How to implement the 112 dialing system from the panel at the wicket?
rychmar 801 2
  • #1 18814029
    rychmar
    Rate: 13
    I need to make such a system .
    There is to be a button on the wicket with a call panel , when the button is pressed the system is to dial 112 and connect the caller to the emergency number.
    This is the requirement of the fire brigade.
    I have browsed through a lot of intercoms and exchanges; but I have not found a solution to the problem.
    Has any esteemed colleague done something like this and can help?
    I would appreciate a hint.
  • #2 18814115
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    On the wicket is to be a button with a call panel , after pressing the button the system is to dial 112 and connect the caller to the emergency number .
    These are the requirements of the fire brigade.
    Yes, look for example at myCom Farfisa, which is a GSM intercom.
    Greetings
  • #3 18814268
    Jacdiag
    Level 30  
    Help: 116
    Rate: 382
    rychmar wrote:
    This is the requirement of the fire service.
    And do these their requirements have any support in §§ :?: .
