Best Petrol Lawn Mowers under PLN 1400 with Drive & Engine Speed Control: Top Picks
ustijuf 146334 140
Which petrol lawn mower with a drive, and preferably engine speed control, can I buy for up to PLN 1400?
At PLN 1,400, don’t expect a really sensible petrol mower with both drive and engine speed control; several users say you need to raise the budget to about PLN 1,800 to get that feature set [#17911266][#17945862] If you can stretch the budget, look at AL-KO models such as the Classic 518 VS or similar Highline/Premium versions, or at World mowers with Loncin engines, which were repeatedly praised for durability and parts availability [#17911266][#17945862] Avoid NAC and other random Allegro/no-name builds, because users warned about poor quality and lack of spare parts [#17897754][#17946169] For the engine choice, Loncin was generally preferred over current Briggs & Stratton, which several posters described as weaker than older B&S units [#17900200][#18769146] As for the speed-control lever, it usually adjusts the governor spring/sensitivity rather than directly setting throttle, so the engine still self-stabilizes under load [#17935862]
  • #61 18630408
    zagorski-tomasz
    Help: 8
    Rate: 141
    In this mower, only the engine is ok, the rest is Chinese so-so, and when I read that the mower has, for example, 9in1, my hands drop. Sellers bend descriptions as much as possible just to sell. I would never buy it, so you have to consider whether you want to wade into such Chinese machines or whether it is better to buy something better. The weight of this mower shows that the casing is made of thin sheet metal and may not last a long time.
  • #62 18651014
    baki1992
    I read the whole topic and I wonder what petrol mower to buy. The budget is about 1500-2000 and the mowing area is 1500m2. For now, only the grass is sown, but it is worth starting to look around for something. So far there are no trees or anything. Thanks in advance for the suggestions.
  • #63 18653091
    bieder1
    zagorski-tomasz wrote:
    bieder1 wrote:
    I refresh the topic
    I am looking for something from exhaust gases also up to PLN 1400 or something like that. The key of choice is the drive, 46cm, mumbling, side ejection, rear.
    I consider.
    1. Petrol lawn mower MacAllister B&S 675IS 46 cm with starter price PLN 1448
    2. WORLD GRL 460S HW 4W1 Loncin 166 cm engine, about PLN 1300
    3. STIGA COMBI 48 SQ 166cc PLN 1375
    B&S from the 6 series is already a recommended engine. Loncin from the Chinese also has good reviews. And Stiga because I once had and remained sentiment.
    Out of all this company, definitely the GRL 460S, it will definitely be more durable than the Stigi, MacAlister is a typical Chinese market without spare parts
    In the end, the choice fell on the AL-KO Premium Highline 470 SP-A petrol lawn mower (119946)
  • #64 18660882
    zagorski-tomasz
    Help: 8
    Rate: 141
    Good choice as you can buy it from your local dealer.
  • #65 18741726
  • #66 18741839
    78db78
    Help: 1826
    Rate: 3306
    I have about 20ar for mowing, I have an oleomac with 196cm3, the engine is already working for the 5th season and it is important in the mower whether it mows the basket or not, the drive is useful so as not to push the rest, it's even a pity to read. Engines smaller than 196cc are too weak speed control I have but I never use, always mowing is at maximum speed and that's about the topic and not writing about the year to buy a mower, I made my decision in 15 minutes when I was in the store. And after 2 see on YT, the guy takes the EMA's engine apart and compares it to the Honda, it's the same, worse, the B $ S engine falls out.
  • #67 18742317
  • #68 18742357
    78db78
    Help: 1826
    Rate: 3306
    Hello, it's probably about the max, i.e. let it be starting power = max torque * 0.86 at 4500 rpm
    and net power horsepower = torque * 0.59 at 3100 rpm
    I think that the optimal RPM is 2800 = 2900 more will destroy the engine.
    As you know, the maximum power of the engine is just a marketing gimmick, and we, the customers, mechanics and sellers, should care about the useful power of the mower.
    Useful power, assuming work at 3100 RPM for B&S engines, it looks like this (maximum engine power in brackets):
    400 - 2.36 hp (3.44 hp)
    450 - 2.66 hp (3.87 hp)
    500 - 2.95 hp (4.30 hp)
    550 - 3.25 hp (4.73 hp)
    575 - 3.39 hp (4.95 hp)
    600 - 3.54 hp (5.16 hp)
    625 - 3.69 hp (5.38 hp)
    650 - 3.84 hp (5.59 hp)
    675 - 3.98 hp (5.81 hp)
    700 - 4.13 hp (6.02 hp)
    800 - 4.72 hp (6.88 hp)
  • #69 18743539
    Enjama
    After 12 years, I would like to replace the mower. So far I had a Partner 190cc Briggs Bottom Valve. The mower still works, but the drive is lame, the metal gear of the wheel is broken. I've already earned some extra money from a turner. I will leave it as a spare, I liked the fact that there is no problem with the parts, you can buy everything at Husqvarna even after 12 years.
    Budget up to 2k PLN
    In total, I am swinging between two models:
    World GRL 530S / 560s Loncin 196cc engine
    or pay 500 PLN and buy it
    Weibang WB537SLC Loncin 196cc engine
    Maybe someone knows if these mowers have metal gears?
    And is it worth paying an extra 500 zeta for this Weibang?
  • #70 18743580
    krzych101
    Rate: 71
    World GRL 530S / 560s I advise against it, I bought this year with a B&S 675 engine they sent me with a damaged drive I wrote to the service in Białystok no response the engine goes out with denser grass, previously I also had B $ S 500 with the engine but it was unstoppable and I bought World GRL 560s because on the gardening forum they praised that good workmanship but it's nonsense and service for nothing, I would not buy this shit anymore, the engine is very weak, the wheels on the bearings shift, and a liter of fuel will burn for an hour, so where's the savings
  • #71 18743762
    Enjama
    Well, you worried me, because many people recommended this equipment, you have a capacity of 163cc with a weaker Briggs engine
    It aims at a 196cc Loncin.
    Can you tell me what you mean with this wheel shift? You mean that, for example, when withdrawing the lever from the regulation, it changes its position?
    If someone spoke about this Weibang model, is it worth paying extra for it?
  • #72 18743786
    zagorski-tomasz
    Help: 8
    Rate: 141
    Here, I would complain to those in Białystok, not to the machine, they sold you something damaged as you write, when the machine is operational, there is no problem with them and they pressed what they had, if, of course, what you write is true
  • #73 18744079
    krzych101
    Rate: 71
    Why should I write not true, the front wheels are not horizontal, one is higher, the other is lower, the mower moves on 3 wheels because one is always in the air, generally the mower is very heavy, it is difficult to drive without a drive.
    The grass bag is a misunderstanding, when you mow it you can't see the dust, all the dust comes out through the grass basket, it's not a basket material. How can you sell a mower without springs that tension the mower drive belts, where they have internal control The paint comes off in places after several mowing. Where is the very good performance here?
  • #74 18744347
    zagorski-tomasz
    Help: 8
    Rate: 141
    As far as I know, such a thing happens not only in these mowers but even in more famous companies and it is the fault of the wheel mounting welding probably, you see when someone sold you a mower without a spring tensioning the belt, blame him because maybe they pulled it out themselves, but I do not know the matter and it is not my problem, but I can only sympathize with you, the material basket is like dust is flying from it and you could buy it with a plastic basket, also do not complain by weight because you have seen you buy, I have already seen these mowers in person 10 years old and there was paint on the underside and the rest of the housing in very good condition and when it goes down you should advertise it, well, unfortunately, as you can see, despite the good reputation of these machines, they can also put away the linden
  • #75 18744386
    enhanced
    Help: 964
    Rate: 885
    I bought WORLD GRL 460P HW 166 ccm 4in1 LONCIN there at the end of that year - 8.3 Nm and I can't complain, is there something dust? People, what a text - if you mow dusty places, it will get dusty, it is not a vacuum cleaner with filters.
    The wheels run normally, all four are stable, burns a little, and certainly not a liter per hour, fires an arrow, it is heavy but I knew what I was taking - at least something apart from the engine is and must weigh.
    No paint on the top comes off because I haven't looked at the bottom.
    Apparently you got some broken scrap.
  • #76 18744987
    krzych101
    Rate: 71
    I am writing which mower from World GRL 530S / 560s I came across, I had no influence on the choice of the basket because it was the only one it was exposed to, I understand that it can get dusty, but if the world is not visible at 30m, it is probably not ok
    Personally, I did not see this mower before buying it, I trusted the opinions from the Internet, but probably most of the positive opinions were issued by the sellers of these mowers. It is definitely a lesson for me for the future
  • #77 18745016
    Enjama
    Gentlemen, I decided on the Weibang company
    I just don't know which engine to choose
    Is Loncin 196 cc 3.6 kW and 10.5 Nm
    Or a more expensive model by about PLN 150
    Kohler XT775 173cc 3.5kW and 10.5Nm engine
    The power is practically the same, only Loncin has a larger engine capacity.
    The model from Kohler is WEIBANG WB536SKL
    The model with Loncin is Weibang WB537SLC 3IN1
  • #78 18745409
    palmus
    Help: 235
    Rate: 755
    If it is possible (drunk more to the moderator) in this thread, someone can suggest a machine for a very small garden? The only criterion is the regularly cut and tangling power cord of the electric charger, which I want to eliminate. I was thinking about a stimulant, but I think it's a cat in a poke. I do not want to give PLN 1,500, unless it is not possible.
  • #79 18747936
    zagorski-tomasz
    Help: 8
    Rate: 141
    Many companies have already tried Kohler and it's a misfire, you won't buy some parts in a while, generally I wouldn't buy Weibang at all, but if you insist, take Chinese.
  • #80 18747950
  • #81 18748043
    Enjama
    I ordered with Loncin, why don't you recommend Weibang?
    Honestly, I haven't found any negative opinions about them on the internet.
  • #82 18748220
    zagorski-tomasz
    Help: 8
    Rate: 141
    Now, as you ordered this mow, it's too late for such posts as to what, how and why.
  • #83 18752316
    adi790
    Rate: 16
    Hello .
    I need a new petrol lawn mower with a drive and possibly electric start (but not necessarily). budget max. 2 thousand
    So far there was Nac 375 (tragedy with engine, drive), then Leroy Sterwins brand with B&S 575 with electric start. It lasted two years, i.e. the start-up failed at some point (cables were replaced), and then the drive broke down for good. Now, reading, I am stupid because many people say that Brigs engines are now not the same and better Loncin, or other brands? I care about a mower with spare parts, especially drives and housings. Will someone recommend something sensible that will work and comes without any adventures for a few years. The mower does not have to be powerful, it mows on a regular basis :) if the mower is running. :)
  • #84 18754322
    zagorski-tomasz
    Help: 8
    Rate: 141
    And look at AL-KO mowers, they have everything you need
  • #85 18760132
    petertabak
    I am a total layman when it comes to petrol lawn mowers, I do not want someone in the store to push the equipment from which I will get the highest commission, but the equipment that I will be happy with and will serve me for years, and spare parts will be available at affordable prices.
    I have a plot of about 10 ares with a noticeable tilt, hence I need a mower with a drive, I think it would be good if it had a mulching function.
    I would also like a mower with the possibility of disengaging the drive, because I read somewhere that not all of them have one, that I can easily withdraw it without lifting it.
    And now the most important thing, the price range is only PLN 1600. What would you recommend? I was looking at Al-Ko 475SP, Highline 527 SP and Oleo-Mac GV25 + 53TK
  • #86 18765532
    zagorski-tomasz
    Help: 8
    Rate: 141
    Definitely AL-KO, but look for this year's models, these are older
  • #87 18769146
    grzesiekyogi
    Definitely AL-KO
    Sorry, Mr. Zagorski-Tomasz, but definitely NOT !!!. That's because AL-KO is powered by Briggs & Stratton engines. Today's brigs are unfortunately a scrap (unlike the old indestructible brigs). They are at least a class (or even two) worse than loncin. You ask why?
    Here you go:
    1) loncin-cast iron cylinder liner / brigs-aluminum (no liner !!!)
    2) loncin- rolling bearing in the body / brigs - no bearing (slide bearing !!!)
    3) loncin- aluminum brigs carburetor - plastic carburetor
    4) loncin- hard brigs crankshaft - guanolite shaft with a much smaller weight and size
    etc. etc.
    You don't believe? Watch. https://www.youtube.com/watch?v=jLXlOsJpRA4
    Mr. petertabak: take for example the one mentioned by Mr. Oleo-Mac or any other one on the Loncin engine. Avoid all Brigs mowers. It really is gOwnolit!
  • #88 18769255
  • #89 18769499
    petertabak
    Strange situation, but I think I will not choose any of the above, and I think I will go to the Chinese World GRL460S on loncin. I heard only positive opinions about it, it has a powerful engine, everything I need is the availability of parts in a few years, but somehow you have to find a golden mean.
  • #90 18769736
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1070
    petertabak wrote:
    the only thing I'm worried about is the availability of parts in a few years, but somehow you have to find a golden mean.
    In a few years there will be nothing to renovate.
    The equipment for years was years ago. In today's world, people want cheap and colorful. He cares little about quality the way you do.
The discussion revolves around selecting the best petrol lawn mowers under PLN 1400, emphasizing the need for a drive and engine speed control. Participants express strong opinions on various brands and models, highlighting the reliability of engines such as Loncin and Briggs & Stratton. Recommendations include models from Oleo-Mac, AL-KO, and World, with specific models like the World GRL 460P HW and AL-KO 470 SP-A being frequently mentioned. Users caution against brands like NAC and Handy due to poor quality and lack of spare parts. The importance of engine durability, ease of maintenance, and the mower's build quality are also discussed, with a consensus that investing in a reliable engine is crucial for long-term satisfaction.
