Smart socket Gosund SP111 - Beep every 10 min: Causes (Voltage, Wi-Fi, Software)
Smoku_Luki 1569 7
  • #1 20308786
    Smoku_Luki
    Level 4  
    I have a question regarding the Smart socket Gosund SP111.
    It seemingly works fine but every 10 minutes or so it clicks / makes a sound like that when switched on / off.
    I have several of these sockets and they all make this sound.
    What could be the cause (voltage, Wi-Fi, software) ?
    They did not do this before - only for a while.
  • #2 20309049
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    It's a pity you didn't insert a recording of this sound, I have these sockets and they are so far quiet ....
  • #3 20309256
    Smoku_Luki
    Level 4  
  • #4 20309580
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    It looks like it resets or loses power for a fraction of a second , do you have the original software ???
  • #5 20309642
    Smoku_Luki
    Level 4  
    MikeC wrote:
    It looks like it resets or loses power for a fraction of a second, do you have the original software ??
    Yes original - I have not fiddled with anything - I am moderately familiar with such things ;)
    I am also chatting to Gosund tech support but so far they have not given a reason.
    I have sent them the IP addresses of the plugins - the technicians are to check the cause.
  • #6 20309850
    MikeC
    Level 32  
    Help: 201
    Rate: 972
    Write back what they answer ...
  • #7 20339038
    bart.m
    Hi, I have had the same problem on two plugs for about a week now. The plug switches off and on for about half a second (you can hear the relay click) in cycles from 1 min to about 2 minutes. Any advice welcome…
  • Router restart, app cache clear, and device reset steps
    #8 20341835
    Smoku_Luki
    Level 4  
    This they replied to me but I haven't tried it yet - lack of time....
    Hello, thank you for waiting. I received an update from the technical team. They recommended the following.
    1. Restart your router and clear the cache in the app.
    -Open the app, click ME> Click Settings > click "Clear Cache" at the bottom
    2. remove the device from the app.
    -To remove the device from the app: Click the device name -click the edit sign (upper right-hand side). Go to the bottom of the screen and click Remove device "Disconnect -wipe data".
    3. Lastly, reset it to connect again. Simply press and hold the power button (for about 10 seconds). The smart plug will blink slowly for AP mode and fast blinking for Easy mode.
The discussion revolves around the Gosund SP111 smart socket, which has started making a clicking sound every 10 minutes, indicating a potential issue. Users speculate that the cause may be related to power fluctuations, Wi-Fi connectivity, or software problems. One user reports that the socket seems to reset or lose power briefly. The original software is confirmed to be in use, and the user is in contact with Gosund tech support for further assistance. Recommendations from tech support include restarting the router, clearing the app cache, removing the device from the app, and resetting the socket to reconnect it.
