How to control F&F relays on DIN rail with ESP8266?
shady79 2139 22
How can I control 24VDC DIN-rail relays from an ESP8266 as simply as possible?
You cannot drive a 24VDC relay coil directly from an ESP8266 pin; you need a transistor-based driver stage, not just a logic-level converter [#18257695] The simplest practical circuit is a transistor with a base resistor and a flyback diode across the relay coil; one reply also notes that 24V relays can be driven with just a transistor, a 1 kΩ resistor, and a diode, and that this can be built on a small universal board [#18262217] If you want something ready-made, look for 3.3V optocoupler isolation driver modules for single/dual channels on AliExpress, or use an MCP23017 plus ULN2003A as a driver combination [#18260683] [#18260742] Another option mentioned is to skip the external relay hardware and use reprogrammable Sonoff/Shelly DIN-rail-style modules that already include the power supply, ESP, and relay [#18262217]
  • #1 18257677
    shady79
    Welcome,
    I would like to do a lighting control in my house, and to make it look nice I would like to use DIN rail mounted F&F relays. The problem is that they have a 24VDC coil. Controlling from the ESP8266 is a bit of a problem in this case. Can anyone recommend anything on this subject? Some sort of logic level converter? The simplest thing would probably be to give a transistor and use it to drive a relay, but that's a bit of a pain - I'd like to make it as simple as possible. It would probably be best to use a PLC of some sort.
    A grenton system is nice but the price ranges are cosmic ;) .
  • #2 18257695
    jakubek56
    Level 32  
    Help: 202
    Rate: 454
    Even if the coils of this relay were at 3.3V they would still draw too much current from the ESP output.
    The only solution is a transistor.
    Using a PLC instead of an ESP AND a transistor is several tens of times more expensive.
  • #3 18257948
    shady79
    does anyone know any ready-made modules with transistors that could be used? Making such a board isn't too much of a problem, but if there was something ready-made and with e.g. MCP23017 it would be a great thing:) .
  • #4 18260683
  • #5 18260742
    tos18
    Help: 1114
    Rate: 1875
    MCP + ULN2003A
  • #6 18261126
    shady79
    khoam wrote:
    On ali there are single and dual channel modules with optocouplers (necessary in this case) with 3V3 logic control. Images below - you need to search under "Optocoupler Isolation Module Driver" for the 3V3 version.
    Added after 38 [seconds]:
    shady79 wrote:
    e.g. still with MCP23017 would be great:)
    I have not found any such.
    well this is an interesting option.;)
  • #7 18262217
    krzbor
    Help: 43
    Rate: 1073
    To control a 24vDC relay all you need is one transistor, a 1k resistor and a diode for the surge on the relay. I don't know why separate modules are needed. Such a thing can easily be assembled on a universal board. I don't know how you want to build a circuit based on ESP and where to get power for the relay (24V) and ESP (3V). I personally switched to SONOFF modules, e.g. Sonoff Basic. They can be freely reprogrammed and have what you need: power supply, ESP and relay. There are even DIN rail mounts for Sonoff. I recently bought (but haven't installed yet) a Shelly 1 - that's a baby! Fully programmable too, of course, it even has a programming socket soldered in. But beware - the chip has no galvanic separation.
  • #8 18262386
  • #9 18262443
    krzbor
    Help: 43
    Rate: 1073
    khoam wrote:
    Then there will be no galvanic separation either.
    The author writes nothing that he wants to have separation. Anyway, what is the point of separation if you are controlling a relay?
  • #10 18262448
  • #11 18262539
    krzbor
    Help: 43
    Rate: 1073
    khoam wrote:
    To galvanically isolate the 24V relay coil supply voltage from the 3V3 logic.
    Just what for? We short the negatives of the ESP supply (3V) and the 24V supply and connect to the emitter of the transistor. A 1k resistor to the base and then to the ESP, and a relay to the collector, and the other end of the relay to +24V. This is a typical operating circuit (OC) that can cope with different voltages.
  • #12 18262575
  • #13 18262619
    krzbor
    Help: 43
    Rate: 1073
    24V relays usually have low currents. You can give a 10k resistor in the base of the transistor instead of 1k. Then, in the event of a breakthrough, we have (24V-3V)/10k =2.1 mA - this is how much will flow through the uP output protection diode. Such a current will not damage it. Nor will it damage the ESP.
  • #14 18262775
  • #17 18468086
    shady79
    Hi again so as not to start a similar topic let me ask here on the subject of relay control via esp.
    I have connected the mentioned ESP and actually one of its pins via a PC817 optocoupler to the SSR25DD relay http://www.fotek.com.tw/pdf/SSR-DD.pdf and switching on/off via it the 12V circuit with the LED strip works. On the other hand I have a problem getting dimming via a PWM signal. I have easyesp installed on my esp and when I give e.g. pwm 5.1023 it shines at max but when I give pwm 5.500 it also shines at max a fill of 100 shines say 10% less than at max and a fill of 20 does not shine. It can be concluded that the diodes basically do not react to the changing fill of the pwm signal. What do you think, should I look for the cause from the software side or could this signal be distorted somewhere. There are two optocouplers on the way, the pwm signal is generated by esp at 1kHz as standard.
    How to control F&F relays on DIN rail with ESP8266? .
    I wonder if sometimes this R1 is not too small because it looks like in this case the current is limited to 33mA and the current capacity of the port is 12mA so it would be better to use a resistor in the 330-660ohm range to jerk the current from it to the max
  • #18 18468953
    tos18
    Help: 1114
    Rate: 1875
    These relays have a response time of 1ms so the PWM frequency must be less than 100Hz because the relay will not handle it.
    R2 in my opinion is unnecessary.
    Consider ditching the SSR in favour of a good mosfet and driver - they will certainly be faster.
  • #19 18468988
  • #20 18469034
    shady79
    And this ssr is not made on a mosfet?
  • #21 18469104
    tos18
    Help: 1114
    Rate: 1875
    It probably is - maybe even on two of them. which doesn't change things - a response time of 1ms.
  • #22 18469175
  • #23 18469911
    shady79
    can the frequency be changed somewhere in the settings or with a command, because I think I read somewhere that you have to change it somewhere in the source file, recompile the program and put it into esp....
    Added after 8 [minutes]:
    shady79 wrote:
    Can the frequency be changed somewhere in the settings or with a command because somewhere I think I read that you have to change it somewhere in the source file, recompile the program and upload it to esp...
    good i think i have found
    PWM,<GPIO>,<duty>,<duration>,<frequency>
    Added after 44 [minutes]:
    I'll check tonight, but just thinking about it, a time of 1ms is 1/1000s so a frequency of 1kHz is theoretically within that range. Maybe it would be enough to give for example 800Hz?
The discussion revolves around controlling DIN rail mounted F&F relays with an ESP8266, which presents challenges due to the relays' 24VDC coil requirements. Users suggest using a transistor to interface the ESP8266's 3.3V output with the relay, as direct control is not feasible. Recommendations include using optocoupler isolation modules and specific transistor configurations to ensure safe operation. Some participants mention alternative solutions like SONOFF modules and Shelly devices, which integrate ESP and relay functionalities. The conversation also touches on PWM control for LED dimming, highlighting the limitations of SSRs and suggesting MOSFETs for better performance.
TL;DR: A 24 VDC relay coil draws ≈30 mA, exceeding ESP8266’s 12 mA GPIO limit [Espressif, 2016]. “The only solution is a transistor” [Elektroda, jakubek56, post #18257695] Keep PWM under 100 Hz; SSR latency is 1 ms [Fotek, 2019].
Why it matters: Matching drive current and speed prevents burnt GPIOs and flickering loads.
• ESP8266 GPIO current: 12 mA typ., 20 mA abs. max [Espressif, 2016] • F&F 24 VDC relay coil ≈ 800 Ω → 30 mA [F&F Catalogue, 2019] • Fotek SSR-25DD turn-on/off time ≤ 1 ms [Fotek, 2019] • ULN2003A sink per channel: 500 mA, 50 V [TI, 2015] • PC817 CTR ≈ 50 % at 5 mA; use ≤ 330 Ω at 3.3 V [Sharp, 2012]
Can the ESP8266 directly switch a 24 VDC DIN-rail relay?
No. The relay needs ~30 mA while one ESP8266 pin supplies 12 mA typical [Espressif, 2016]. Driving it directly risks latch-up or permanent damage [Elektroda, shady79, post #18257677]
What is the simplest safe driver for one relay?
Use an NPN transistor (e.g., 2N2222), a 1 kΩ base resistor, and a fly-back diode across the coil. This open-collector circuit isolates the ESP from 24 V and costs under €0.20 [Elektroda, krzbor, post #18262217]
Are off-the-shelf 3.3 V opto-driver boards available?
Yes. Search “Optocoupler Isolation Module Driver 3V3” on AliExpress; single- and dual-channel boards cost ≈ €1 each [Elektroda, khoam, post #18260683]
How can I expand to 16 outputs neatly?
Combine an MCP23017 I²C expander with a ULN2003A array. The MCP gives 16 GPIO; the ULN sinks up to 500 mA per channel at 50 V—enough for multiple 24 V relays [Elektroda, tos18, #18260742; TI, 2015].
Is a PLC a better choice than ESP + driver?
A small PLC costs €100–€150, roughly 20× an ESP board plus driver transistors (<€7). Unless you need industrial certifications, ESP-based control remains more economical [Siemens Price List, 2023].
Can I drive a solid-state relay directly from the ESP?
Yes, SSR-25DD’s LED input needs 3 mA; the ESP pin can source that safely [Fotek, 2019]. Forum tests confirmed direct drive works [Elektroda, shady79, post #18263286]
Why does my SSR refuse to dim an LED strip at 1 kHz PWM?
SSR-25DD switches in about 1 ms, so anything above 100 Hz never reaches full on/off. The LED sees nearly constant current and stays bright [Fotek, 2019; Elektroda, tos18, #18468953].
How do I lower PWM frequency in ESP Easy?
Send the command:
  1. serial/tcp → PWM,,,,
  2. Set to 50–100 Hz.
  3. Save. Example: PWM,5,512,0,80 This matches the SSR’s 1 ms response [ESP Easy Wiki].
What’s a better dimmer than an SSR?
Use an N-channel logic-level MOSFET (e.g., IRLZ44N) plus a 10 kΩ gate resistor. MOSFETs switch in < 100 ns, so PWM up to 20 kHz is possible—well above flicker perception [Switching-MOSFET AppNote, 2021; Elektroda, khoam, #18468988].
What could happen if the switching transistor shorts?
A collector-emitter short may dump 24 V into the ESP pin. Without an optocoupler or large base resistor, that over-voltage can exceed the ESP’s 6 V absolute maximum rating and kill the chip [Espressif, 2016].
Three-step build: ESP8266 relay interface
  1. Solder transistor, 1 kΩ base resistor, and 1 N4148 diode onto stripboard.
  2. Tie ESP ground and 24 V negative together; connect GPIO through resistor to base.
  3. Mount F&F relay on DIN rail; wire coil to +24 V and transistor collector. Test with 3.3 V signal—relay clicks reliably [How-To derived from Elektroda thread].
