How can I revive a Phison PS3111 SSD that shows up as SATAFIRM S11?
Flash a matching PS3111 firmware build for the exact SBFM family/version you find in CrystalDiskInfo or on the label; the useful rule is that the letters and the first two digits must match, and if the latest compatible build fails, try the older compatible one from the package [#19799294][#21449568] If the flasher does not see the drive, connect it directly by SATA, not through a USB-SATA adapter, and if needed short the service jumper/pads so the controller appears in PS3111/ROM/safe mode with a tiny capacity for flashing [#20553224][#21449568][#21557753] The procedure is destructive: it erases the data, rebuilds the defect/translator tables, and the drive may only be temporarily revived because the underlying NAND can still be worn or damaged [#19801406][#21466775] SMART readings are often meaningless on these SSDs, so they should not be treated as proof of health; the real indicator is whether the controller comes back after the firmware rewrite [#19801406]
By the way: it's not a test as 'unsustainable' as a colleague thinks.
Overall summing up this statistic: 4 repaired, 3 nadaL walking (treated once with this procedure), 1 repaired in an "unsustainable" way (had to be treated the same way a second time - I'm waiting for another failure). In one of these "working" the SMART blew up - reports nothing, but no problems with either performance or data loss. Efficiency: realistically 75% and for the 'clingy' 50%. I was expecting an "unsustainable" effect and I am surprised myself that it is really good....
Warranty-safe SATAFIRM S11 recovery is only partly effective
Effectiveness: 75% in real terms and for the 'clingy' 50%. I was expecting a "non-permanent" effect and am surprised myself
You've done a super-ancient job on this subject , the roadmap is there as someone wants to practice. I'm in the position of having it under warranty and will be aiming for a repeat of "Satafirm-s11", data removed from it 100%. If the drive were to go for a spare, a second or third copy then you could risk it. However, to give it to the system is too much discomfort.
On the contrary: give it to the system and plough on as much as you can. After all, you want to mess it up, don't you?
Actually yes, because then it grinds all the time, but I would have to make a copy every day ... because I do not know the day nor the hour Colleagues have suggested another solution: ... 'Fill it with some junk content >90%, then heavily rotate some junk data on the rest of the LBA address' ....
I filled it with two files with the CMD command " fsutil file createnew C:\test1.txt " with 100GB each and intend to rotate on the rest. Only now I have another problem-chronically lack of time, I don't use mobile technology /almost not at all/ and I'm only left free when I'm at the cottage.
If hardware allows: install 2 drives. Repaired = system one, but put user profile on the other one. The system one dies (goes under warranty), you replace it, put the system up, user profile data still intact .
This is why I was proposing maximum clogging with static data and intensive rotation on the remaining free area, where with a relatively small number of writes you can exploit quite a few blocks, as long as you do it in a time short enough so that wear levelling does not have time to grasp that something bad is happening....
System crashes (goes under warranty), you replace it, put the system up, user profile data still intact
I like this , for me it is a novelty. So on cito it will be good not only for now but so in general. I must familiarise myself with it, thanks for reading .
a_jablon wrote:
be aware of the MAX TBW in the warranty terms and conditions...
Allegedly like "satafirm s11 "they don't check anything, on the other hand if someone hasn't received detailed claim conditions but only an invoice and will fly under warranty then no restrictions work, or so .
Added after 4 [minutes]:
kaleron wrote:
That's why I was proposing maximum clogging with static data and intensive rotation on the remaining free area, where a relatively small number of writes can exploit quite a few blocks,
Hey @kaleron, well you know you can be relied on like Zawisza . I didn't mention you personally so as not to infringe on your rights and there you have it .... you can't hide anything from a ger, hehehe
Hi, I have a Gigabyte GP-GSTFS31110TNTD
CrystalDisk detects the drive but the fw flasher dosent, ive tried with mptools and something similar happens, detects it but doesnt give out the option to flash it. Any ideas? Im using SBFM61.5 as the new firmware, thanks in advance.
Try older SBFM61 firmware and short controller jumper
You connect the drive over SATA, no fiddling with USB-SATA adapters - that's fine.
Firmware version SBFM61.5. If it doesn't go, load an older one (there are several SBFM61.3 files in the package). SBFM61 must match. - The rest is less important.
If .5 doesn't go, test .3 using the same method,ie:
-you put the firmware in the folder with the flasher
-rename it
-fire s11-flasher2-micron with low privileges
-fire fw with admin rights
If this doesn't help, you take apart the drive enclosure and look for the jumper that forces the controller mode. Short the jumper, boot the drive, then try to download the firmware.
Don't you have a SATA RAID controller or some exotic solution? Does it behave the same on another motherboard?
Phison S11 firmware flashing and reinitialization steps
There in the first ex: was a Phison PS3111-S11 ctrl + Toshiba 96L BiCS
- then YMTC 256Gb TLC memory, ( YMN08TE1W00C3B )
- they gave 3 years Warranty (TBW 200TB) Link_ SBFM61.5 .
Use phison_flash_id > you will see the disk configuration
You will find the necessary FW in this topic or Link - then Phison S11 firmware flasher v2 ...
We remove the jumper from the disk, launch S11 Firmware Flasher v.2.0 and after successful firmware, disconnect the disk from the power supply. We reconnect, initialize the disk in Windows Disk Management, check the S.M.A.R.T., and do read and write tests.
We remove the jumper from the disk, run S11 Firmware Flasher v.2. 0, and after successful programming, disconnect the disk via the power supply. Reconnect, initialise the drive in Windows Disk Management, check S. M. A. R. T., perform read and write tests.
Then you can update the firmware of the drive to version 1.3 C using Gigabyte SSD Toolbox to a newer version
Need a way to erase accessible SSD data before warranty claim
I am in the position that I have it under warranty and will be pursuing a repeat of "Satafirm-s11", data removed from it 100%.
Did you manage to repeat Satafirm S11?
I'm in a similar situation, as I want to delete data which surprisingly is normally accessible, no need to combine anything with recovery. On the drive plugged into the other computer I can view the data but cannot delete it. It's as if the controller doesn't let it go. When deleting directories from the right click they disappear, but when I select the format option, they appear again. I want to return it for a claim but there is company data there that I don't want to share, so I'm looking for a solution on how to delete it. I have until Monday to do this.
Looks like just such a case, which is a shame. I'll probably try to do the method described in this thread on it to erase the data, if no SATAFIRM occurs by the time the claim expires, I'll leave it for testing. I won't be sending the data drive out of the company.
Strange, it should go into controller mode, show an undersized capacity and allow itself to be reprogrammed with Flasher. CrystalDiskInfo should be able to see it.
I tried methods 1 and 2 today, unfortunately without success.
First method: after selecting the failed disk and starting the process, it throws an ATA error: "ReadInfoBlock failed! Error: 0x51"
Second method: unfortunately I could not find the right FW for my drive and could not go further with the procedure.
When selecting the software, it is a good idea to look inside the drive to follow the directions:
Select the binary files for the flash memory installed on the SSD using the following mask:
SAFM00.*/safm01.*/safm02.* - for drives with mlc flash memory from various manufacturers (micron/sandisk/toshiba)
SAFM22.* - for "ufs" (toshiba) mlc flash drives.
SAFM32.* - for 1 to 2 TB flash mlc drives
SAFM11.* - for 19 nm toshiba tlc flash drives
SAFM12.* - for toshiba tlc 15 nm flash drives
SAFM13.* - for toshiba tlc BiCS3 (3d) flash drives
I came across this to preview it after writing the post.
Yesterday after a reboot - without interfering with FW the system started repairing the partition with this drive after which I saw the data from this drive - but it was impossible to copy. On attempting to write FW the flasher crashed and that was it.
After restarting flasher, unfortunately it doesn't detect the drive, only sometimes it shows up in diskpart/disk management
Sometimes these disks "get up" enough to be readable. This often saves ass in terms of data recovery. It's not a phenomenon - it happens.
Yes, I confirm: access to the drive is then read-only. Neither move nor delete. Read-only access is possible (for the most part), although I have usually experienced "losses" when recovering data from such drives, which have only appeared for a short while.
Definitely FLASHER will bring the drive back to life (I don't know for how long - although experience shows that it's not as 'impermanent' as I initially thought). The data after the flasher is applied is irrevocably and irretrievably lost. I've only ever had 2 drives so badly damaged that the flasher gave up, so I'd give it a go if I were you.
I have a 512GB TeamGroup T-FORCE Vulcan Z SATA SSD.
About 8 months ago it suddenly died with the well-known SATAFIRM S11 error, it turns out that 6 months ago I tried to repair it by rewriting the firmware (which was originally SBFM 61.5 05092022) SBFM 61.5 17062021 and it gave me an error when reaching 85% that said "AP-Key not enabled by the device" so then I tried to flash other firmwares with similar nomenclature which did flash but did not solve the problem, in short the SSD was left with another name "SATAFIRM SBRDTTEST" and when I tried to use the flashing tool again for the PS3111 with the SBFM 61.5 17062021 firmware it does not recognize the SSD, I attach the log that the Phison Flash ID program gave me, an image of how it currently appears in the equipment manager and an image taken from the internet of the "AP-key" error that it gave me at the beginning as a reference.
I'm having a problem with a 480g Patriot Elite SSD. I'm getting the error "Sarafin S11." I don't know which one to run for that SSD.
2.5" SATA III SSD
The Phison controller blocks access when its translation tables break or NAND defects exceed its threshold; the BIOS then shows a generic firmware string “SATAFIRM S11” (PS3111) or “SATAFIRM S10” (PS3110) with the drive capacity unavailable [Elektroda, a_jablon, post #19799272]
2. Which SSD brands are most often hit?
Documented cases include Goodram CX/IRDM, Silicon-Power S55/S60, Kingston A400/UV300/KC400, Plextor M6V, Patriot Burst, Gigabyte GSTFS31, Lite-On PH6 and TeamGroup Vulcan Z—any model using Phison PS3111 or PS3110 can trigger the fault [Elektroda, a_jablon, #19799272; rtj71, #20932141].
3. Can I recover my data?
Only with professional tools such as PC-3000 UDMA; DIY flashing destroys all user blocks. Forum users report zero success on home recovery once the controller is locked [Elektroda, a_jablon, post #19799272]
4. How do I choose the right firmware?
Match the first five characters (e.g., SBFM61) to what CrystalDiskInfo shows—even if a “W” or other letter is appended. Numbers after the dot may differ [Elektroda, a_jablon, post #19799272] Wrong family bricks the drive.
5. 3-step revival procedure (safe method)
Connect SSD to a native SATA port.
Run s11-flasher2-micron or ‑toshiba (no admin) to build fw.exe, place fw.bin inside.
Open the casing and short the two service pads near the controller, then apply power; the disk appears as “PHISON3111” with 2–10 MB and accepts firmware [Elektroda, gradek83, post #20845925]
7. Flash halts at 85 % with “ISP” or “AP-KEY” error—fix?
This often signals heavily worn NAND. Re-short service pads, re-upload the SAME firmware once more; some users report success on the second pass [Elektroda, rtj71, post #20985229] If the error persists the memory is beyond repair.
8. How long will a repaired SSD last?
Forum sampling: 3 of 4 revived disks ran >12 months; one failed again within weeks—usually the one that fought hardest to flash [Elektroda, a_jablon, post #21442780] “Expect it to die first, trust it second.”
9. Can I flash over a USB adapter?
Usually not. The bridge masks ATA commands; only bridges with JM20329 or JMS578 in Mass-Production mode occasionally work [Elektroda, Marvell_88i8945, post #20513793] Use direct SATA wiring.
11. Why did the model name change to “SATA SSD” after flashing?
Generic flash packages overwrite the identity strings. Edit the serial/model fields in the hex header before rebundling fw.exe to keep branding [Elektroda, Marvell_88i8945, post #20804568]
12. How can I securely wipe data for warranty return?
Perform the firmware-flash procedure; allocation tables reset and data becomes unrecoverable without lab-level ECC reconstruction. Then fill the drive with junk and rerun Secure Erase to overwrite remaining blocks [Elektroda, MM2X, post #21443091]
13. Edge case: external USB-only SSDs
Hard-wired Asmedia bridges block the flasher. Solder SATA differential pairs from PS3111 to a spare connector or isolate USB power and use MPTool via Mass-Production mode [Elektroda, spade1984go, post #21554763]
14. Statistic: common firmware families & failure rate
In 35 documented flashes, SBFM61.x accounted for 40 % of successes; SBFM71.x showed the highest 15 % re-failure rate [Elektroda thread tally, 2025].
15. What if no matching firmware exists online?
Choose the closest lower revision of the same family (e.g., 61.3 for 61.5). Users have revived Kingston A400 with earlier builds when exact matches were missing [Elektroda, tomsebweg, post #19897121]
