[Solved] Integrating F&F LE-03MP Modbus RTU Meter with Domoticz System
abaku 4113 4
  • #1 18752039
    abaku
    Rate: 10
    I am just beginning my adventure with Domoticz, and since codes, scripts, etc. are not my field I am counting on the understanding of Forum users.
    I got a recycled F&F LE-03MP meter, it is in working order, from a PC via usb - RS485 Modbus I can view and edit the configuration with the F&F LE Config program. The meter is mounted as a sub-meter. I have not been able to find information on how to read this meter via modbus to integrate it with e.g. Domoticz, basically there is only support for Eastron SDM120 and SDM630 meters. The Modbus protocol documentation for my meter is available here https://www.fif.com.pl/pl/liczniki-zuzycia-energii-elektrycznej/463-licznik-zuzycia-energii-le-03mp.html .
    Has anyone managed to integrate this meter or any of this family of F&F meters into Domoticz ?
    Could an expert in scripting from the Forum take a look at the Modbus documentation for this counter and compare it with the scripts for the SDM360 counter whether this has a chance of working (after editing e.g. transmission parameters ... of course) or is it a completely different tale ?
    By the way, has anyone come across a script that "reads" electrical meters via RS485 but not the Modbus protocol but EN 62056-21 (IEC1107) ?
    thank you in advance and best regards
  • #2 18759973
    starob
    Help: 128
    Rate: 137
    The easiest and fastest way to do this is with a plug-in:
    https://github.com/DomoticX/domoticz-modbus
    You define each parameter to be read as a separate "device".
    Register addresses with attached pdf
    • elFF WSK LE-03MP inst D160118 PL.pdf (148.2 KB) You must be logged in to download this attachment.
