Monitoring BMeters Cold Water Meter w/ RFM TX 1.1 Radio Module Using Domoticz & DIY Adapter
przeqpiciel 7014 4
  • Question about decoding BMeters RFM TX 1.1 meters
    #1 16806877
    przeqpiciel
    Help: 285
    Rate: 238
    The housing cooperative made me happy by replacing the cold water meters with those with radio reading, so they do not have to worry me when they want to read - a good idea. I was equipped with cold water meters from bmeters with a radio module similar to this . There is an inscription RFM TX 1.1 on the radio overlay, which would indicate that I would theoretically need it such an adapter for domoticz .
    In connection with the above, I have a question. Has anyone dealt with this radio overlay and a homemade way to successfully read the state of their meters? Yes, I know, the transmission is encrypted, but maybe there is a way to do that.
  • #2 16806921
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Second water meter in series ... ;)
  • #3 16806938
    przeqpiciel
    Help: 285
    Rate: 238
    Half a joke, half seriously. Would you have a command meter that would work with the domoticz in the wireless option?
    @Moderator, reply to PM
  • #4 16843492
    Sickboy
    Rate: 18
    If you like to party then rPi + camera. On this you put ffmpeg and write a script to recognize usage digits on the meter. Although if you have an overlay it probably covers the reading ...
  • #5 16849343
    also
    Rate: 77
    I would not look after the readings too much because some series have a bug :P
