Somfy J4 RTS vs J4 WT for Facade Blinds: Arduino Mega & Domoticz Integration Options
frytek1986 2622 1
  • #1 17446910
    frytek1986
    Hello. I'm at the stage of choosing facade blinds for my house. The idea is that they would be controlled by an Arduino Mega connected to a Rasberry Pi with Domoticz.
    I am wondering which motor to take for the facade blinds:
    - Somfy J4 RTS
    - Somfy J4 WT
    - any other, do you recommend?
    Anyone done something like this before? With roller shutters it's simpler, every plc will control it because it's only a matter of giving L1 and L2. Here the matter is different because it is also about the rotation of the lamellas. From what I read, this is done by giving a short (<1sec) signal which controls the blinds.
    I have seen at Anwis (blinds manufacturer) a nice remote control where you can set the angle of the lamellas very precisely (10 steps), can such a thing be (and how) realised using Arduino and Domoticz? I would like these systems to be open to my small automation and not closed in, for example, a Somfy remote control (which, by the way, costs over 600PLN for 16 channels).
    Another question concerns cables. I understand that it is best to run cables from each facade shutter to the control panel. In this case, would 4x0.5 cable be suitable? In addition, I would like to be able to control a wall button. I also run a cable from this to the control panel, e.g. 3x0.5 (up/down) and connect this to the digital input.
    Does anyone have something like this ready and programmed? There are examples for roller shutters, but I have not yet found any.
    Can driving short signals (0.1sec) with an Arduino Mega be problematic?
    I would appreciate any advice on this topic. I'm just starting out (Arduino, PI on the way) but I need to let go of the blind order now (to properly prepare the lintels in the house). I therefore need to know the model of the motor.
    Thx!
  • #2 18226815
    grzmac83
    I'm bumping up the topic.
    I'm at the stage of choosing hardware for a smart home and selecting facade blinds.
    Probably my solution will be based on Raspberry pi + Andruino Mega + Domoticz.
    I would like to go towards wired motors for the blinds and control via 2 solid state relays due to their faster response time than electromagnetic relays. On the logic side, I will make a protection so that two relays cannot be used at once. I understand that these types of relays will be fast enough for me to be able to rotate the louvre blades comfortably?
    Fries, perhaps you have already managed to grasp this topic?
    Greetings,
    Grzmac
