Swimming pool roller shutter control with rotation counter - I am looking for ready-made solutions
technikabasenowa 2904 9
Are there any ready-made roller-shutter drives or controllers with an encoder/rotation counter for a swimming pool roller blind?
Yes—there are ready-made roller-shutter drives with electronic end positions based on an encoder, and 24V versions also exist for roof and truck roller shutters; Somfy is mentioned as one manufacturer that offers them [#16690796] [#16690831] These drives typically run for only 3–5 minutes continuously, then shut off thermally at about 140–160°C and restart after cooling to 70–80°C, with speeds around 14–17 rpm [#16690796] If the built-in encoder is just a simple pulser, a programmable pulse counter and some logic can be enough, with a reset to a machine zero to avoid accumulated error [#16690934] Another suggested alternative was a pinhole disc with a slotted optocoupler if you need your own encoder sensing [#16690749]
  • #1 16690393
    technikabasenowa
    Help: 138
    Rate: 445
    As in the subject
    Most of these devices have mechanical limiters - I am looking for something with a rotation counter - encoder - are there any ready-made ones?
    I need it for swimming pool roller-blinds - the working principle is to roll up the scroll like in window roller-blinds only different length.
  • #2 16690569
    Zbigniew 400
    Help: 283
    Rate: 794
    How about reed switches?
  • #3 16690691
    technikabasenowa
    Help: 138
    Rate: 445
    No mounting - must be an encoder - maybe some roller shutter gate controllers?
  • #4 16690749
    Zbigniew 400
    Help: 283
    Rate: 794
    Then use a pinhole disc and a slotted optocoupler.
    Electronic shutter drives have thermal duty-cycle limits
    #5 16690796
    Marek J.
    Help: 526
    Rate: 951
    When it comes to end positions, there are two types of motors (or in fact drives) for roller shutters.
    One has mechanical end positions (usually within 20-40 turns) and the other has electronic end positions (on an encoder) usually linked to an obstacle detection sensor. I think the latter have a much greater range of adjustment (Elero/Nice, Somfy, Mobilus, Yooda, etc). However, you need to bear in mind that these drives have a maximum continuous operation of 3-5 minutes. Once they reach 140-160 degrees they will switch off and only switch on once they have cooled down to 70-80 degrees, and their speed is 14-17 revolutions per minute.
  • Built-in encoder enables cheaper 24 VDC control
    #6 16690809
    technikabasenowa
    Help: 138
    Rate: 445
    So I'm getting the hang of it
    I have a roller shutter motor built into the pipe there is already an encoder built in, I mean the controller-counter executive system itself I will convert in the pool roller shutters are 24VDC motors.
    I am looking for something reasonably priced, the original controller alone without motor and encoder is a few hundred euros - the charms of things for the pool :cry:
    24 V roller shutter drives as a possible source
    #7 16690831
    Marek J.
    Help: 526
    Rate: 951
    Simply a niche that manufacturers and distributors are exploiting....
    Roof roller shutter drives also come in 24V versions. The same is true for roller shutters on trucks.
    Certainly Somfy has them in its range. Whether others do too - I'm not sure, but it's likely. You will have to make some phone calls, send some e-mail enquiries and you will probably find something.
    Zbigniew 400
    Help: 283
    Rate: 794
    What kind of built-in encoder is this?
    If it is a simple pulser, an adjustable pulse counter /about PLN100/ and some logic would suffice.
    I would introduce a reset, so-called machine zero, to eliminate
    error summing.
  • #9 16691888
    technikabasenowa
    Help: 138
    Rate: 445
    Can you write something more - because I'm not very good with digital cameras
    I think there's a simple pulser there.
  • #10 16692815
    Zbigniew 400
    Help: 283
    Rate: 794
    You programme the number of pulses and the drive switches off.
    If the counter is reversible, the drive runs from 0 to the set value. This is best because it is simpler logic.
The discussion focuses on finding ready-made control solutions for swimming pool roller shutters that use rotation counters or encoders instead of mechanical limiters. Typical roller shutter drives either have mechanical end stops or electronic end positions controlled by encoders, often combined with obstacle detection sensors. Encoder-based drives offer greater adjustment range but have operational limits such as maximum continuous run time and thermal cutoffs. Common 24VDC motors with built-in encoders are used, but original controllers are expensive. Suggested solutions include using pinhole discs with slotted optocouplers or simple pulse counters with reset functionality to track rotation accurately. Brands like Somfy, Elero, Nice, Mobilus, and Yooda offer electronic encoder-based roller shutter drives, including 24V versions suitable for niche applications like pool roller blinds. Custom logic or adjustable pulse counters (~£100) can be employed to interface with simple encoder pulses for cost-effective control.
