[Solved] Best Cable for 6 External Roller Blinds: 4x1.5 vs 5x1.5 Wires, Switchboard & Drivers
grippen123 84030 17
What cable should I use for up to six external roller shutters controlled from a central switchboard with drivers, 4-core or 5-core?
Use 5-core 1.5 mm² cable if you want the installation to be future-proof and flexible [#17431082] For a central-control setup, run the wall-switch wiring back to the switchboard, and use 5x1.5 mm² to each roller shutter motor [#17440985][#17433417] One suggested arrangement is 4x1.5 mm² between the switchboard and the wall switch, and 5x1.5 mm² from the switchboard to the shutter, so the system can still work via the local switch if the wireless module fails [#17441148] 4x1.5 mm² is only enough for a very simple up/down installation; if you may later add phone, clock, or smart-home control, 5-core gives more room for changes [#17435970][#17437005]
  • #1 17430956
    grippen123
    Rate: 80
    Hello, I am at the stage of building a house. I am planning to install up to 6 external roller shutters. The installation will be led to one switchboard with drivers. Which cable is best to use 4 or 5 wires?
    rtvserwisant
    Help: 59
    Rate: 97
    It is always better to use a 5-wire cable.
  • #4 17432807
    grippen123
    Rate: 80
    Ordinary blinds, the cheapest up and down. The best control is a phone or a tablet. I don't have a selected system yet. Installation for now.
    Added after 6 [minutes]:
    Archive link subject. I guess it has changed a little over the years.
  • #5 17432892
    suworow
    Help: 650
    Rate: 1278
    It hasn't changed much. Electricity is still supplied from the wire, and the blinds usually work up and down :) It does not change that in order to give the right advice you need to know the exact requirements and that you still have to drag users by the language to say something more. The changes are only that with each subsequent question of this type I become more and more grumpy (or maybe just with age), but not malicious, because I would still like to help, but not on the principle: "you will be pleased" :) Is a colleague planning, for example, some local buttons on the roller shutters, or only control from remote controls or telephone? Why the system with the controllers located centrally and not locally in the boxes next to the roller shutters? What are these drivers? From which this choice comes from. Why won't he consult it with the roller shutter supplier, and if he has already done it, why won't a colleague present this concept to us for discussion :)
    mawerix123
    Help: 482
    Rate: 951
    Of the last three roller shutter installations, in each of them I put a 5x1.5 fixed L cable for remote control + G / D / N / PE
    suworow
    Help: 650
    Rate: 1278
    Is it for the fungus that a colleague plans to buy drivers mounted to cans?
    grippen123 wrote:
    At the moment I have decided to run a 5x1.5 cable to each point.
    The cable has some kind of beginning or end (or if you prefer two ends ;) It is not enough to say where it happened, but also where it came from. (in report) Maybe a friend will draw what he wants to do?
  • #9 17435970
    Marek J.
    Help: 526
    Rate: 951
    If a colleague does not know what he wants yet and the motors in the roller blinds will be
    grippen123 wrote:
    ordinary cheapest top bottom
    is 4x1.5 from each roller shutter motor to the switchgear and 4x1.5 from each G / D switch to the switchboard. Remember to leave free space for modules, controller, etc. in the switchgear, depending on the number of roller shutters. Everything can be done with this roller shutter arrangement.
    suworow
    Help: 650
    Rate: 1278
    Not only up and down? ;)
    Well, the author probably does not know what he wants to do himself, and this 4X cable comes out a bit ...
    After all, you can also power all the blinds from one 3X in boxes, next to the blinds, give drivers and pull the cables from them to the buttons :)
    Marek J.
    Help: 526
    Rate: 951
    But if you fancy Fateka, Logo! or another PLC system or a clock that controls a roller shutter or a group?
    Such a clock needs to be powered ...
    suworow
    Help: 650
    Rate: 1278
    Right. I just point out a certain inconsistency in cabling and the selection of equipment ...
    But don't forget that when it comes to central control, the author chose Fiu-Fi drivers (or maybe Wi-Fi? ;) )
  • #13 17437005
    grippen123
    Rate: 80
    The installation is to be able to be modified later. This driver was an example. Ultimately, I will want to control the phone or the clock remote control, maybe some "smart home" module. The cost of the wires is irrelevant. Therefore, all the cables to the switchboard will be seen later. The installation is to be exaggerated. I was thinking about twisted pair comp. then there would be a lot of room for maneuver.
  • #14 17439830
    grippen123
    Rate: 80
    I am still wondering whether to let go of the wires from the wall switches to the switchboard or to the blind. From the switchboard to the 5x1.5 roller blind, these wires will be wifi control, clock, etc. And the wires from the GD Stop switches. Only the central switch for the switchgear. But will all the cables to the switchgear be better?
    Marek J.
    Help: 526
    Rate: 951
    To the switchboard.
    And how will you protect yourself against accidentally applying voltage to both directions of the engine?
    mawerix123
    Help: 482
    Rate: 951
    You can like this
    4x1.5mm2 cable from the switchboard to the switch, from the switchboard to the 5x1.5mm2 roller shutter.
    The principle of operation is simple, when the roller shutter is controlled by the module in the switchgear, the switch is de-energized.
    If the wireless control is damaged, the blinds will operate via the switch anyway.
    Marek J.
    Help: 526
    Rate: 951
    @ mawerix123
    Did your colleague read the previous posts carefully?
    To the user @ grippen123 it was about:
    grippen123 wrote:
    So I am still wondering whether to let go of the wires from the wall switches to the switching station or for roller blinds.
  • #18 17459909
    grippen123
    Rate: 80
    Thanks to everyone for your help.
    Subject solved. I close
The discussion revolves around the optimal cable choice for installing six external roller blinds, specifically debating between 4x1.5 and 5x1.5 wire configurations. Participants generally recommend using a 5-wire cable for better functionality, especially for remote control options. The author plans to control the blinds via a central switchboard and is considering future modifications, including smart home integration. Various suggestions include using drivers like the Blebox Shutterbox and Zamel, and considerations for local versus central control systems are discussed. The importance of leaving space in the switchboard for additional modules and ensuring proper wiring to prevent voltage issues is emphasized.
TL;DR: For roller shutters, 5‑wire is the flexible choice—"It is always better to use a 5‑wire cable." Plan home runs to a central switchboard and allow future smart control without rewiring. [Elektroda, rtvserwisant, post #17431082]
Why it matters: This helps homebuilders planning up to six external roller blinds choose cable counts, topology, and drivers confidently.
What’s the best cable for external roller shutters: 4x1.5 or 5x1.5?
Choose 5x1.5 mm² to each shutter for flexibility and interlocks. "It is always better to use a 5‑wire cable." This decision reduces rewiring if you later add smart control. [Elektroda, rtvserwisant, post #17431082]
How should I cable if I haven’t chosen a control system yet?
Run 4x1.5 from each motor to the switchboard and 4x1.5 from each Up/Down switch to the switchboard. Leave space for drivers and control modules. "Everything can be done with this roller shutter arrangement." [Elektroda, Marek J., post #17435970]
Should wall switch cables go to the switchboard or directly to the shutter?
Route wall switch cables to the switchboard. This matches centralized driver setups and keeps your options open. [Elektroda, Marek J., post #17440985]
How do I wire Wi‑Fi control with manual fallback?
Use parallel wiring that isolates the switch during module operation. Home‑run 4x1.5 to the wall switch and 5x1.5 to the shutter. How‑To: 1. Home‑run both cables to the switchboard. 2. Connect the module outputs to the motor’s UP and DOWN leads. 3. Use the module or relays to de‑energize the switch when driving. If wireless fails, the switch still works. [Elektroda, mawerix123, post #17441148]
How do I prevent powering UP and DOWN at the same time?
Add electrical interlocking between the two directions. Dedicated shutter modules or properly wired relays will block simultaneous feeds. This prevents simultaneous voltage on both motor directions. [Elektroda, Marek J., post #17440985]
Can I centralize all drivers in the switchboard?
Yes. Centralizing drivers supports PLCs or time clocks for group control later. Examples include Fatek and Siemens Logo! [Elektroda, Marek J., post #17436009]
Can I instead use local modules next to each shutter?
Yes. You can power all blinds from one three‑core feed to boxes near each shutter. Place the drivers locally and run short cables to the buttons. [Elektroda, suworow, post #17435994]
Is 4‑core cable enough for basic UP/DOWN motors?
Yes. With ordinary up/down motors, 4x1.5 mm² from each motor to the switchboard works. It supports straightforward central control. [Elektroda, Marek J., post #17435970]
Do I need PE and Neutral at the motor point?
Yes. Plan G/D/N/PE to each shutter, with a fixed L for remote control where applicable. This supports versatile control options. [Elektroda, mawerix123, post #17433417]
Should I also run a twisted pair (Cat/UTP) for future integration?
Consider adding a twisted‑pair run for future sensors or bus control. It offers extra room for maneuver during upgrades. [Elektroda, grippen123, post #17437005]
Where should I connect the central “All Up/Down” switch?
Wire the central switch to the switchboard. This aligns with centralized control and simplifies later changes. [Elektroda, Marek J., post #17440985]
Is more than five cores ever worth it?
Extra conductors add options for future logic or sensors. As one expert noted, "Or better six, and that's not my last word." Use them if budget allows. [Elektroda, suworow, post #17431769]
Do Wi‑Fi modules fail safe—will I lose control if they die?
Design for resilience. "If the wireless control is damaged, the blinds will operate via the switch anyway." This requires the fallback wiring described above. [Elektroda, mawerix123, post #17441148]
