ESP8266-12F Flashing: Address Offsets for NONOS_SDK-2.2.1 Firmware
shel82 2145 6
  • Clarifying ESP8266 NONOS SDK flash offsets
    #1 17831021
    shel82
    Rate: 116
    Hello, I'm starting to play with the ESP8266 (in my case it's version 12F), I wanted to upload the original FW and I'm starting to get nystagmus.
    I've downloaded probably the latest version marked as NONOS_SDK-2.2.1 (that is, the one without the operating system), but reading the manual I don't really know at which addresses (offsets) to upload the different parts (binary images) of the software I'll add that I'm using ESP Flash Download Tool.
    There is a description in the README.md from the bin/at directory, but it is nowhere near the naming of the files contained in the package.
    From what I understand, in order to upload the simpler version (the one without the ability to update the FW via WiFi - direct Flash programming) I am interested in NON-BOOT MODE##, according to which for the ESP-12F version (4MB) I upload the following
    eagle.flash.bin 0x00000
    eagle.irom0text.bin 0x10000
    Flash size 32Mbit: 0x7e000 & 0x3fe000
    However, in the downloaded package I have the following files:
    blank.bin
    boot.bin
    esp_init_data_default.bin
    user1.1024.new.2.bin
    user2.1024.new.2.bin
    and I don't really know what to put where?
  • #2 17831181
  • #3 17833851
    Nagus
    Help: 99
    Rate: 97
    Don't go down this road. The only valid SDK for ESP8266 is ESP8266_RTOS_SDK, which is successively being rewritten in esp-idf style. That is, it is being developed intensively, and ESP8266 and ESP32 support is also being unified. There the firmware update is simplified - you have one soft image file. Anyway, uploading software is done from within the built-in makefile, so you don't have to fiddle with it at all.
  • #4 17834400
  • #5 17836199
    Nagus
    Help: 99
    Rate: 97
    Even after removing the ideological wording, NONOS_SDK is non-perspective, as the development burden has been shifted towards esp-idf. An additional advantage of esp-idf is that ESP8266 software can be ported to ESP32 and vice versa, with only minor adjustments. Also, there is no need to combine coarse features such as native http server support, which is unlikely to be present in NONOS, while it is just starting to be introduced in RTOS (ESP32 already had it).
  • #6 17836627
  • #7 17836894
    Nagus
    Help: 99
    Rate: 97
    OK, too much of a mental shortcut....
    The ESP32 has much beefier peripherals, so if something is based on peripherals unique to the ESP32, then porting it to the 8266 at face value isn't going to work.
    But, for example, such support for a basic UART. In the ESP8266 there is no pin setting for the UART and the uart_driver_install function has one less parameter. Everything else qualifies under ctrl-c ctrl-v. Knocking one command and one parameter out of another can hardly be considered code ploughing.
    There are hardly any drastic differences in WLAN interface handling either.
    I've done a bit of practice with both, used large chunks of code on both platforms, and apparently I've developed some strange beliefs.
The discussion revolves around flashing the ESP8266-12F with the NONOS_SDK-2.2.1 firmware. The user seeks guidance on the correct address offsets for uploading binary images using the ESP Flash Download Tool. Responses indicate that the binaries must be built from the ESP8266_NONOS_SDK GitHub repository. Some participants recommend transitioning to the ESP8266_RTOS_SDK, which is actively developed and simplifies firmware updates. The NONOS_SDK is noted for its compatibility with higher-level programming languages like Lua and MicroPython, but it is considered less future-proof compared to the ESP-IDF framework. The conversation highlights the differences in development focus between the two SDKs and the potential for code portability between ESP8266 and ESP32 platforms.
