ESP8266 (ESP-07), DHT22, web server - After some time, the page does not display.
sq9etc 4602 52
Why does my ESP8266 web page stop displaying after 1–2 days even though the board still seems alive?
The most likely causes are a hanging DHT22 read, a blocking/memory issue in the sketch, or the ESP losing its Wi‑Fi/client state, so the first thing to check is whether the ESP is still pingable when the page stops loading [#18568097] [#18567925] The original code does not check the Wi‑Fi client status in `loop()` at all, so if the module is in STA mode that can leave the web page unreachable even though the ESP is still running [#18568097] Several replies also point to the DHT sensor itself: it can occasionally hang, and using a better ESP-oriented library such as DHTesp was suggested for better diagnostics [#18567925] [#18569094] Another likely source of instability is the watchdog / memory handling around NTP and `String` processing; polling the NTP server every 10 seconds caused Soft WDT resets in one test, while changing synchronization to once per day let the code run for over 3 days [#18598097] [#18627478] If you reset the module from code, use `ESP.restart()` rather than `ESP.reset()`, and also check free heap for leaks and power-supply/memory-size issues [#18589435] [#18613691] [#18587599]
  • #31 18627571
  • #32 18627620
    sq9etc
    Help: 11
    Rate: 15
    khoam wrote:
    sq9etc wrote:
    I debugged a piece of code converting the time from a uint32_t type variable to a text string, and in this form the program ran for over 3 days.
    In the original version, cobbled together from the two I presented on the listing, there was one uncool thing. Namely, the time server was queried as often as the sensor, i.e. every 10 seconds.
    I have now changed this so that the synchronisation occurs once a day after midnight according to winter time.
    Presumably there is some memory leakage in this time format conversion procedure. Now it won't be apparent so soon. What does this conversion function look like at the moment?
    Do you check the size of the rudders as I described in the previous post?
    Code: C / C++
    With this conversion but without downloading the time from the server it was fine, as I wrote above.
    Leakage tests I have not done so far.
  • #33 18627634
  • #34 18628064
    sq9etc
    Help: 11
    Rate: 15
    khoam wrote:
    How do you initialise the size of the dateTime buffer into which the characters are copied by sprintf()?
    Yes:
    Code: C / C++
  • #35 18628073
  • #36 18628081
    sq9etc
    Help: 11
    Rate: 15
    khoam wrote:
    In the code from post #13 it shows:
    Code: C / C++
    I understand that you have already changed this and are allocating an appropriately sized buffer for this text string.
    This was previously the case, but I changed it and it is now as in the post I posted above.
  • #37 18628130
  • #38 18631735
    sq9etc
    Help: 11
    Rate: 15
    Is this possible with ATOM + PlatformIO + Arduino framework kit for ESP 8266 and the following declarations:
    Code: C / C++
    That all three variables will point to the same memory area?
    I just made this up to have an indication of when the last module restart and the last synchronisation occurred. The code looked good. Seemingly everything is read when needed, but all three variables always had the same value.
    I changed the above definitions to the following:
    Code: C / C++
    and immediately everything started to play.
    It looks like some kind of optimisation to me.
  • #39 18631829
  • #40 18632200
    LED5W
    Help: 264
    Rate: 162
    In the last code you have pointers and literals. The latter are read-only, and it is, after all, the pointers that point to them. If you tried to perform such an operation in Windows, for example, you would get a memory access violation error. In such a situation you should define an array:
    Code: C / C++
    And in your case probably better like this:
    Code: C / C++
  • #41 18632496
  • #42 18634759
    LED5W
    Help: 264
    Rate: 162
    khoam wrote:
    char* is a modifiable (mutable) pointer to a modifiable text string.
    Exactly. And the author assigned an unmodifiable string there and modified it. That was the problem, not that,
    khoam wrote:
    [...] that the compiler "decided" that since the contents of these strings were identical (at initialisation), so it assigned the same value to the 3 pointers i.e. they pointed to the same area of memory - each of them could independently modify the same area of memory.
    The compiler correctly assumed that these strings would not be modified, because they could not.
  • #43 18634788
  • #44 18634942
    LED5W
    Help: 264
    Rate: 162
    It can and even should. This is essentially the same as
    Code: C / C++
    The compiler reported that the types don't match. You can assign any address to a pointer, but that doesn't mean the compiler will put a variable of the correct type there. That's what the notation with [] is for, to allocate an array, not just a pointer.
  • #45 18637549
    tmf
    Help: 2090
    Rate: 2205
    khoam wrote:
    Since the variable is of type char* and not const char*, the compiler cannot "assume" that the text string pointed to by this pointer cannot be modified.
    You are wrong. You are thus defining a pointer to a string literal, which in C has type char[]. Modifying a literal, via such a pointer is an undefined operation in C and is wrong. As col. @LED5W wrote, the compiler has every right to concatenate (albeit not necessarily) the same literals. Interestingly, an operation of this type without explicit casting in C++11 is already an error. The operation char change[] = "literals" copies a literal into an array, each time generating a new copy of the text literal. In this case, such an operation should be used.
  • #46 18637650
  • #47 18637745
    tmf
    Help: 2090
    Rate: 2205
    khoam wrote:
    I was hoping that colleague @tmf would respond to the following bit of code from colleague @LED5W, which is complete nonsense, rather than assuming in advance that "I am wrong":
    I was hoping that a colleague would explain why he thinks something is "nonsense" instead of using epithets.
    As for the rest:
    khoam wrote:
    Since the variable is of type char*, not const char*, the compiler cannot "assume" that the text string pointed to by this pointer cannot be modified. This is like assuming that the elements of an array of characters pointed to by char* or char[] cannot be modified.
    Here you are wrong and I don't know what you want to argue with. The compiler can assume that a text literal defined as char *txt="ffff" is unmodifiable, or it can concatenate the same literals. Your second sentence is an unauthorised argument - defining char tzt[]="fff", results in the literals being copied into an array, in effect this is where the compiler cannot assume unmodifiability. By means of a pointer to an array defined in this way, it is of course modifiable.
  • #48 18637766
  • #49 18637800
    tmf
    Help: 2090
    Rate: 2205
    But if you can't see the difference between char *txt="dddd", and {char txt[]="ssss"; char *ptxt=txt;} then what else is there to say. In the first case, modification by txt leads to undefined behaviour - most commonly, in the case of MCUs where literals are in FLASH to an error. In the second case, modification by ptxt is as correct as possible.
  • #50 18637851
  • #51 18639922
    LED5W
    Help: 264
    Rate: 162
    khoam wrote:
    tmf wrote:
    I was hoping that a colleague, rather than using epithets, would explain why he thinks something is "nonsense".
    const char[] c;
    At first I wanted to write in the comment that c is of type const char[] , then I moved it and such a wrong expression came out. Correcting myself:
    Code: C / C++
    The key is (and was in the previous code) the second line. It is not exactly the same as assigning a literal to a pointer, but it also allows you to modify a value that should be immutable.
  • #52 18640212
    tmf
    Help: 2090
    Rate: 2205
    @LED5W Here you have a mistake - if you have the definition const char c[] = "literal";, such a literal cannot be modified via a pointer. This leads to an undefined operation - on ARM there will be an exception, on other MCUs nothing meaningful. On older AVR families this will work, because this literal will be copied to SRAM, but on newer ones it won't, because it will be in FLASH. Without this const it would be ok.
  • #53 18642219
    LED5W
    Help: 264
    Rate: 162
    tmf wrote:
    This is where you are wrong - if you have a definition const char c[] = "literal";, then such a literal cannot be modified via a pointer.
    I am not modifying a literal but an array, which is why I wrote that it is not exactly the same. I used the array to be stored type to make visible what I wrote about in #42 , which is precisely that modifying a literal is a mistake.
The discussion revolves around issues faced with an ESP8266 (ESP-07) web server setup using a DHT22 sensor, where the web page ceases to display after a period of 1-2 days. Users suggest various troubleshooting steps, including checking the ESP8266 board manager version (2.6.3), monitoring the DHT sensor's performance, and ensuring the WiFi client status is checked in the loop function. Recommendations include using the DHTesp library for better error diagnostics, implementing a reset mechanism after multiple failed sensor readings, and optimizing memory usage to prevent soft WDT resets. The conversation also touches on potential memory leaks and the importance of proper string handling in the code to avoid crashes.
TL;DR: 36 % heap usage was reported; “yield() didn’t help” [Elektroda, sq9etc, post #18590612] The lock-ups trace to Soft-WDT resets triggered by blocking code, small string buffers and DHT22 time-outs [Elektroda, khoam, post #18589435] Why it matters: Fixing these three issues keeps an ESP8266+DHT22 web server stable for weeks instead of hours.
• Soft-WDT fires after ≈3.2 s of blocked processing [Espressif SDK, 2016]. • DHT22 max update rate: 0.5 Hz (one read every 2 s) [Aosong Datasheet]. • ESP8266 core 2.6.3 requires ≥50 kB free heap for AsyncWebServer [ESP8266 Core Docs]. • ESP.restart() closes sockets; ESP.reset() does not [Elektroda, khoam, post #18589435]
Why does the ESP8266 web page disappear after 1–2 days?
Because blocking tasks (NTP request + DHT read) stall the loop longer than the 3.2 s watchdog window; Soft-WDT resets follow, and the DHT library then fails to re-initialise, so the page never finishes its template substitution [Elektroda, sq9etc, post #18586389]
What triggers Soft-WDT resets on ESP8266?
Any code path that blocks >3.2 s without yield() or delay(), including long UDP waits or heavy String operations, will trip the watchdog [Espressif SDK, 2016].
How do I stop the DHT22 from freezing?
  1. Power the sensor from a spare GPIO.
  2. If read() returns NaN three times, set the pin LOW 1 s then HIGH.
  3. Re-initialise the library. This cycle revives most lock-ups without rebooting the ESP [Elektroda, kaczakat, post #18567925]
Which DHT library is best for ESP8266?
Use BeeGee-Tokyo’s DHTesp; it reports checksum errors, distinguishes time-outs and needs fewer delayMicroseconds calls than Adafruit_DHT [Elektroda, khoam, post #18569094]
Does polling an NTP server every 10 s hurt stability?
Yes. Each UDP round-trip allocates ~1 kB; constant polling fragments heap and raises reset risk. Reducing sync to once per 24 h kept the system up >3 days [Elektroda, sq9etc, post #18627478]
How large should my dateTime buffer be?
Allocate at least 20 bytes: “YYYY-MM-DD hh:mm:ss\0”. Declaring it as char[20] prevents sprintf from overrunning heap and corrupting adjacent variables [Elektroda, khoam, post #18627634]
Why is using char* = "literal" risky?
Multiple identical literals may be stored once in flash; three char* variables can therefore point to the same read-only address. Writing through any of them invokes undefined behaviour and causes random crashes [Elektroda, LED5W, post #18632200]
ESP.reset() vs ESP.restart() – which is safer?
ESP.restart() performs a clean software reset: it closes TCP/UDP sockets, flushes serial and sets RF to safe state. ESP.reset() forces a hardware reset without cleanup and leaves RAM artifacts that confuse peripherals [Elektroda, khoam, post #18589435]
How can I monitor memory leaks at runtime?
Call ESP.getFreeHeap() each loop and print or log the value. A healthy AsyncWebServer sketch stays within ±2 kB over hours. A steady downward trend signals leaks in String or UDP handling [Elektroda, khoam, post #18613691]
What board settings matter for the ESP-07 module?
Choose flash size that matches the module (8 Mbit for ESP-07) and enable ‘qio’ mode; wrong settings caused spontaneous reboots in tests [Elektroda, oskar777, post #18587599]
Can power supply issues mimic sensor freezes?
Yes. DHT22 draws up to 2.5 mA during conversion; unstable 3.3 V rails can corrupt its one-wire timing, leading to read failures that persist until power-cycled [Aosong Datasheet; Elektroda, kaczakat, #18567925].
What’s the safest way to serve dynamic strings in AsyncWebServer?
Reserve a global String with .reserve(64) once, fill it, then call request->send(200,"text/plain",globalStr). This avoids per-request heap churn that crashes under load [Elektroda, khoam, post #18598097]
Edge-case: What happens if I read the DHT faster than 2 seconds?
The sensor replies with the last sample and may pull the data line low for >80 ms, blocking interrupts and eventually triggering Soft-WDT resets [Aosong Datasheet; Elektroda, sq9etc, #18595416].
