Delayed automatic switching off of the socket when a certain voltage is detected.
konradi 930 0
  • Need delay reset on brief low-power dips
    #1 19793406
    konradi
    I have this problem, I can't cope with setting the automation in the nous socket in the app. I.e. I want to set to automatically turn off the speakers after a certain time when the consumption of amps or watts changes below the set. And yes, I was able to set this up, but the application, even though it momentarily detects a lower consumption than set, starts counting the delay time set by me and turns off the speakers, even though music is still playing from them. It is known that when the music is playing then there is consumption, but sometimes you make a short break (1min - 3min) and then there is no consumption and return to listening, and I want that after detecting a lower consumption than set for example after 10 minutes, the speakers turned off. I do not know if it is possible for the application not to detect these breaks of 1 - 3 minutes, but for the automation to switch on after 10 minutes of lower than set consumption.
