[Solved] GOSUND SP111 WIFI Socket - Setting Action Thresholds for Power Consumption
snow 8199 4
  • Power threshold automation not triggering on SP111
    #1 19355563
    snow
    Help: 178
    Rate: 201
    I have purchased a GOSUND SP111 WIFI socket. I wanted to use it to power a device so that if the power consumption drops below, say, 100W the socket will disconnect that device from the mains.
    To do this, I set the following condition in the application under Intelligent -> Automation :
    When device status changes - Smart Socket -.> Power -> Less than 100W -.> Run the device -> Smart Socket -.> Switch -> OFF .
    Unfortunately when the power consumption drops below 100W the socket does not cut off the power. No matter whether I set the restriction to an intake of more than some watts or less, the socket always remains switched on. Also setting the condition from the current consumption is the same, it still powers the device.
    The socket control from the phone works. It measures current consumption, power consumption, mains voltage. It can be switched on and off from the app.
    I tried setting this up in three different apps (Smart Living, Tuya and in the manufacturer's app GOSUND), but in none of them was I able to get it to work.
    Am I doing something wrong or is this socket rather faulty?
  • #2 19363284
    snow
    Help: 178
    Rate: 201
    Does no one really know? :(
  • #3 19365333
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    Yes, I do use such gadgets sometimes. However, the first thing I do is change the soft in them to Tasmota, Esphome etc.
    So unfortunately I can't help.
  • #4 19365742
    snow
    Help: 178
    Rate: 201
    I changed the plug for another manufacturer and it is OK. Apparently there was something wrong with that one.
    I set the schedule as in the first post and the unit is switched off as the power drops below a certain threshold.
  • #5 19368915
    snow
    Help: 178
    Rate: 201
    To be closed
