[Solved] STA380BWF chip, is it possible to use it with ESP32 for internet radio?
cikorittta00 1359 5
  • #1 19272553
    cikorittta00
    I am planning to build an internet radio on ESP32, 1602A 2x16 display. And this is the circuit. There is a datasheet available for it, but I have no idea if it will work with any library available on the internet.
    This chip has I2S and also I2C.
    I have attached a pdf of it
    Is there anyone here who has tried to implement such or similar circuit to ESP32/8266?
    Thank you and best regards
  • #3 19273314
    cikorittta00
    Hello, yes I know there are these projects. I'm more concerned with implementing this chip to play audio (mp3 radio) from this codec.
  • #5 19321140
    cikorittta00
    Hello, after being away for a while I got this circuit working, after connecting the digital signals I had to add a few lines of code. Due to the fact that the audio control is over i2c.
    Anyway, thanks for guiding me to the solution of this "easy" problem
    The topic is closed
  • I2c control code added to make circuit work
    #6 19321143
    cikorittta00
    Anyway, thank you for guiding me to the solution of this "easy" problem
    The topic is closed
    Added after 1 [minute]: .
    The topic is closed
