[Satel Integra 64] How to program a 230V LED dimmer with a motion detector?
Lelslelon 2802 1
  • #1 17305102
    Lelslelon
    I have the following problem.
    I would like to programme a light in the hallway of my flat as follows:
    At night, at certain times, the light would be switched on via the movement detector in the hallway but to make it darker and not glaring. In addition, I would like to switch this light on at 100% brightness using a button at all times.
    I generally know how to do this, but the problem is that 230v led dimmers are signal-controlled.
    So now the question:
    How to program and whether it is possible to achieve that when the motion detector detects movement and it will be at a certain time, INT-ORS will give a signal to the dimmer and it will switch it on, but after two minutes with no movement on the detector, INT-ORS will give a short signal again and the light will switch off.
    I want to use the satellite integra 64 for the control.
  • #2 17305120
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    It can be done, but the shortest pulse the Integra can give is 1 second. I don't know how this relates to your dimmers.
    As for the run time, this can be achieved in several ways.
    1 Use a "mono switch" type output
    2 Use an output of the "end of output signalling" type.
    Set such a timer to operate at specific times as required.
    Then set up logic using outputs of the logical product and logical sum type.
