Which petrol lawn mower with a drive, and preferably engine speed control, can I buy for up to PLN 1400?
At PLN 1,400, don’t expect a really sensible petrol mower with both drive and engine speed control; several users say you need to raise the budget to about PLN 1,800 to get that feature set [#17911266][#17945862] If you can stretch the budget, look at AL-KO models such as the Classic 518 VS or similar Highline/Premium versions, or at World mowers with Loncin engines, which were repeatedly praised for durability and parts availability [#17911266][#17945862] Avoid NAC and other random Allegro/no-name builds, because users warned about poor quality and lack of spare parts [#17897754][#17946169] For the engine choice, Loncin was generally preferred over current Briggs & Stratton, which several posters described as weaker than older B&S units [#17900200][#18769146] As for the speed-control lever, it usually adjusts the governor spring/sensitivity rather than directly setting throttle, so the engine still self-stabilizes under load [#17935862]
I strongly advise against it, Handy is an even more difficult case than NAC, Husar or Ursus. There are no parts for it, the casing quoted "made of durable material" can fall apart after the first season. There are 4 sites in my area, including ours, and nobody wants to fix it. If you have a service around you that promises you that it will repair ... you can risk. The Loncin 139 ccm engine is a unit for light mowers and for small areas, the transmission is definitely an "invention". Well, for the money ... mower + knife + oil - it's hard to make something good.
Is it enough for oil, filter, candle replacement, knife sharpening PLN 240? The spare parts themselves are expensive and not only consumables, here the guarantee is to milk the customer out of money and if it breaks, unfortunately it will be the customer's fault, I have already seen rusted Honda after 8 years and as we know it is not the same quality as it used to be because they make them unknown where. When it comes to functionality, AL-KO is unbeatable in this respect and the website you mentioned I would rather be afraid to mention because of the positive feedback for money and I also heard about removing uncomfortable posts.
As for the site https://pilarz.org, I agree with you - I have noticed deleted posts more than once. I don't know where the prices are - maybe in the salon where you work, but for a quick showroom (for this authorized Honda) next to me www.lopeno.pl for what you wrote takes: oil change -> 28 PLN original air filter -> 29 PLN candles -> PLN 11 (which is rarely replaced) knife sharpening -> PLN 7.50 and for the entire inspection (which you call taking money from the customer), that is: oil change, filter, candle, knife sharpening, valve clearance adjustment, drive check, lubrication of drive parts cost: PLN 70 plus parts (oil, filter, candle, prices above) in) As for the housing from the bottom, it does not matter what company, if you do not maintain it, you clean it, sooner or later the rust will come out on each device. The quality of the Honda bank has not changed anything. What is Al-Ko better in terms of functionality than this Honda SKEPA what I gave? http://www.mojahonda.pl/kosiarka-honda/kosiar...nda-izy-ii/kosiarka-honda-hrg-466-skep-detail not looking at the engines unfortunately from the lower shelf. :)
Yes, that's right, Honda comes with a 5-year retail customer warranty. Agree Weibang also makes decent machines (based on Honda engines) - it's hard to disagree. As for the chassis - the model you provided is the same price, e.g .: 476 VKE -> https://www.honda-sklep-lopeno.pl/product-pol-137-HRX-476-VKE.html 476 VYE -> https://www.honda-sklep-lopeno.pl/product-pol-138-HRX-476-VYE.html The bodies of the above-mentioned models are made of the same material as the Formula 1 Honda cars, that is, they are very strong, light and will not rust. You can hit with a hammer and you won't break it.
Hello, I am looking for proven equipment up to 1200 or less The requirements are a mowing width of 44-46 cm and a basket. Preferably without a drive. What to consider?
Maybe something like that, the cutting width is a bit smaller, but the price is also much smaller.
Proven equipment is NAC. The engine has been running for 10 years. You have to buy the accessories by the kilograms. It will be cheaper. Proven, cheap but crap.
Today you will not buy an engine from 10 years ago. Currently, NAC has added a crazy engine to the crazy gear.
It's definitely worth it. Probably the best corps in the money. 159 ccm engine, over 8 Nm is not afraid of any work. Not yet loaded with the drive, it chops even dense grass. In general, I have been servicing Worldy for many years and no complaints ... I have one myself on a small plot ... also the previous model with a choke cable. He will be in the 8th season, the drive sprockets in the rear wheels have broken down, so he has been pushed since last season and ... he does not want to die. It's a pity to spend on a new mower as the devil is still mowing, the body is healthy and everything works. I will not put money into the drive because I hope that it will finally go to the end ... But when will it be? Whenever you can - take World. I bought mine and is servicing it here: https://multimaszyny.eu/kosiarka-bez-napedu/1...a-spalinowa-world-grl-460p-hw-4w1-loncin.html
[quote = "Lucas81" ] As for the case from the bottom, it does not matter what company, if you do not maintain, clean it, sooner or later the rust will come out on each device. The quality of the Honda bank has not changed anything. What is Al-Ko better in terms of functionality than this Honda SKEPA what I gave? [/ quote]
You probably have confused the concepts with these housings, this is not the fairy tale, these are normal in Honda rusting housings, the prices of such high inspections are in Honda services and maybe not in yours, but they plunder customers evenly, as for mower housings, it just matters what it is from below because thanks to this, if neglected, the mower will rust much later.
On the other hand, the mentioned forum works on the principle of "if you pay, you have favorable opinions" and for this, posts that do not suit them are removed and people think that they recommend machines selflessly.
The first mower for them, due to the so-so engine with a weak starter, has an ordinary housing and its origin is unknown, AL-KO does not sell this model, how to take AL-KO with a housing only Highline and these are the best collecting mowers, even 100% of the basket is loaded with moist grass.
The second is the most, but in the description they write that the housing is up to 4 mm, which is not true, and the further description is also a bit stretched, I would buy it personally on Allegro. Third is third so that should be enough.
Summing up, if you are looking for a nice and functional mower, you have a little well-kept lawn, AL-KO is the best, if it is to be simple to mow everything, including stones, sticks, and debris after construction, it is WORLD, I would forget Oleomaca.
I will stick to the topic because I am struggling with the purchase of a new mower. I am considering 3 models: Link Link Link
Which in your opinion is the best choice and why?
As Tomek-Zagórski wrote, the best choice of these 3 is WORLD in Loncin. The casing is 1.8 mm thick (it's thick for a lawn mower) and is painted with a primer - what importance you will see after many years when the paint will not come off in patches :)
I recommend the store: https://multimaszyny.eu/kosiarka-z-napedem/12...a-spalinowa-world-grl-530s-hw-4w1-loncin.html they have an account on alledrogo, but if you buy through the store and call / you write that you know about them from the electrode forum will add oil for free. A small thing, but it enjoys. Because after 5 working hours of the mower, the oil must be changed (after running in). So this run-in bottle will give you time to boot smoothly.
I put on a Brigs engine from a mower to a rotary tiller, it was also from this company, but it fell. How do you recommend remaking the engine speed control?
And I have a question basically for service technicians, and even two: 1. Is it worth buying a stimulant? 2. What is the smallest petrol mower on the market? Justification: grass only 70 sq m, but I don't have the strength to buy and patch a regularly cut cable anymore. A woman uses it ...
Exactly, for this size, buy a battery, some cheap (Jula, Castorama). As for stimulants, I will recommend Honda, at least some of them will be available on the bank for a long time after the production of a given model is finished, but it makes no sense to use a gas tube for such a size. : /
I refresh the topic I am looking for something from exhaust gases also up to PLN 1400 or something like that. The key of choice is the drive, 46cm, mumbling, side ejection, rear. I consider. 1. Petrol lawn mower MacAllister B&S 675IS 46 cm with starter price PLN 1448
2. WORLD GRL 460S HW 4W1 Loncin 166 cm engine, about PLN 1300
3. STIGA COMBI 48 SQ 166cc PLN 1375
B&S from the 6 series is already a recommended engine. Loncin from the Chinese also has good reviews. And Stiga because I once had and remained sentiment.
Out of all this company, definitely the GRL 460S, it will definitely be more durable than the Stigi, MacAlister is a typical Chinese market without spare parts
Is it worth paying extra to Brigs in WORLD GRB 460S HW 4in1 B & S625 ???
and a question about the drive .... yesterday I had discussions about whether to take a motorized mower or not? Some of my lawns have some obstacles, such as trees, bushes, which causes frequent maneuvers. In another part, I have straight episodes again. I also found out that mowers without a drive seem to be less stuck with grass due to the larger outlet opening to the basket. etc etc.
So load into the drive ??? Mowers anyway, due to obstacles, I will not take more than 46cm.
The discussion revolves around selecting the best petrol lawn mowers under PLN 1400, emphasizing the need for a drive and engine speed control. Participants express strong opinions on various brands and models, highlighting the reliability of engines such as Loncin and Briggs & Stratton. Recommendations include models from Oleo-Mac, AL-KO, and World, with specific models like the World GRL 460P HW and AL-KO 470 SP-A being frequently mentioned. Users caution against brands like NAC and Handy due to poor quality and lack of spare parts. The importance of engine durability, ease of maintenance, and the mower's build quality are also discussed, with a consensus that investing in a reliable engine is crucial for long-term satisfaction. AI summary based on the discussion. May contain errors.
