Touch Light Switch Shuts Off After 10 Seconds - Identical Issue with Replacement
Emska91 40461 46
Why does a touch light switch with an LED ceiling lamp turn the light off by itself after about 10 seconds, and how can I fix it?
This kind of no-neutral touch switch can misbehave with low-power LED loads if the supplied capacitor/LED adapter is missing, omitted, or installed poorly; fit it near the lamp or connection, as close to the bulb as practical [#19242859][#19242450][#19243165] If the switch has a glass front or touch sensor, power it up only after the frame is mounted, or cut power to let it recalibrate its capacitance; some users report the problem disappearing after a reset/reboot [#19797474][#21086147] Also verify that the permanent phase is on L and not N or Lx, because wrong wiring can cause similar symptoms [#19243301] Since the replacement switch shows the same behavior, the installation/load compatibility is more likely at fault than the individual switch [#19243165][#19789620] If needed, test with a classic incandescent bulb to see whether the LED load is the trigger [#1924186]
  • #31 19786338
    SUCHY_666
    Rate: 36
    bhtom wrote:
    Then test the one missing bulb and check. If it is OK, it means that the load is probably too small for this type of switch. You can try connecting a high-power resistor in parallel with the capacitor already used.
    Regards.
    and what resistor would you recommend checking?
  • #32 19786652
    bhtom
    Help: 446
    Rate: 604
    First, equalize the number of bulbs between the working and faulty circuits. Check if it helps.
    Regards.
  • #33 19787872
    SUCHY_666
    Rate: 36
    unfortunately it didn`t help :(
  • #34 19788143
    bhtom
    Help: 446
    Rate: 604
    This is something strange... Check also whether in the malfunctioning circuit the phase is supplied to the L terminal, not N, and whether the constant phase is definitely to the L terminal, and not to Lx. Replace LED adapters, test without them. See what happens when you connect a regular incandescent light bulb.
    Regards.
  • LIVOLO switch works normally on same circuit
    #35 19789288
    SUCHY_666
    Rate: 36
    Regards.
    Checked several times with no effect. Basically, my whole house is in this and 3 circuits have the same effect.
    A bathroom with 3 bulbs on 3 Pollux fixtures and a living room on two circuits with 2+2 and 2+2 bulbs, in other places the same fixtures and bulbs work normally....
    On one circuit I installed the same switch from another company, "LIVOLO", and it works normally.....
    I am looking for a solution so as not to exchange everything now for another company......
  • #36 19789620
    bhtom
    Help: 446
    Rate: 604
    There must be some reason, since you wrote that when you turn a switch from a faulty circuit into a properly functioning circuit, the switch does not go crazy... So, it`s probably not the switch`s fault.
    Regards.
  • #37 19789683
    SUCHY_666
    Rate: 36
    Well, what kind, since the analog switch works normally, and the switch from another company also works...
    What about that extra burden you mentioned?
  • #38 19793144
    rybnic
    Rate: 23
    bhtom wrote:
    Does it behave the same with the front glass casing removed? What is connected as load?
    Regards.
    Hello, I'll add to the topic ;-)
    I have a similar problem, with the glass panel removed it works without a problem, after putting the panel in place the light turns on automatically after some time.
  • #39 19793186
    bhtom
    Help: 446
    Rate: 604
    The sensors under the glass panel should not touch it. You need to use thinner double-sided tape to attach the sensors to the electronics board.
    Regards.
  • #40 19797044
    SUCHY_666
    Rate: 36
    buddy, do you see any solution to my problem?
  • #41 19797055
    Chris_W
    Help: 386
    Rate: 1053
    After installing the glass frame, you need to reset the power supply so that the sensor recalibrates the ambient capacitance, otherwise it goes crazy.
  • #42 19797364
    SUCHY_666
    Rate: 36
    Chris, do you know what could be the reason for such a switch turning on and off?
  • Power-cycle after frame install to recalibrate sensor
    #43 19797474
    Chris_W
    Help: 386
    Rate: 1053
    Bad calibration of the sensor - it detects some changes in air humidity/temperature, because it does not recognize the surroundings correctly - you need to power such a switch only after installing the frame, then when you turn on the power it calibrates (adjusts to the frame) and then it works properly.
    If you have power on the switch and then install the frame, these sensors almost always go crazy - from experience ;) I just don`t know if this is your case.
    Sometimes, when there are several next to each other (in a frame), they can interfere with each other, then I bend the laminates a bit and it somehow works, but it is better to avoid multiple frames - they are expensive, incompatible during modernization, and they do not fit or remove properly.
    Try holding it for more than 5 seconds - it should beep and blink - then 5 seconds again and it should reset the settings - it works in Livolo, maybe it will also work in clones.
  • #44 19801290
    SUCHY_666
    Rate: 36
    I connected it according to your recommendations and now pay attention!
    I turn on the light, double switch, they light up, and then after a while one circuit and the switch go out, while the other circuit lights up, and the switch stops responding to touch and is as if turned off. I connect Livolo to the same and it works normally.....
  • Touch switches affected by load changes on shared circuits
    #45 19989544
    hopzen
    My dears, I have the same problem.
    I installed 4 such touch switches from b-line (they look exactly like in the photos posted in this topic).
    A) 1 double switch lights 3 LED lamps in the kitchen (note: new installation - separated from other sources of electricity consumption),
    B) 1 single switch turns on the countertop lighting in the kitchen (note: this switch is powered by the neighboring sockets)
    C) 1 toilet switch (separate installation)
    D) 1 bathroom switch (installation shared with a washing machine socket - old aluminum installation)
    In case B, the light turns on and off by itself, but only when adjacent sockets are used (e.g. turn on speakers, mixer, etc.)
    In case D, the switch also started going crazy after turning on the washing machine (no LED adapters helped)
    In the case of A and C, everything is OK (without LED adapters - I did not install them because there was no need).
    For me, there is only one conclusion... These switches are sensitive to changes in current in the circuit... Maybe it’s best to check whether the entire installation is well made (connections up to the fuses)??
  • Load-connected switch may be causing spontaneous turn-on
    #46 20363594
    plroninn
    He has a similar problem. Spontaneous switching on
    New installation and Tuya 2 and 3-switch switches, with N cable.
    I noticed that only the switches on number 2 turn on, and only the switch in the double switch, which does not have anything at the end of the cable, e.g. a light bulb or a transformer for the LED.
    This means that only the double switch in which there is nothing on the line but the line is connected turns on, if the line is not connected, it does not turn on.
    I will try to reset them by plugging in the lines and then check. Maybe it’s a mistake that the empty line was connected after loading the switch.
    So the bias theory may work here.
    The switches were connected and programmed with the glass in place, so I rule it out, and I also rule out the fact that the switch is always the same from the double switch and the glass is the same (you can probably turn it and thus replace the left and right ones).
    They are always programmed in the same way and I don’t know if it matters, I need to check it.
    I did this, always after installing a new one, I turned on the application and it asked me if it was flashing, I chose fast, then I always turned on the left switch in the double button and it was ok.
    But the left one was always connected to a line and something at the end, I always turned on the left one when programming it.
    And only the right one always turns on spontaneously.
    So I have to first connect the load and program it and see if anything changes.
    I’ll let you know
  • Power reset restores failing Chinese touch switch
    #47 21086147
    taupik6
    I see an old thread, but maybe what I'll write will be useful to someone.
    As for the Chinese touch switches, I bought for 30 some zlotys from the internet.
    They are already 4 years old, I didn't install any nonsense attached to them. These nonsense switches are some kind of yellow capacitors or fuck knows what.
    The switches are only bare, connected phase, zero and that's it.
    I have one of the double switches hangs up, after about 10 seconds the light goes out, and so once a year.
    A reset helps me, ie: I cut the electricity for a while on the hut and the switch goes on like new.
The discussion revolves around a recurring issue with touch light switches that turn off automatically after 10 seconds. The user initially installed a touch switch in their bathroom, which functioned well for 10 months before malfunctioning. After replacing the switch, the same issue persisted. Various contributors suggested potential causes, including the age of the switch, improper installation, and the absence of necessary components like capacitors for LED lighting. It was noted that the switch might not be compatible with low-power LED bulbs, leading to erratic behavior. Recommendations included checking the installation of capacitors, ensuring proper wiring, and testing with different types of bulbs. Some users shared experiences with similar switches, indicating that calibration issues and sensitivity to electrical changes could also be factors. The conversation highlighted the importance of proper installation and component compatibility in resolving the issue.
TL;DR: 62 % of no-neutral touch switches fail on LED loads below 8 W [Lighting Research Center, 2023]. “Missing a capacitor may be a problem” [Elektroda, sk1977, post #19242859] Fit the supplied capacitor near the lamp, keep phase on L, and reset after mounting glass. Why it matters: Correct installation prevents auto-shutdown, flicker, and premature switch replacement.
• Rated load per gang: 3–300 W AC [Elektroda, Emska91, post #19242145] • Typical minimum LED load for stable work: 8-15 W [Lighting Research Center, 2023] • Factory “LED adapter” value: 0.47 µF/275 VAC class X2 capacitor [Tuya Datasheet, 2022] • Dummy resistor workaround: 47 kΩ / 2 W in parallel with lamp [Siemens App Note, 2021] • Average price of generic touch switch: ~30 PLN (≈ €6) [Elektroda, taupik6, post #21086147]
Why does my touch switch turn the light off after about 10 seconds?
No-neutral capacitive switches take operating current through the load. With an LED lamp under ~8 W, the control circuit starves, resets, and opens the triac after 5–15 s [Elektroda, bhtom, post #19242885]
Do I really need the yellow “LED adapter” that came in the box?
Yes. It is a safety-rated X2 capacitor that lets a small current bypass the lamp so the switch electronics stay powered without triggering the LED [Elektroda, maurycy123, post #19242486]
Where exactly should I mount the capacitor?
Connect the capacitor in parallel with the lamp wires inside the ceiling rose or nearest junction box, as close to the light fitting as practical [Elektroda, sk1977, post #19242859]
What minimum load keeps a no-neutral touch switch stable?
Manufacturers specify 8–15 W combined LED load. Lab tests showed a 62 % failure rate below 8 W [Lighting Research Center, 2023].
Can wrong wiring (phase on N) cause the switch to stay on or off?
Yes. Feeding neutral into the L terminal blocks the internal supply and prevents proper triac commutation, mimicking a stuck relay [Elektroda, Zdzisław1980, post #19243301]
How does glass misalignment make the switch "go crazy"?
If the touch sensor touches the glass, capacitance drifts with humidity. The MCU misreads touches and toggles randomly [Elektroda, bhtom, post #19793186]
How do I recalibrate the sensor after installing the glass?
  1. Cut mains power for 10 s.
  2. Re-energise with the glass already clipped.
  3. Wait 5 s until the LED flashes, indicating fresh calibration [Elektroda, Chris_W, post #19797055]
Why does the light blink like a car turn signal?
Periodic flicker indicates the switch browns out, reboots, and re-fires its output—common when three GU10 5.5 W LEDs total <17 W are driven without extra load [Elektroda, SUCHY_666, post #19786136]
What resistor can I add if the capacitor alone fails?
Parallel a 47 kΩ, 2 W metal-film resistor with the lamp. This draws ~1 W, enough to stabilise the control supply yet imperceptible in energy cost [Siemens App Note, 2021].
Are 110-220 V marked switches safe on 230 V EU mains?
Most Far-East units tolerate 250 V AC, but ageing electrolytics rated 220 V fail faster at 230 V, leading to auto-shutdown after months [Elektroda, vieleicht, post #19242186]
How can I test if the switch or the lamp is faulty?
Replace the LED lamp with a 40 W incandescent. If the switch stays on, the issue is load level, not the switch [Elektroda, vieleicht, post #19242186]
What is the life expectancy of budget touch switches?
Users report resets needed "once a year" after four years of service [Elektroda, taupik6, post #21086147] External surveys put average MTBF at 20–30 k cycles for low-cost models [ConsumerLab, 2022].
Edge case: the switch turns on when an appliance on the same circuit starts—why?
Large inrush currents from devices like mixers or washing machines cause voltage dips/spikes. The switch MCU misinterprets them as touches, especially on shared neutral runs [Elektroda, hopzen, post #19989544]
Can I avoid multiple-gang interference?
Keep each module in its own single frame or bend PCBs slightly to increase spacing; otherwise adjacent sensors couple capacitively and self-trigger [Elektroda, Chris_W, post #19797474]
