Best Petrol Lawn Mowers under PLN 1400 with Drive & Engine Speed Control: Top Picks
ustijuf 146334 140
Which petrol lawn mower with a drive, and preferably engine speed control, can I buy for up to PLN 1400?
At PLN 1,400, don’t expect a really sensible petrol mower with both drive and engine speed control; several users say you need to raise the budget to about PLN 1,800 to get that feature set [#17911266][#17945862] If you can stretch the budget, look at AL-KO models such as the Classic 518 VS or similar Highline/Premium versions, or at World mowers with Loncin engines, which were repeatedly praised for durability and parts availability [#17911266][#17945862] Avoid NAC and other random Allegro/no-name builds, because users warned about poor quality and lack of spare parts [#17897754][#17946169] For the engine choice, Loncin was generally preferred over current Briggs & Stratton, which several posters described as weaker than older B&S units [#17900200][#18769146] As for the speed-control lever, it usually adjusts the governor spring/sensitivity rather than directly setting throttle, so the engine still self-stabilizes under load [#17935862]
  • #91 18769827
    grzesiekyogi
    petertabak wrote:
    the only thing I'm worried about is the availability of parts in a few years
    In my opinion, you have nothing to fear. Not only the world, but a lot of other quinols are made on this engine and serviced in Polish workshops. There will be some parts for a long time. In addition to the engine, you only have a shack and a few lines where a smart man will always fix something in the absence of parts.
    Mierzejewski46 wrote:
    In today's world, people want cheap and colorful. He cares little about quality the way you do.
    Unfortunately, this is true and the manufacturer of B&S engines fits perfectly into this trend. Slowly, even something starts to be said about the lack of an oil change ... well, what for. "OSW" (Fire up, skew and push ... ol).
  • #92 18770314
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1134
    This is not said, only many engine models have this option written in the manual, only refilling is included, if it was not enough, and not a word about replacing ...
  • #93 18770610
  • #94 18770662
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1134
    Novile wrote:
    There is hardly anything else in the mower except the engine and the tow truck.
    Well, sometimes there is a drive gear, sometimes multi-speed or hydrostatic, sometimes there is a knife clutch ...
  • #95 18780172
    grzesiekyogi
    I have a question about AL-KO mowers. I do not withdraw from my opinion about B&S engines - it is still a scrap in my opinion and I will not buy this guano and I will not recommend it to anyone. I only have a question about the rest of the guts of AL-KO mowers. What does the kennel and other elements look like? Is the booth, e.g. 51.9 sp-h alcohol with a Honda engine, solid and durable? Does it only look nice? Are other elements such as gear, knife, etc. worth recommending from this manufacturer?
  • #96 18783386
    tome_rodowski
    I bought a combustion engine from StIhla, because I trust them only for them. You can buy it at good prices, e.g. clean garden. You won't find anything better
  • #97 18786177
    gian_franco
    I recommend the G-Force XSZ51A 4in1 224cc (in the car in the picture below).
    Purchased in 2017.
    I would mow the 3rd season but I hit a tree stump (hand thick) and the shaft probably bent (I hope it will be an engine repair). In the 2nd week I am waiting in Siedlce for the service, until he calls whether this mower can be repaired, or the engine to be replaced, or what, what costs, but the gentlemen on Kraszewski have a lot of work and you have to wait one more week (3 in total).
    If it is impossible to repair it at a reasonable price, I buy a second identical one, the older one will be for parts.
    I thought to kick something that does not break on the stumps (HRX 537C5 HYE, https://www.ehonda.net.pl/p/honda-hrx-537-c5-hye-kosiarka-spalinowa-nowosc_8462, for + 5.000 PLN, the last one model only without electric starter), but probably such a mower does not exist, and these clutches are apparently more of a good thing than a useful thing in practice.
    More details about the proposed model: https://kosiarka.pl/pl/300-kosiarka-g-force-xsz51a-2050000460692.html
    Best regards,
    Sebastian,
    Siedlce.
    Added after 19 [minutes]:
    Erbit wrote:
    wacek.wacek wrote:
    Proven equipment is NAC. The engine has been running for 10 years. You have to buy the accessories by the kilograms. It will be cheaper. Proven, cheap but crap.
    Today you will not buy an engine from 10 years ago. Currently, NAC has added a crazy engine to the crazy gear.
    I confirm
    When NAC appeared on the market, I immediately bought a scythe and a chainsaw.
    My scythe was stolen from me, Pilarka is still in use today.
    I would rather buy G-Force Grass for the second time https://kosiarka.pl/pl/300-kosiarka-g-force-xsz51a-2050000460692.html
    I am waiting for the verdict from the repair shop, whether after hitting the stump and blocking the blade, it can still be repaired or not.
    If it does not go to repair (impossible engine overhaul, too much damage, too high repair cost), I buy a second one.
    I was thinking about the highest model of Honda (without electric starter) for almost 5k PLN, because there is a clutch, the blade on the stump stands half a turn, which should stop damaging the shaft in such (super rare) situations, but apparently it is more than a practical thing .
    Greetings,
    Seba, Siedlce
  • #98 18786526
  • #99 18786797
    gian_franco
    You picked me up, buddy, but I survived mine. I don't know, maybe this photo from the plot confused you. I did not mow at home.
    Let me remind you that this is a topic about mowers up to 1400 and this one probably costs just that much.
    I can confirm that the G-Force cards are good. But the Loncin engines are also praised for their performance compared to the BS (which is like NAC and probably everything that is consumer, mechanical, electronic and not from NASA is simply less durable over the years). Planned Equipment Wear Bill Gates would say?
    Long time ago, the stage of looking at names is behind me. :)
    "You don't know where you cut the tree." I will not comment, it does not always mow at home. Normally at home on my plot, since puppy baskets (good 20 years old) I have polished every dimple, but I mowed around my block and "I was not well rested". ; ) Mowing around the block is a cool thing, the neighbors are always converging, a good social initiative, I recommend mowing and not only at home. Unfortunately, the grass was overgrown, the stump was always there, I always avoided it, but ... It happened. You have to mow more, especially with this mower, because for her 30 ares in the countryside is not enough, so I also drive between the cages on the estate, because the cooperatives mow, you know, maybe 2-3 times a year.
    Peugeot 508 is not some great car there. But thanks. (When it was necessary to replace the irons in it, I rolled up my sleeves, pushed back the boards on the channel and in turn, the wheels, rocker arms, sled, steering column and irons, I replaced them in 3 hours, looking at YT twice and calling my father-in-law once). Your "my anti-talent" to mechanics is not zero, I jumped to level 1 or 2 out of 10. ;)
    Oh, thanks also for the advice with these tree stumps.
    You have to watch out for obstacles, as you say, and not mow with a grain of salt.
    In this Grass (so that the computers do not get hit) my belt from the drive fell off only 2 times. But since I learned this mower - I push it lightly, setting the initial speed with the strength of my own hands, only when the wheels start to move I turn on the drive - the belt never fell off.
    Firing up is a fairy tale. Always the first time. It doesn't matter if it was a week or a winter.
    Of course, there are a lot of disadvantages, you clean e.g. a basket, the same one does not fill up to the end with grass (if it is high), no speed regulation, what else, well, then there is nothing to stick to. Okay, the knife is also a drawback, it is thin compared to what I saw under the Honda, and its waviness, it is hard to sharpen, it consumes quickly. But it's probably a type of mulching-collector knife, and this is what they have. If you want to change the oil, you simply tilt it to the side and it flies from the tap you pour. Poor thing, I flooded the air filter all over.
    I have no experience with other mowers (apart from my 1st BS, which I started mowing for a kid 20 years ago, it cost about 800-1200 PLN, I don't remember and it was driving, or rather it was pushed for 12 years). But years later the opinions changed, so the choice fell on "novelty".
    I say, there may be something better at this price. But I would take it a second time. What about the old one? Basket, filter, drive, wheels, housing, etc. What will fall in the new one, I'll take it out of the old one and go.
    Is this Janusz's approach? I do not start the engine, I prefer to pay people who know it, just like I am paid for my job, which I know better.
    If I had a company dealing with the maintenance of green areas,of course, I would be looking for a PRO, even those from Honda for 6-8k PLN, plus a scythe, tractor, olx, I even thought to haul it all with this Peżot to start ...
    I honestly like good things (IT come back) like the RTX 2060TI (once again: G-Force) working with a 32 core threadripper about other components, not to mention in my PC complex a year ago. He works at Microsoft, but since the stumps damage the shafts, and the Loncin 224 due to cast iron sleeves, cylinders, the shaft and other parts in the engine has a chance (I hope) to get out of it alive, why take Honda or Jonny Deer for the same stump will fly even more $$?
    Do not make a friend about people hasty conclusions, it is better to add something to the topic, because it recommended some trolling or hate without support. We know embroidery, it does not pay off. ;) Come to Siedlce, you know mowers, long lines, brick business.
    Greetings,
  • #100 18787152
  • #101 18790240
    barcelowicz
    I am looking for a mower in the range of PLN 1200-1300. Grinding and drive welcome. The acreage to be mowed is about 15 ares, the area is mostly level, but 10-15% of it remains after the activity of the mole. After an initial inspection of the Internet, World and AL-KO brands and the following models are in the lead
    https://grass.com.pl/produkt/Kosiarka-pl,Kosi...siarka-spalinowa-xsz46-loncin-159cm3-4w1/8144
    http://www.alko.sklep.pl/pl/catalog/view/2522/320/kosiarka-highline-46_8-sp-az-napedem
    http://www.alko.sklep.pl/pl/catalog/view/2770/320/kosiarka-comfort-46_0-sp-a-plus
    Any of these machines is worth recommending? Possibly, can there be anything else in this budget?
  • #102 18801404
    zagorski-tomasz
    Help: 8
    Rate: 141
    Everything is nice, but there is always some but ..., the Loncin engine breaks down when the flywheel breaks and the shafts straighten in them as in others, moreover, who is normal after buying a mower looks for a curb to hit it immediately, is the carburetor ready? made of plastic or cast does not matter because we do not mow with the carburetor, the engine in the mower is only part of the success, because if the rest is of poor quality, it is nothing, Oleomac is a mower which is a whole lot on the market and collects maybe 60% of the basket and is advertised for at any price, even overrated and not worth buying, just such an ordinary mower, going to the heart of the AL-KO mower case is a different story, an asymmetrical housing that facilitates attaching at e.g. a fence, Highline housings that fill the basket in 100%. Slip knife hubs and not thin aluminum as in Oleomac, you can also replace some advantages, AL-KO mowers are not expensive so we can choose a regular Oleomac or AL-KO mower that beats its Oleo mowers, even the Chinese World is better made from Oleomac.
  • #103 18805628
    Dawid727272
    If you choose a petrol lawn mower, then only with a drive. I mowed a large area at home and mowed without a drive at the beginning and then with a drive, so the difference in handling is a huge plus, of course, for the drive. My mower is an old AL-KO Silver 46 model with a 450 brix. I know, you will write. that weak and everything, but wait and let me describe it to you. I bought it from a friend when she was two years old. The mower from 2011 for me since 2013 and it mows full seasons from 2014. And now, in order not to be there, it works in the season from 50 mth to 80 mth about twenty mowing, each 4 hours with a break for emptying the basket or adding fuel. Now the mower is pulled down to the screw because it's time to fix it. So when it comes to a non-runnable engine, change the oil, clean the filter and the fire. After the winter, pump up fuel and it flies like crazy with the third pull. The drive is not badly resolved, but it lacks the best. In the middle of the drive, everything is metal, snails. bearings. but the shaft with the cable likes to work and then the drive works continuously, it can be repaired. but you have to think a bit. Plastic pulley roller, unfortunately I am replacing it now, because the other one has been damaged. Links to exchange because they are cracked or blocked in the armor. I had to sleep on the tow truck and repaint it, but it didn't cost anything because the materials were there. The wheels are super resolved, 2 bearings per wheel, all the time working. Now for me. If today's alcohol equipment is as good as the one I have, I would take it blind, because when I leave my mower for mowing, my neighbors nod their heads that this mower can handle so much. Parts service available, very good, practically everything can be ordered on the website, but their prices are very high.
    In conclusion, if the mower is only powered. The brix motors start up really nicely and are quite cheap. Take care of changing the oil in the season, clean the air filter every few cuts and, most importantly, sharpen the knife at least once every two cuts. Ps and wash the tow truck.
    And remember, don't believe this mower has 6, 8 or 10 horses. Capacity comes first, and then the rest, the old rule of thumb is that power comes from capacity. Of course, these cheap mowers.
    Regards and sorry for any typos.
  • #104 18826912
    batk
    Hi
    Is it worth taking the WORLD GRL 560 mower instead of the 530?
    It has a wider knife and a larger basket, and the price is practically the same.
    Unfortunately, I can't find any reviews for the 560 anywhere.
    Someone something? :)
    best regards
  • #105 18842495
    bednyk
    Hey, looking for a mower in rough terrain. Uneven meadow, molehills, 2000 m2.
    I am considering between:
    MAKITA PLM5600N2
    AL-KO Premium 520 SP-H Honda XL
    Which one would you choose and why?
  • #106 18848354
    zagorski-tomasz
    Help: 8
    Rate: 141
    If of these two is AL-KO, the mower is better made, it collects better into the basket, asymmetric casing, longer warranty, the engine is a relative thing and I don't like Honda
  • #107 18887787
    Feriz
    Have you checked out John Gardener? In my opinion, they have pretty cool equipment when it comes to the combustion versions. I have one with a drive and with a plot of almost 2,000 m2, I can handle it without problems.
  • #108 18887880
  • #109 18893061
    zagorski-tomasz
    Help: 8
    Rate: 141
    It's just an advertisement for one-time Chinese food, everyone is trying to sell something, especially inventions like Gard .......
  • #110 19000736
    Finsek
    I don't remember this name somehow, but everyone can have their own feelings. I think that it just works because I have a two-season version of the JG model G83051 and I am quite happy, especially in terms of price. The quality somehow I do not see that they stand out from the more expensive producers.
  • #111 19094414
    lambo2
    What do you think about Genkins engines? Mounted in NAC petrol mowers.
    I have such a mower at a good price in my store and I am thinking about buying it.
    NAC LS51-150-hsd-li for PLN 710
  • Request for mower recommendation under PLN 1400
    #112 19292979
    Gento123
    Good evening, I would like to buy a petrol lawn mower. Simple area, no stones.
    I wonder which will be the "best" choice in this price range? Or maybe something else?
    1. https://jokergroup.pl/kosiarka-spalinowa-z-napedem-al-ko-470sp-a-119946,3,1897,4023?.
    2.https: //kosiarka.pl/pl/538-world-grl-530s-hw-4w1-2050000460678.html
    3. https://www.gardenshop.pl/faworyt-kosiarka-spalinowa-pro-mp51-sle-loncin-51-cm-p-7843.html
    Thanks in advance for your answer and help.
  • Wheel bearings and adjustable drive speed matter
    #113 19293262
    klm787
    Level 37  
    Help: 446
    Rate: 950
    It will be difficult, maybe not as an experienced mower, but I see shortcomings in every offer.
    I will not criticize any of the offers because it will not make sense.
    But I will write what to pay attention to, e.g. what other mowers have in their offer, there is no mention of them.
    It is really worth paying attention to the proper construction of the wheels, they must be properly bearing, because one of the first elements that will fall will be swaying wheels, which we will then lose (they will simply fall off).
    The next thing is the drive, in any of the presented offer I do not see the possibility of setting the speed of the mower, they all have one gear, and rather a bit fast. So, as it is presented in one of the offers, the mower mows the grass almost 30 cm in height (although in my opinion it does not even have half of it).
    But if it is actually 30 cm, the presented speed will not cope with it (add a little more moisture, dew will then be wiped off).
    Another thing is the starter.
    Well, it's a convenience, but you have to pay extra for it, at the expense of the starter, it is worth considering other parameters that will be more interesting to us.
    You should also pay attention to the engine itself, the non-proprietary ones are produced under the license of the proprietary ones.
    Lots of info on the web, it's worth reading.
    Almost everyone boasts a double layer of powder enamel, a water drink, a photomontage. This should be the standard these days. In the higher models, the powder-coated steel sheet has also been replaced by the sheet, but aluminum and also powder coated. Can not be ripped off.
    Cutting height adjustment. Such information should not even be in the parameters, this parameter should be the standard.
    The mechanism itself is different, and you can also pay attention to it.
  • Request for a sturdier mower under PLN 1600
    #114 19293586
    Gento123
    Thank you for the extensive answer, I understand that each mower has some advantages and disadvantages.
    Could you introduce a mower that you think would be the closest to what you described?
    In fact, the starter is not a priority and it would be worth investing in a mower with more solid wheels than with a starter, I would like to mention that I would not like to spend more than PLN 1600 (everyone can afford it).
    After work, I will try to look for something else, and possibly throw it into "verification".
    best regards
  • Budget mowers differ only in parts and warranty
    #115 19293626
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1134
    In fact, for the amount you can spend, there is no chance to buy a decent mower (as one previous speaker suggested, especially with an aluminum body. To buy such a mower, you would have to multiply your budget 3-4 times.
    For this budget you will not get anything other than what you indicated in the links. They will only differ in color, decals, and engine model, but of the same class. Besides, it's all the same nothing that distinguishes one from the other, just some irrelevant details.
    With such a purchase, you only need to look at the best possible availability of parts and the availability of reliable warranty service so that there are no problems when problems with the equipment start ...
  • Requesting maneuverable petrol mower recommendations for wet, uneven lawn
    #116 19326182
    whoanybody
    I want to buy a petrol lawn mower up to 2,000 and this is the maximum I would like to spend, ideally if I would close in the amount of 1,800. wet) and there are always a lot of molehills. The rest of the plot is normal weed. I don't know if it makes sense to invest in a drive, although I can see most of them have it now. For so many years I had a Briggs mower without a drive and it never bothered me, but it has already fallen completely and will not be able to resurrect it. I have a lot of trees and shrubs on my plot, so it must be manoeuvrable. Apparently, today's Briggs engines are not the same anymore, but is it really such a crap? Or maybe there is no tragedy and it is worth wading in?
    I was thinking about something like this:
    STIGA Combi 53SQH HONDA 51cm petrol lawn mower
    DRIVE MOWER WITH MOTOR HONDA GCV 51cm 6KM GT
    Maybe you can recommend something good and solid?
  • #117 19326404
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1134
    This is what don't worry that they have "drive". Two, a maximum of three seasons of mowing and there will be no drive, such is the quality and charm of these "drives". :D :not: :shocked!:
  • #118 19328556
    robertkudelka
    Rate: 52
    Polecam
    Naac
  • Choosing a mower with better bagging and power
    #119 19387014
    boruurob
    Rate: 98
    I will connect to the topic. I was 12 years old with the AL-KO 46BR classic mower.
    the time has come for a new one, also with a drive, but more powerful. Budget ~ 1500-3000.
    What should it be better at than the old one? I am already writing what hurt me in her:
    - the basket was only 100% full when it was dry and the grass was short. With wet or long grass, it clogged the mower at the middle of the basket (you had to open the hatch and push the grass to the left side and unblock the intake channel, which is a bit risky with the mower turned on)
    - with dense, large grass it could often choke and go out - you had to mow half the path.
    I wonder what functions, apart from mowing, it should have.
    1.The mower bowl and the knife should be solid - this is due to the quite rocky lawn and dogs that will also dig something out from time to time.
    2. plastic or fabric basket - what are the differences?
    3. RPM control - it's probably moderately useful, huh? although on a few straight lines, especially when it is getting dark or it is raining, you would like to push faster.
    It is important to me that:
    - it was light (I often maneuver and reverse the mower)
    - she was strong
    - it filled the basket to the max and did not clog the inlet channel
    - relatively quiet
    - and as little emergency as possible (so the Chinese scare me a bit)
  • Honda engine premium worth the 500 PLN difference
    #120 19403096
    boruurob
    Rate: 98
    I took AL-KO for the wallpaper first. I chose two mowers that meet my expectations:
    https://alko-garden.pl/urz-dzia-ogrodnicze/pi...iarka-do-trawy/kosiarka-470-sp-h-premium.html - 1.949 - Honda engine
    https://alko-garden.pl/urz-dzia-ogrodnicze/pi...iarka-do-trawy/kosiarka-470-sp-a-premium.html - 1.499 - loncin engine
    as you can see they differ in the engine. Is the 500 PLN for the Honda engine worth paying extra?
The discussion revolves around selecting the best petrol lawn mowers under PLN 1400, emphasizing the need for a drive and engine speed control. Participants express strong opinions on various brands and models, highlighting the reliability of engines such as Loncin and Briggs & Stratton. Recommendations include models from Oleo-Mac, AL-KO, and World, with specific models like the World GRL 460P HW and AL-KO 470 SP-A being frequently mentioned. Users caution against brands like NAC and Handy due to poor quality and lack of spare parts. The importance of engine durability, ease of maintenance, and the mower's build quality are also discussed, with a consensus that investing in a reliable engine is crucial for long-term satisfaction.
