[Solved] Can Hormann HET24 Relay Interrupt Continuous Voltage Circuit for Electrolock?
qba_22 846 1
  • Question about whether HET24 contacts can interrupt a live circuit
    #1 19604151
    qba_22
    Rate: 38
    Good evening
    I've already tinkered with the subject of the hormann het24 as a relay for the wicket electrolock.
    As I have punched a hole in the wall and already have space I am trying to connect it.
    I have an electric gate with a hold. There is voltage - it is closed. The voltage fades the pulse opens it and it stays open until the wicket is closed again.
    And the question is whether the contacts of this relay when triggered will break the circuit or do they just act as a temporary circuit closure? in other words if there is voltage on the contact all the time will it break when triggered?
    thanks for your time and cheers
    Kuba
  • #2 19609327
    qba_22
    Rate: 38
    This is how it can be connected.
    Power supply + 2 cables to the contacts of the control panel (the one you have at home) which are responsible for the operation of the electrify
