Which smart lock, switches and thermostatic heads to choose?
jedlikk 999 3
  • #1 18384846
    jedlikk
    Hello forumers.
    I'm making a request for advice regarding smart devices for a flat. I would like to install some smart devices in the flat namely the first device is: A smart door lock, the second device is a touch light switch controlled by wi-fi, the third device is a thermostatic head controlled by wi-fi. If anyone has dealt with such devices please recommend and write an opinion. Unfortunately there are not many such devices to choose from on the Polish market so for any suggestions I will be eternal :D .
  • #2 18388133
    bartekfigura
    Level 30  
    Help: 112
    Rate: 522
    Read about the Fibaro system
  • #3 18388226
    jedlikk
    I am considering the fibaro system as much as possible, however I have one reservation, namely the heads have built-in batteries. I am wondering how the issue of recharging has been solved, is it possible to quickly disassemble and connect to the charger? Or do you have to combine and charge the heads at the heater?
    I've got my sights set on 2 more systems, i.e. Netatmo and Homematic. Reading about all these systems I'm confused and I'm wondering which one will be the most suitable. First of all, I want the system to work with Google Home so that I have everything connected to one system and I don't have to install several applications, each for something else.
  • #4 18399955
    wkasku
    FIBARO heads are screw-on. They are easy to remove.
    I'd post links with examples, but I can't yet :D You can see Robert Nawrowski's material on YT.
    If not, just powerbank and cable ;) .
