Inexpensive system to start with - Seemple/Homematic/Fibaro and others
Nix 4911 43
Will a low-cost wireless smart-home system based on Seemple/Z-Wave be reliable for a retrofit detached house with radiator heads, sensors, lighting, relays, valves, and cameras?
For this kind of retrofit, the thread points much more to Homematic/CCU than to a cloud-dependent starter system like Seemple/Fibaro: it can work without cloud, supports direct device-to-device communication, and CCU2/CCU3 still support older HM devices as well as HMIP [#18231299][#18232036][#18234281][#18238699] The Homematic IP Access Point is not a full controller: it only pairs/configures devices, connects to the cloud, and does not create scenes or freely control relay outputs, so boiler/relay logic needs a CCU2/CCU3 or a dedicated relay solution [#18235959][#18251849][#18242596] If you mix HM and HMIP, they can coexist on one CCU, but direct HM↔HMIP scenes do not work, so keep one protocol per room when a heating group must react directly [#18234281][#18260878][#18262343] Camera integration exists only in a limited way, and motion detection/RTSP support was described as problematic, so several replies recommend keeping cameras as a separate IP subsystem rather than making them part of the core automation [#18234674][#18235086] Smoke detectors work on their own locally; you mainly program the notification, not the alarm sound itself [#18347882]
  • #31 18255833
  • #32 18260766
    Nix
    Help: 17
    Rate: 189
    Well I understand more now, thanks :) .
    I finally bought the CCU3 control unit( I don't have it in my hand yet) and I will be completing the system, to start with I want to
    to start with, I want to have the heads under control, and let's say a smoke detector.
    Since I have all the radiators (except two) in separate rooms, I'm going to cut costs a bit and buy both the "ordinary - old" heads and the new HmIP, because as my colleague wrote above, it will work well :) .
  • #33 18260878
  • #34 18260982
    Nix
    Help: 17
    Rate: 189
    This may be a silly question-but do I necessarily need a thermostat at all ?
    Can't the heads themselves be used as a thermostat (or in this case a temperature sensor)? Well, you know that there will be some error in the reading, because the head is on the radiator and therefore directly on the heat source, but can it work like that ?
  • #35 18261004
  • #36 18262308
    Nix
    Help: 17
    Rate: 189
    Ok, so some sort of temp sensor/thermostat is needed.
    And is it possible to connect a wall thermostat, e.g. type Homematic Wireless Thermostat HmIP-WTH-2
    or can it be
    Wireless temperature and humidity sensor
    EQ-3 HomeMatic 132095 HM-WDS40-TH-I-2? Will both devices work ( in simple terms) in the same way? Well, it is known that the wall thermostat has a display, but apart from that, the operation in the system of both actors will be the same ?
    You wrote above that
    .... with the HMIP thermostat you will not operate the HM head (and vice versa)...
    But this only applies to the impossibility of direct connections between HM and HMiP actors - but I understand that this could work( actor connections) via connections to CCU 3? Only that such a solution will be a bit less "reliable" in the sense of reliability ? Please explain what are the disadvantages of such a mixed actor connection ?
  • #37 18262343
  • #38 18262358
    gag70
    Help: 65
    Rate: 76
    The lifespan of these smart devices is about 10 years. After that, the manufacturer does not support. Sometimes the manufacturer is no longer there because it went bankrupt or sold out to a bigger one.
    When an ordinary light switch at home breaks down - whether it is a pre-war Bakelite switch or a newer one - you go to the shop and buy a new one. And what happens when an element with mcu and firmware from Fibaro breaks down?
    I have been dealing with ventilation automation for more than 25 years, most of the things available a decade ago and earlier are no longer in circulation and if something breaks, the customer has to replace the cabinet, i.e. the whole system, with something currently offered by the market, which in ten years' time will again be discarded and replaced.
    Have fun with Home Automation and in a few years please remember what I wrote, because time flies fast.
  • #39 18262405
  • #40 18277491
    Kuniarz
    Moderator of Designing
    Help: 371
    Rate: 825
    gag70 wrote:
    When an ordinary light switch breaks down in your house - whether it's a pre-war Bakelite switch or a newer one - you go to the shop and buy a new one. And what happens when an element with mcu and firmware from Fibaro breaks down?
    ...then you remove the FIBARO module from underneath the Bakelite switch and restore the house to a pre-21st century version ;-) .
    It's well known that progress is rapid, devices age, manufacturer support doesn't last forever, but.... one has to have something out of this life, right ? ;-)
  • #41 18277500
    Nix
    Help: 17
    Rate: 189
    All right, but aren't the Homematic components (old, without IP) already about 10 years old today and still supported by the new control unit, because the CCU3 is new?
  • #42 18277559
  • #43 18347697
    Nix
    Help: 17
    Rate: 189
    Finally, I have some components:
    -HmIP heads
    -HmIP heads
    - 2 x SD-2 smoke detector
    - on-off switch
    The actuators are already in the system, whereas I cannot program a simple schedule where I would have a lower temperature at night for several heads.... The Homematic WebUI is, however, a little unclear for me, and rather unintuitive....
    How is it simpler to make such a schedule? And the second question - do you also need to make a program for the "basic" operation of smoke detectors, or will they, in the event of detecting smoke, emit an acoustic signal on their own, and only, for example, the notification needs to be programmed?
  • #44 18347882
✨ The discussion revolves around selecting a low-cost smart home system, particularly focusing on the Seemple system based on Z-Wave technology, and comparing it with alternatives like HomeMatic and Fibaro. Users express concerns about the reliability and compatibility of these systems, especially regarding the integration of various components such as thermostatic radiator heads, motion cameras, smoke detectors, and valve actuators. HomeMatic is highlighted for its ability to operate without cloud dependency and direct communication between devices, while Fibaro is noted for its closed protocol limiting compatibility with non-Fibaro devices. Users also discuss the importance of having a reliable control unit, with mentions of CCU2 and CCU3, and the implications of using older versus newer components. The conversation emphasizes the need for a versatile system that can manage multiple functions effectively while considering future expandability and the potential for technological obsolescence.
