_sync failed
    error: espcomm_open failed
    error: espcomm_upload_mem failed
    When I open ESPlorer nothing happens either, it doesn't connect to the chip, in windows device manager it is seen "usb to serial". And hence my question - has anyone had this problem before and knows how to solve it.
  • #2 16689820
    rafcio_21
    Help: 137
    Rate: 299
    You need to upload the correct drivers and in the ide do you install a new set of tiles? Sometimes I couldn't get the program into the node, but pulling it out for a while and inserting the USB cable again helped and the program loaded normally.
  • Missing bits/cxxabi_tweaks.h in ESP8266 toolchain
    #3 16689858
    I have added in the tile idea, and the drivers are supposedly good, but I have windows 8.1 so maybe its the fault. On win xp I tried it and the message popped up:
    Arduino:1.8.4 (Windows XP), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (3M SPIFFS)".
    In file included from C:Documents and Settings Local settings Application dataArduino15packagesesp8266hardware.cpp:23:0:
    c:docs and settings local settings applicationdataArduino15packagesesp8266-hardwareesp8266-elf-gcc1.20.0-26-gb404fb9-2-xtensa-lx106-elf-include++4.8.2cxxabi.h:50:32: fatal error: bits/cxxabi_tweaks.h: No such file or directory
    #include <bits/cxxabi_tweaks.h>
    compilation terminated.
    exit status 1
    Compilation error for NodeMCU 1.0 board (ESP-12E Module).
    This report should contain more information if in
    File -> Preferences the option "Show
    detailed information during compilation"
  • #4 16689869
    rafcio_21
    Help: 137
    Rate: 299
    Sometimes I had such a message with a compilation error for nodemcu and missing installed libraries .
