GSM SIM800L modules from Allegro - antenna line quality and project application
Atlantis86 3561 16
Can a SIM800L GSM module with a poorly routed antenna trace be used reliably in an SMS/GPRS project, or will it cause problems?
Yes, the SIM800L can work well despite the board’s rough antenna layout, but it is very sensitive to the power supply and antenna setup [#16808826][#16810305] One user reported that with a proper PCB antenna the module worked very well, while a contact-board build failed because the contacts had too much resistance and the module draws a lot of current [#16810305] Another noted that with no external antenna or a badly oriented wire antenna, the module can report an “OVERVOLTAGE PROTECT” state and temporarily switch off, then retry registration later [#16808947] The peak current can reach about 2 A for 0.5 ms, and the supply voltage should not drop by more than 300 mV, so the PCB power path and decoupling matter more than the apparent antenna-trace imperfections [#16810456] The thread also notes that the SIM800 can obtain time from the GSM network, so NTP may not be necessary for time sync [#16809846]
  • #1 16808792
    Atlantis86
    Level 19  
    Help: 7
    Rate: 23
    Cheap SIM800L GSM module boards have been available on Allegro for a while now. Usually mounted on a red laminate, they are characterised by their small size and, as far as I can see, are quite popular among Arduino users. Or at least this is indicated by the not inconsiderable number of tutorials on the Web. Image attached.
    GSM SIM800L modules from Allegro - antenna line quality and project application .
    I am currently working on the design of a certain device that will need GSM connectivity. Mainly receiving SMS and occasionally GRPS - the latter for, among other things, time synchronisation with NTP. Using such a module would simplify my board design quite a bit.
    However, after looking at the pictures, the first doubts arose. Namely, the antenna line does not look like it was designed according to the rules of art. The path winds next to another solder field, and the adjacent ground fields are in quite close proximity and are not connected to the general ground on the other side of the board. It does not resemble, for example, a microstrip line in any way....
    Does the module work properly and perform well despite this? I ask because I have come across one piece of information about GSM transmission interfering with its own UART communication. At the same time, from what I can see the modules are quite popular.
    Someone may have dealt with them and can share an opinion?
  • #2 16808826
    czareqpl
    Help: 196
    Rate: 580
    And searching for topics on the electrode tried?
    There are several topics where people have used these modules (including me).
    They perform quite well. You just have to take care of a good power supply.
  • #3 16808922
    czasnagli
    Help: 19
    Rate: 105
    The sim800l works fine, but for about $4 on aliexpress you can buy a sim800c. See how many useful pins are brought out in the sim800c. It also has bluetooth.
  • #4 16808947
  • #5 16809117
    simw
    Help: 94
    Rate: 288
    niveasoft wrote:
    This diagnostic message from the SIM comes with a 100% good 4.0V supply so I submit this for your consideration.
    It is worthwhile in your software to listen to what the module is writing.
    From what I've read in the literature, a very common cause of problems with gsm modules is bad PCB and power supply design, as the thread author also wrote about. The module takes relatively a lot of current in the operating mode and therefore, in a nutshell, it is easy to "generate pins on the power supply". So much for the literature. I haven't run these modules myself yet, so I can't confirm this.
    Colleague niveasoft seems to be suggesting that the modules themselves are tref, since he writes about "100% good 4.0V power supply", at least that's how I perceive it myself, but I could be wrong.
    Please elaborate on this thought. The PCB for this module is a handmade one or is it some kind of "spider"? Was the power supply checked on an oscilloscope?
    I am very curious...
  • #6 16809211
    czareqpl
    Help: 196
    Rate: 580
    I'll add a piece of my solution:
    Diagram excerpt:
    A coil in the ground and power supply cuts off buzzing during data/audio connections. In this way I have ensured silent operation for the audio path.
    PCB fragment:
    Greetings and best wishes for success.
  • #7 16809846
  • #8 16810066
    czareqpl
    Help: 196
    Rate: 580
    R-MIK wrote:
    This is probably not the best idea.
    Not the best but effective.
  • #9 16810095
  • #10 16810178
  • #11 16810270
    czareqpl
    Help: 196
    Rate: 580
    R-MIK wrote:
    And maybe the problem is in the PCB (ground) design
    Some advice on how to route the ground plane would be useful in that case:
    In blue I have marked the position of the SIM800L module.
    In red I have marked the connection point of the coil to ground.
    In yellow colour I have marked the paths with the audio signal, which is sensitive to hum from the GSM module.
    In the upper left is the audio section.
    Any advice from a colleague?
  • #12 16810305
    krzbor
    Help: 42
    Rate: 1072
    I have this module, it works very well. However, I bought it with a PCB antenna plugged into the socket. What surprised me was the audio working well - I thought with that much power in the antenna the unshielded cables to the microphone and speaker would be a problem. Just one piece of advice - I did tests on a contact board and it wouldn't work - it turned out that the contacts on this board have too much resistance (the Chinese made them out of steel, I think). This circuit really draws a lot of current. If anyone is having trouble with the stability of this circuit, start by checking the power supply (its efficiency).
  • #13 16810456
    simw
    Help: 94
    Rate: 288
    The maximum current for such modules can be up to 2A in about 0.5ms. The power supply must be designed so that the supply voltage does not drop by more than 300mV - data for the SIM800f module (if I remember the model correctly). It turns out that the problem may be the thermopads themselves at the pins, and other thin paths on which, at 2A, too much voltage drop may occur - by the way, a similar effect is observed with poor quality usb cables supplying power to mobiles or even RPIs.
    With errors in the above, even connecting to high-efficiency sources such as batteries or laboratory power supplies will have no positive effect.
  • #14 16817437
    Atlantis86
    Level 19  
    Help: 7
    Rate: 23
    Among other reasons, this is why I do not use thermal pads on my boards.
    And of course I intend to put at least two suitably large tantalum capacitors at the module power pin.
    BTW I have read that it is condemned to put small filter capacitors on the RX and TX lines of the module. Is it advisable to use similar filtering also on the second UART interface (debug)? What about the other communication interfaces (SPI, USB, etc.)?
  • #15 16817490
  • #16 16818048
    Szaflik
    Help: 15
    Rate: 332
    Has at least the "minimum" filter on the audio lines recommended by the manufacturer been implemented on the PCB ? (Figure 30 of the hardware design: "Speaker reference circuit") ? In the picture of the PCB it looks as if the audio paths are coming directly out of the module.
  • #17 18479046
    neo_84
    Rate: 97
    As long as you don't need an audio track, everything looks fairly easy. Unfortunately I managed to make one board on which the microphone worked really well . Recently I received new boards (different shape pcb) ready beautiful non-thermal transfer but unfortunately failure :( the problem is probably with the antenna as some colleague wrote does not radiate power. If I cut my hand between the antenna and sima covers as if the plate interference disappears and the current decreases
The discussion focuses on the use of cheap SIM800L GSM modules from Allegro, popular among Arduino users for GSM connectivity including SMS reception and occasional GPRS for NTP time synchronization. Concerns were raised about the antenna line design on these modules, noting non-ideal PCB layout with winding antenna traces near solder fields and isolated ground areas not connected to the main ground plane, potentially affecting RF performance. Several contributors emphasized the critical importance of a stable, low-noise power supply capable of delivering peak currents up to 2A in short bursts to avoid voltage drops and module resets. The SIM800L module can self-manage network login and power states but is sensitive to antenna quality and power supply integrity. Alternative modules like the SIM800C, which offers more pins and Bluetooth, were suggested. Proper PCB design practices were discussed, including grounding strategies, filtering on audio lines, and avoiding capacitors on UART and SPI lines to prevent data transmission errors. The use of coils in ground lines was debated, with caution advised due to potential ground potential differences. Practical advice included using large tantalum capacitors near power pins, ensuring minimal resistance in power contacts, and following manufacturer recommendations for audio filtering circuits. Some users reported issues with antenna radiation and interference, which could be mitigated by physical adjustments. Overall, the thread highlights the challenges of integrating low-cost GSM modules into custom boards, stressing careful attention to antenna layout, power supply design, and signal integrity for reliable operation.
TL;DR: Allegro red-board SIM800L "works fine" and SIM800C costs about $4, exposing more useful pins and Bluetooth. [Elektroda, czasnagli, post #16808922] Why it matters: This FAQ helps Arduino- and embedded-makers avoid RF, power, and audio pitfalls when adding GSM to projects.
Do SIM800L modules from Allegro work reliably despite the odd antenna trace?
Yes, users report good results when the power supply is solid. “They perform quite well. You just have to take care of a good power supply.” Prioritize a low-impedance 4 V rail, short leads, and adequate bulk plus high-frequency decoupling. Many problems blamed on RF layout are actually supply sags during TX bursts. Start with power integrity, then assess antenna placement and ground. [Elektroda, czareqpl, post #16808826]
What current and voltage headroom do I need for SIM800L power?
Design for ≈2 A peak pulses lasting about 0.5 ms. Keep the module’s supply droop under 300 mV during those bursts. Use wide copper pours, avoid thin thermals to the power pins, and place low-ESR bulk caps beside VBAT. Even good bench supplies fail if PCB resistance causes transient drops. [Elektroda, simw, post #16810456]
Why does my module show “OVERVOLTAGE PROTECT” and switch off?
That message can appear with a 100% good 4.0 V source if the antenna is missing or poorly oriented. Unradiated RF energy can trigger protection and the module may go OFF for around 10 seconds, then retry network attach automatically. Ensure a matched antenna and clear placement. [Elektroda, 373522, post #16808947]
Can SIM800 set the clock without using NTP over GPRS?
Yes. The SIM800 can synchronize its time directly from the GSM network. This avoids GPRS traffic and simplifies code. Use the module’s AT commands to query and update time after registration, then only fall back to NTP if the network time is unavailable. [Elektroda, 22053, post #16809846]
Should I add small capacitors on UART RX/TX to fight RF noise?
No. Don’t mask layout issues with UART capacitors. They can corrupt high-speed transfers and large data blocks. Fix grounding, decoupling, and routing instead. “Capacitors on SPI? Do you want to slow down the communication?” applies similarly to UART; avoid adding RC on data lines. [Elektroda, 22053, post #16817490]
How do I stop GSM buzz in the audio path?
Implement the manufacturer’s minimum audio filtering network close to the module, as in the “Speaker reference circuit.” Keep audio traces short, use a clean analog ground region, and separate them from the RF/power areas. Skipping the recommended filter leaves the path vulnerable to TDMA bursts. [Elektroda, Szaflik, post #16818048]
Is placing a coil (inductor) in the ground return a good idea?
No. Ground should remain at one potential. An inductor can separate grounds and create unintended voltage differences under burst currents. Improve ground planes, star returns, and supply filtering instead. Reserve isolation only for deliberate galvanic isolation strategies. [Elektroda, 22053, post #16810095]
What layout mistakes most often break SIM800 power integrity?
Thin traces, thermally relieved pads on power pins, and long loops to bulk capacitors cause transient drops. At 2 A bursts, tiny resistances matter and can undermine even high-capacity supplies. Use solid pours, direct pad connections, and caps at the module pins. [Elektroda, simw, post #16810456]
Why won’t my SIM800L work on a solderless breadboard?
Contact resistance on some breadboards is high, causing voltage loss during TX pulses. One user found the module failed on a breadboard but worked with low-resistance wiring. Power this module with short, thick leads and avoid spring-contact prototyping. [Elektroda, krzbor, post #16810305]
SIM800L vs SIM800C: which should I choose?
SIM800C brings out more useful pins and adds Bluetooth, making it more flexible. It is available around $4, which rivals the SIM800L modules. If you need extra interfaces or BT, SIM800C is attractive; otherwise SIM800L remains fine for SMS/GPRS basics. [Elektroda, czasnagli, post #16808922]
Can antenna issues increase noise and current draw?
Yes. A poorly matched or blocked antenna can raise interference and current. One report shows interference subsiding and current decreasing when a hand detuned the region between antenna and shields. Validate antenna placement, clearance, and matching before blaming firmware. [Elektroda, neo_84, post #18479046]
Do I need the debug UART and should it be filtered?
Use the debug UART only if you need module logs. Do not add capacitors to the UART lines; they can distort edges and slow communication. Prioritize clean routing and reference ground instead of RC filters on digital I/O. [Elektroda, 22053, post #16817490]
How should I interface SPI or USB to the SIM800 family?
Avoid RC loading on high-speed lines. For level shifting on SPI, use 74LVC-series translators to keep edges sharp. Do not “mix” components into USB; follow the manufacturer’s reference design and keep routing controlled-impedance where required. [Elektroda, 22053, post #16817490]
What’s a microstrip line, and does this module need one?
A microstrip is a controlled-impedance RF trace over a ground plane. While some boards show meandering antenna feeds, field reports say modules still work if power and antenna are correct. Prioritize antenna orientation and robust supply first. [Elektroda, czareqpl, post #16808826]
Quick 3-step power integrity checklist for SIM800L/SIM800C
  1. Place low-ESR bulk capacitors at VBAT; target <300 mV droop during 2 A, 0.5 ms bursts.
  2. Use wide pours and avoid thermal reliefs on power pins.
  3. Shorten ground returns and keep loops tight around the module. [Elektroda, simw, post #16810456]
Can I rely on GPRS for time sync, or should I prefer network time?
Prefer GSM network time because it is immediate and avoids GPRS overhead. Use GPRS/NTP only as backup if the cell time is unavailable or insufficient for your application’s accuracy needs. This reduces data use and simplifies firmware. [Elektroda, 22053, post #16809846]
