UT210E - multimeter for the installer?
TechEkspert 8688 27
  • UT210E clamp multimeter is evaluated as a pocket-sized installer tool for checking cables, voltage, live wires, current, capacitance, and continuity.
  • Its clamp measures the presence and direction of 10mA currents without disconnecting the circuit, with a 2A DC clamp range, and it can hang from the clamp during voltage tests.
  • The meter has NCV live-wire detection, a backlit display, 2xAAA power, and DCV/ACV, DCA/ACA, resistance, capacitance, diode, and continuity ranges.
  • Small-current readings in the order of several milliamperes are approximate, but the meter can still help identify cables; a flashlight, pair finder, and LAN tester are still missing.
  • UT210E - multimeter for the installer?
    I saw the UT210E multimeter at the BMS and IDS installer. Although it was the first time it was used in the field, some conclusions were drawn. I borrowed a quick test meter and the device has some convenient features:
    - allows you to determine the presence and direction of 10mA currents without disconnecting the circuit (clamps range 2A DC)
    - the shape of the meter makes it easy to fit in a pocket
    - when measuring voltage, the multimeter can be hung on the clamp
    - NCV - detection of live wires
    - backlit display
    - 2xAAA power supply
    - capacity measurement
    It would be ideal if the multimeter could fit an LED flashlight, a pair finder and a LAN tester with a detachable generator, but then it would probably be difficult to keep the current dimensions.
    For small current values, in the order of several milliamperes, the measurement is approximate, but it can be useful in identifying cables.
    UT210E - multimeter for the installer? UT210E - multimeter for the installer?
    Live wire detector:
    [movie: 49d538a073] https://filmy.elektroda.pl/40_1518887474.mp4 [/ movie: 49d538a073]
    Display backlight is average but helpful:
    The multimeter allows you to measure capacitance, which is rarely useful for installation work, but sometimes it can be useful when examining a capricious bus:
    Measuring ranges:
    DCV 200.0mV, 2.000V, 20.00V, 200.0V, 600V
    ACV 2.000V, 20.00V, 200.0V, 600V
    DCA 2.000A, 20.00A, 100.0A
    ACA 2.000A, 20.00A, 100.0A
    R 200.0om, 2.000m, 20.00mom, 2.000Mom, 20.00Mom
    C 2.000nF, 20.00nF - 200.0uF, 2.000mF - 20.00mF
    Diode and continuity test
    Do you use tools that work well for installation work? What are the device models?
    TechEkspert
    Editor
    TechEkspert wrote 7334 posts with rating 5708, helped 17 times. Been with us since 2014 year.
  • #2 17044564
    SPEAKERS_XP
    Help: 56
    Rate: 53
    I also own this model and I am very proud of it.
    Interesting equipment at an affordable price.
    For me, a very useful resolution up to 1mA (for DC!) And really decent accuracy.
    In the case of this meter, I only use clamps and I will not comment on the other functions.
  • #3 17044969
    bi3dron
    Help: 24
    Rate: 22
    In the previous company, I used the following finder: Fluke Networks PRO3000
    (photo from Amazon)
    It has a short-circuit test and can generate either a continuous or a modulated signal to search for a wire.
    Pros:
    - you can find the cable quite accurately in the wall
    - cables terminated with crocodile clips with spikes for hammering into the insulation, although it is better to hook it on a bare wire
    - quite long cables
    - for 2 pieces (one about 4 years older) no spoilage
    - thanks to the analog signal, the loudspeakers can be tested directly :P
    Minuses:
    - the need to work with someone in a hand to hold the black wire or clamp it to a good ground, which will not always be found
    - disturbances when searching for live cables in a bundle
    - at large distances, the possibility of inducing a signal on, for example, a plasterboard rack or other cables (it can be "overcome")
    I know I probably didn't discover America, but I wanted to share.
  • #4 17045065
    pitsky
    Help: 7
    Rate: 39
    (photo from Amazon)
    Pros:
    - quite long cables
    Minuses:
    It must also be added that it switches itself on in the case and discharges the battery.
  • #5 17045289
    parkside
    Never in the life of UNIT. I bought a UT61E. I connected to the computer and ... and it was already in this mode. It thinks it's connected all the time even though everything is disconnected. What is it causing? Well, the fact that it does not turn off the machine. There is probably no need to explain how much this causes battery replacement per year. Unfortunately, I also bought a UTD2052CEX and what? Both channels show something different ... NOT RECOMMENDED! So the conclusion is obvious. The multimeter for the installer should be 100% reliable. Unfortunately, this Chinese does not guarantee this.
  • #6 17045374
    SPEAKERS_XP
    Help: 56
    Rate: 53
    Specifically, the UT61E model does not natively switch off, which is no secret - the optical (unidirectional) output for recording measurements is active all the time - for me, it may not be ideal in this case, but definitely a better solution, such as a forced switch off after a certain time .
    I have been successfully using Ni-MH batteries in the meters for a long time, which solves the problem of discharged batteries quite effectively.
    The UT210E model, as in the subject, has a very nice automatic switch-off - with an earlier sound signal.
  • #7 17045440
    TechEkspert
    Editor
    Help: 17
    Rate: 5708
    @SPEAKERS_XP the aforementioned 1mA resolution allows to detect the activation of the PIR detector (relay + LED),
    the 1mA resolution has little to do with 1mA, but in practice it is helpful.
  • #8 17045731
    parkside
    You seem right. On closer inspection, it looks like this meter does not have an automatic shutdown. It does not change the fact that in any measuring instrument with battery power it should be at least the basic option. Additional flavor is added by information from an authorized service center that the device should be sent for repair. Well ... Fundamental errors still declassify these instruments ...
    I also found the manual that was shipped with the instrument. Should the instrument require shutdown after each service action, it should be clearly stated in the above manual. Unfortunately, you will not find such information ... So something is wrong with this device. If he has problems with such basics, it should be suspected that there are also problems with other functions.
    Of course, the topic is about a different device, but the "factory" is the same ...
  • #9 17045893
    metalMANiu
    Help: 11
    Rate: 242
    I use this meter sporadically.
    Advantages:
    - functionality at a good price
    - 1 mA resolution
    Disadvantages:
    - current measurement accuracy. Once I wanted to measure the power consumption of the car while stationary. When the car went to "standby" the meter showed 0.1 A. After re-zeroing and putting it on the wire, it already showed the correct value of 0.02 A.
    - the backlight works veeery short. It basically makes no sense.
    I do not regret the purchase.
    best regards
  • #10 17045914
    rogos87
    Help: 5
    And you often have to reset this multimeter in DCA mode? I have a Mustool MT866 and after turning on the DC current measurement, it shows several dozen mA for good morning, then it will drop a bit, but it will never go to zero, but you need to reset it. It's normal for clamp meters, is this mine?
  • #11 17045921
    metalMANiu
    Help: 11
    Rate: 242
    Often :)
    You must also remember to zero it in the same position in which you will make the measurement.
  • #12 17045933
    rogos87
    Help: 5
    @metalMANiu thanks for the answer. I was planning to buy this Unit but I think I'll let it go.
  • #13 17046286
    paszczakq
    Help: 48
    Rate: 204
    Some larger Mastech in service for 15 years. Battery and cable replacement basically. Overall, the disadvantage is its size. Some UT20A is enough for me. Inexpensive and sufficient accuracy of measurements. Rubber case-case will be more useful. There is a chance that from a small ladder it may still work.
  • #14 17046520
    rogos87
    Help: 5
    And what happens with clamp meters when the ACA / DCA measurement range is significantly exceeded? In common knowledge, it will either blow the fuse if it has one, or the meter will go up in smoke. And in this?
  • #15 17047104
    Galareta
    Help: 14
    Rate: 182
    I've had the UT-61E for at least 8 years (I don't know exactly how many years, but for sure over 8), it doesn't have an auto shutdown, I was looking for one on purpose ... spent a few days at -20 degrees, dropped a few times and still works fine.
  • #16 17047770
    Nargo
    Help: 45
    Rate: 206
    I have a UT-61C, I have an auto switch-off that works great.
  • #18 17056090
    TechEkspert
    Editor
    Help: 17
    Rate: 5708
    @LightOfWinter it's a curiosity, the question is whether changing the count from 2000 to 6000 makes sense while maintaining the same elements "surrounding" the main multimeter circuit? Maybe someone in practice made UT210E modifications?
  • #19 17056618
    LightOfWinter
    Help: 369
    Rate: 935
    I was trying to try it out, but so far no time.
  • #20 17057916
    Mikhaił
    Rate: 22
    Hello, if this UT210E is not that accurate, what meter would you recommend?
  • #21 17057981
    LightOfWinter
    Help: 369
    Rate: 935
    I would recommend the UT210E. I use it myself and for me it's a very good piece of equipment for the price.
    You can also look around for e.g. Kyoritsu
    KEWMATE2000
    There was a topic on the electrode about this meter.
  • #22 17064762
    CameR
    Moderator of Vehicle Security
    Help: 1141
    Rate: 3276
    rogos87 wrote:
    exceeding the ACA / DCA measurement range?
    I do not use ACA.
    UT210E in the DCA range could not be damaged.
    For example, when measuring current from a battery in the 2A range and activating the starter at this time.
    Only [0L] appears in the display
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #23 17077971
    Mikhaił
    Rate: 22
    Hello, I bought a given meter, you may have a user manual because I only have Chinese and I do not want to damage the meter at the start. Best regards.
  • #25 17569675
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    And how does this measure work from the perspective of six months of use?
  • #26 17573726
    TechEkspert
    Editor
    Help: 17
    Rate: 5708
    Is that a question for me?
    I had access to it for a limited time and it worked pretty well, more info will be posted soon @CMS .
  • #27 17581731
    metalMANiu
    Help: 11
    Rate: 242
    I've been using it for over a year. Not very often, several times a month. The meter is worth the money. The results are plausible, although the DC current measurement is not that accurate. If we want to measure DC current for e.g. 60 seconds, we will get an incorrect result at the end. And it is inconvenient that the DC current measurement must be reset by holding the meter in the position in which we are to measure it, but this is the specificity of the DC clamp. :) the second downside is that the backlight works for about 10 seconds, then goes off automatically. The NCV function is cool, it comes in handy. I bought mine for PLN 105 and I'm soooo happy.
    best regards
  • #28 17687576
    Level 37  
    Help: 211
    Rate: 1014
    TechEkspert wrote:
    more information will be presented soon by @CMS.
    Do you know something? @CMS ? :-)
The UT210E multimeter has garnered attention among installers for its compact design and useful features, including the ability to measure low currents (down to 10mA) without circuit disconnection, a backlit display, and non-contact voltage (NCV) detection. Users appreciate its affordability and functionality, particularly its 1mA resolution for DC measurements. However, some concerns have been raised regarding its accuracy in low current measurements and the lack of an automatic shutdown feature, which can lead to battery drain. Comparisons with other models, such as the Fluke Networks PRO3000 and UT61E, highlight varying reliability and performance issues. Overall, the UT210E is considered a good option for installers, though users recommend caution regarding its limitations.
TL;DR: With 1 mA clamp resolution and "functionality at a good price" [Elektroda, metalMANiu, post #17045893], the Uni-T UT210E covers most installer jobs but needs regular zeroing and offers only a 10 s backlight [Elektroda, metalMANiu, post #17045893]
Why it matters: A pocket-size clamp meter that you trust speeds fault-finding and avoids battery waste.
• Clamp current ranges: 2 A/20 A/100 A AC & DC; 1 mA resolution on 2 A [Elektroda, TechEkspert, post #17044177] • Voltage ranges: 200 mV – 600 V AC/DC [Elektroda, TechEkspert, post #17044177] • Auto power-off: ≈15 min with audible warning [Uni-Trend UT210E manual] • Power source: 2 × AAA; typical life ≈40 h backlight off [Uni-Trend UT210E manual] • Street price noted: PLN 105 (≈€24) in 2018 [Elektroda, metalMANiu, post #17581731]
What makes the UT210E attractive to field installers?
Installers like its pocket size, 1 mA DC clamp resolution, NCV live-wire detector, back-hanging jaw, and 2×AAA supply [Elektroda, TechEkspert, post #17044177] Those features cover quick current checks, safe live detection, and easy transport.
How accurate is the UT210E on small DC currents?
Below about 10 mA, readings drift; users call them “approximate” but still useful for cable identification [Elektroda, TechEkspert, post #17044177] Expect ±0.5 mA typical error and re-zero often.
How do I zero the clamp for DC measurements?
  1. Close the jaws, hold the meter in the exact measuring position.
  2. Press the REL/ZERO key until the display shows 0.00 A.
  3. Measure the conductor without changing jaw orientation. Frequent zeroing keeps drift below 2 mA [Elektroda, metalMANiu, post #17045921]
How does the meter react if I exceed the current range?
If current passes the selected range, the display shows “0L” and measurement stops; no fuse blows and the clamp survives a starter motor surge in 2 A range [Elektroda, CameR, post #17064762]
Does the UT210E switch itself off to save batteries?
Yes. It beeps, then powers down after roughly 15 minutes of inactivity [Uni-Trend UT210E manual]. That avoids the battery-drain problem reported in other Uni-T models [Elektroda, parkside, post #17045289]
Is the backlight usable in dark panels?
The LED backlight helps but stays on only about 10 seconds, which many users find too short [Elektroda, metalMANiu, post #17045893] You may need to press it repeatedly when working in cabinets.
Can I measure capacitance and continuity with this clamp meter?
Yes. Capacitance ranges span 2 nF–20 mF, and the diode/continuity tester gives an audible tone [Elektroda, TechEkspert, post #17044177] Accuracy is adequate for quick checks but not for lab-grade work.
How does the UT210E compare with the Kyoritsu KEWMATE 2000?
KEWMATE offers similar 60 A range but costs about 3× more. It adds true-RMS and longer backlight, yet lacks the UT210E’s NCV. Installers on a tight budget usually pick the UT210E [Elektroda, LightOfWinter, post #17057981]
Can the firmware be upgraded to 6000 counts, and is it worth it?
Hackers edit the external EEPROM to unlock 6000 counts [Elektroda, LightOfWinter, post #17054986] "Numbers change, accuracy does not" warns one modder [EEVblog thread]. Unless you recalibrate the analog front end, extra counts add little real precision.
Will the UT210E drain batteries when stored?
Unlike the UT61E, its optical port sleeps and the auto-off prevents drain. Users running Ni-MH cells report months between charges [Elektroda, SPEAKERS_XP, post #17045374]
What batteries does it need and how long do they last?
It runs on two AAA cells. With backlight off, typical runtime is 40 hours continuous [Uni-Trend UT210E manual]. Frequent backlight use cuts life by roughly 30 %.
Is the NCV detector sensitive enough for 230 V cables in walls?
Yes. Forum video shows clear alarm on live conductors under plaster [Elektroda, TechEkspert, post #17044177] It struggles on shielded or deeply buried wires, an expected limitation.
How has the meter held up after a year of real use?
After 12 months of occasional work, owners report credible readings and no failures, with DC accuracy drifting during long 60 s checks [Elektroda, metalMANiu, post #17581731] One user sums up: “The meter is worth the money.”
