Configuration of TZ79 with Fibaro Controller for Switch 220V
leszek_b22 750 0
  • #1 18344509
    leszek_b22
    Rate: 10
    I want to use this device in a z-wave system. It will be housed in a ceiling mounted plafond. The plafond will be switched on by a normal (traditional) 220V switch on the wall. The idea is to configure the Fibaro z-wave control unit in such a way that when 220V is applied to the TZ79 device, it immediately switches to the "active" or "on" state, i.e. the contacts of the relay inside the device are shorted, which, of course, causes the bulbs in the plafond to switch on.
    (This combination is due to the construction of the house - wooden ceiling (fire hazard) and I don't want to have any permanent 220V voltage there).
