[Solved] How to Control HL-52 v1.0 Low Level Relay with ESP8266 NodeMCU V3 and Blynk?
polandlp 1839 6
  • D0 defaults low, so relay is active on boot
    #1 19617916
    polandlp
    Help: 6
    Rate: 83
    Hi, I recently got carried away with a SMART power strip project so I bought a nodemcu V3 and a low level relay module exactly HL-52 v1.0 on the Node I installed the Blynk software and now how to control this relay? Because it is a low level relay, there is a problem with it, when I connect it to pin D0 the strip is immediately on and when I connect it, it turns off, although on the application the switches are still off. What should I do now?
  • #2 19618126
    tomjed
    Help: 81
    Rate: 303
    And some program...? What have you 'uploaded' to nodemcu?
  • #3 19618272
    polandlp
    Help: 6
    Rate: 83
    Pure Blynk software this older version. But it doesn't have to be Blynk I just want it to be controllable via my phone without connecting to a special wifi but if it can't be done otherwise that can be too. My relay board only does not switch if it is connected to a 5v supply so could I use a transistor from 3.3v to 5v and that would take care of it ?
  • HL-52 relay must be powered from 5 V
    #4 19620097
  • #5 19620272
    polandlp
    Help: 6
    Rate: 83
    khoam wrote:
    what I meant was that when I connect the cable to e.g. V5 then nothing happens on the board and when I connect it to pin D2 where 3v is, then it switches over.
  • #6 19620396
  • #7 20171935
    polandlp
    Help: 6
    Rate: 83
    I had to buy a new module
The discussion revolves around controlling the HL-52 v1.0 low level relay module using an ESP8266 NodeMCU V3 and Blynk software. The user encounters an issue where connecting the relay to pin D0 causes it to turn on immediately, while connecting it to pin D2 results in it switching off. Responses suggest that pin D0 (GPIO16) defaults to a high state on startup, which is unsuitable for this relay, and recommend using other pins like D2, D3, or D5-D7. It is also noted that the HL-52 relay requires a 5V power supply and operates on a low state trigger. A solution involves removing a jumper to separate the power supply for the relay and the input track, which should be powered from 3.3V. The user ultimately had to purchase a new module.
