SATAFIRM S11 or How to bring an SSD to life on a Phison PS3111
a_jablon 198762 195
How can I revive a Phison PS3111 SSD that shows up as SATAFIRM S11?
Flash a matching PS3111 firmware build for the exact SBFM family/version you find in CrystalDiskInfo or on the label; the useful rule is that the letters and the first two digits must match, and if the latest compatible build fails, try the older compatible one from the package [#19799294][#21449568] If the flasher does not see the drive, connect it directly by SATA, not through a USB-SATA adapter, and if needed short the service jumper/pads so the controller appears in PS3111/ROM/safe mode with a tiny capacity for flashing [#20553224][#21449568][#21557753] The procedure is destructive: it erases the data, rebuilds the defect/translator tables, and the drive may only be temporarily revived because the underlying NAND can still be worn or damaged [#19801406][#21466775] SMART readings are often meaningless on these SSDs, so they should not be treated as proof of health; the real indicator is whether the controller comes back after the firmware rewrite [#19801406]
  • Check CrystalDiskInfo software field and firmware version
    #151 21508777
    a_jablon
    Help: 338
    Rate: 837
    Mate, read this topic thoroughly, you will know how to proceed.
    I'm sorry, however you haven't made the minimum effort to check anything and are relying on us here without basic knowledge of your drive to work miracles.
    For starters, CrystalDiskInfo, check what appears in the "software" field, you will know what to do next.
    Not sure what's going on? You take a look at at least post #47 (page 2) from this topic and see what it should look like, then check on your own drive.
    You will know the firmware version, the firmware_ps3111 + S11_flasher package from post #1, the path of action "VERSION 2: re-enforced FIRMWARE upload"....
  • Seeking a reliable way to trigger SATAFIRM S11 mode
    #152 21510281
    MM2X
    Rate: 618
    As I wrote earlier, I managed to get my Gigabyte 240GB SSD back on its feet using the procedure outlined by my colleague @a_jablon. However, the main goal was not to save the drive (it's under warranty) but to be sure that I would erase the data irretrievably (well, maybe 99% sure).
    So I started to pasture it by saving/deleting/transferring data to full capacity, this is what I've been doing for the second month with a frequency of every few days and for the hell of it it won't kick out, I'm waiting like salvation for "satafirm s11" (to complain) and it's as good as gone.
    Have any of you perhaps, in the course of your practices here, encountered a trick that restores "satafirm s11", just for the heck of it, not by accident. I know it sounds silly, because here the repairmen themselves, do not spoil ;) .
    File list on a computer screen showing various files with names and sizes on a disk. .
  • #153 21510291
    a_jablon
    Help: 338
    Rate: 837
    Sadly not, my experience confirms that after a repair (and firmware uplift) the damn things go absolutely fine, as if there was never a problem....
  • #154 21510484
    MM2X
    Rate: 618
    a_jablon wrote:
    after repair (and firmware uplift) cholera some are running completely correctly, as if there was never a problem...
    And as they die after repair do you have any time statistics?, you set up the topic two years ago, are there any that are already hulking 2 years?, because if so I'm left with just the angle ;) .
  • Stress-test repaired SSDs after firmware update
    #155 21510529
    a_jablon
    Help: 338
    Rate: 837
    In total, I repaired about a dozen units, of which I have 4 left with me. Of these 4 units, one died quickly, but it was the one that caused the most problems during resuscitation. The other 3pc - with the latest firmware (raised to the max) - are still running today, in "low-intensity" applications.
    Efficiency: freely 75%...
    What needs to be done: catapult it as far as possible... Put the system on it, torture it. Data to another drive, of course.
  • #156 21511251
    MM2X
    Rate: 618
    a_jablon wrote:
    What you need to do: catapult it as much as possible.... Put the system on it, torture it. Data to another drive, of course.
    Ok, thanks.
  • Reflashed CX400 with 61.5 to revive S11 drive
    #157 21519528
    danieel1987
    Hey All,
    I just wanted to express my gratitude for the original guide. I ran into a CX400 512G2 in a SATAFIRM S11 state while I was browsing the used hardware market, the drive originally had only 5TB lifetime writes. Then I found this guide and managed to buy the drive for a little money. Originally it had SBFM 61.3.X firmware but shotrly after reviving it it went back to dead S11 state. Then I reflashed it with the version 61.5 and since then it seems to be working fine.
    Honestly I don't really expect any long life from the drive, but it will be fine as long as it lives. Nothing important will be stored on it anyways.
    So thanks again!
  • #158 21520086
    danieel1987
    Oh well, it went back to S11 state again :/
  • Asking which SBFM firmware versions are compatible
    #159 21529971
    RazorUA
    Good evening gentlemen! Please let me know what maximum firmware I can install on my SSD GOODRAM CX-300 : 120GB (SSDPR-CX300-120).
    Phison flash id:
    v0.785a
    Drive: 1(ATA)
    OS: 10.0 build 19045
    Model : SSDPR-CX300-120
    Fw : SBFM11.2
    Firmware lock supported [09 00 01 03].
    P/N : 511-180831241 , SBSM11.1
    S11fw: SBFM11.2, 2018Aug 8
    Bank00 : 0x98,0x3a,0x98,0xa3,0x76,0x51,0x8,0x14 - Toshiba 15nm TLC 16k 128Gb/CE 128Gb/die
    Controller : PS3111
    Is it worth installing from such firmware versions? SBFM61.2, SBFM61.3, SBFM91.2?
    Thank you!
  • #161 21537490
    puertopcpro
    Estoy buscando el firmware SBFKq1.3 agradeceria si alguien lo tiene si lo pudiera compartir con la comunidad porfavor, no lo he encontrado en ningun lado ese firmware :)
  • #162 21545756
    melanchel
    Help: 154
    Rate: 380
    SBFKq1.3 q ? drive is kingston?
  • #163 21548647
    puertopcpro
    >>21545756 Yes!, its an Kingston A400
  • PS3111 SSD reports 0 MB with Toshiba BiCS4 NAND
    #164 21554763
    spade1984go
    Hey guys
    I'm having an issue with a PHY 480GB external SSD. It's unfortunately hard wired with an Asmedia USB3 controller, no SATA options and the following info is available:
    v0.844a
    Drive: 3(USB)
    OS: 10.0 build 26100
    Model: PS3111
    Fw : SBRM09.0
    Bank00: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank01: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank02: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank03: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank04: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank05: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank06: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank07: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank08: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank09: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank10: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank11: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank12: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank13: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank14: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Bank15: 0x98,0x3c,0x98,0xb3,0xf6,0xe3,0x8,0x1e - Toshiba 96L BiCS4 TLC 16k 256Gb/CE 256Gb/die 2Plane/die
    Controller : PS3111 in Rom Mode
    My problem is, how do i flash firmware onto it because the S11-Flasher does not recognize the drive (being USB)
    Any thoughts?
    Close-up of an open SSD circuit board connected via USB cable, with visible chips and a red LED indicator.
  • #165 21557753
    kaleron
    HDD and data recovery specialist
    Help: 963
    Rate: 2344
    It is possible that the USB-SATA bridge is interfering with the communication. You could look for documentation and try soldering a wire between the bridge and the controller for a direct connection over SATA.
    Kaleron sp. z o. o.
    Hirszfelda 4/18, Jelcz-Laskowice, 55-231 | Tel.: 713XXXXXX (Show) | Company Website: https://kaleron.pl
  • #166 21557848
    _bluebird_
    Level 4  
    >>21557753 a bit risky to advise soldering wires between SSD chips by an inexperienced user. And what if after your advice a user breaks something ? Will you repair the drive under warranty ?
  • Repairing a defective SSD carries no guarantee
    #167 21557853
    kaleron
    Help: 963
    Rate: 2344
    On what guarantee? Do you even know how to read with understanding? Have you noticed what this topic is about? We are talking about a drive that is defective. If someone wants to repair it for the sake of repairing the drive itself, that means they apparently feel they can. Don't measure everyone by your yardstick. However, if he finds it beyond him or something goes wrong, then as he had a damaged disk, he will continue to have it. If you had read the whole thread carefully, you would have noticed that the repairs described in it don't always succeed, and even if they do, they don't always last. After this type of repair you can't have confidence in the drive anyway. But I get the feeling that I'm asking too much of you.
    Kaleron sp. z o. o.
  • #168 21587911
    spade1984go
    >>21557753
    I don't have a problem soldering, as I have around 20 years of experience with this (microsoldering\hotair, etc). But if i go that route I imagine I'll need an actual SATA port and wires that extend from the controller to it, bypassing the bridge all together? And will this work without additional components?
  • Clip directly to wires and isolate the bridge
    #169 21588044
    kaleron
    Help: 963
    Rate: 2344
    You don't need a port - just clip directly to the wires. That way you avoid signal loss at the connector. If you can't find documentation, try identifying the two differential pairs between the controller and the USB-SATA bridge. You can catch the ground where you are comfortable. If you're going to have communication problems isolate the bridge so it doesn't get power, as its activity can interfere.
    Kaleron sp. z o. o.
  • Phison PS3111 firmware mismatch and boot instability
    #170 21591007
    quaigonjil
    I have such a drive and only one firmware. Has anyone tried to upload another firmware to such a drive? With me so far the symptoms are that the drive boots sometimes even in 20 times always with a different frequency.
    SATAFIRM S11 or How to bring an SSD to life on a Phison PS3111 .
    I have re-uploaded SBFMY1.3 but the drive reports as a SATA SSD and the capacity is 512GB and it is rather not this firmware. Before uploading the firmware it appeared in the s11-flasher that the SBRM09.0 firmware was recognised and there is no such firmware.
  • #171 21604078
    Swerybary
    Would anyone have a FW: SBFMLA.5, for the CL100 drive from Goodram? Unfortunately the package from usbdev.ru does not have this particular one.
  • #172 21604089
    pidar
    Help: 1569
    Rate: 3590
    Swerybary wrote:
    Has anyone perhaps FW: SBFMLA.5, for the CL100 drive from Goodram? Unfortunately the package from usbdev.ru doesn't have this particular one.
    It doesn't have to be the same one. Please specify what kind of memory is there?
  • Goodram CL100 G3 480GB identified on PS3111
    #173 21604663
    Swerybary
    >>21604089 >>21604089 .
    It is exactly the Goodram CL100 G3 480GB
    Model : SATAFIRM S11
    Fw : SBFMLAW5
    Firmware lock supported [FB 00 01 02].
    Drive unlocked [FB 00 01 03]
    P/N : 511-230321273 , SBSMLA.5
    S11fw: SBFMLA.5, 2022Jul19
    S11rv: MLA.5-23
    Original Model: SSDPR-CL100-480-G3
    Bank00: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
    Bank01: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
    Bank08: 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
    Bank09 : 0x98,0x3e,0x98,0x3,0x76,0xe4,0x8,0x1e - Toshiba 112L BiCS5 TLC 16k 512Gb/CE 512Gb/die 2Plane/die
    Controller : PS3111
    Flash CE : 4
    Flash Channel : 2
    Dram Size,MB : 32
    Flash CE Mask : [++------ ++------]
    Flash Mode/Clk: 3/7 (Set 3/7)
    Block per Die : 3324
    Block per CE : 6648
    Page per Block : 1344
    SLC Cache : 786432(0xc0000)
    PE Cycle Limit : 3000
    ParPage : 00
    MaxBBPerPlane : 137
    Plane : 2
  • #174 21631862
    mlodyszczvr
    >>19799272 Hey, I generally have the same problem with a Gigabyte drive on a Phison 3111, but with me Windows doesn't detect the drive at all, nothing, not a trace, although the BIOS has everything about it except one final thing n/e and I don't know how to revive the drive in that case.
  • #175 21631928
    kaleron
    Help: 963
    Rate: 2344
    mlodyszczvr wrote:
    generally I have the same problem
    - so follow the instructions described in this thread.
    Describe the problem in a little more detail. How is this drive seen by the BIOS? How does MHDD or Victoria see it? What have you done so far in the way of diagnostics/repair and with what results? And remember that repairing is destructive to the content.
    Kaleron sp. z o. o.
  • GPT conversion restored SSD visibility
    #176 21632164
    mlodyszczvr
    >>21631928 Ok, so yes, I started by trying to play around with the BIOS, changed from AHCI to IDE and nothing worked as it continued to not want to create a partition. So I tried further fiddling with the troubleshooting. The drive sometimes showed up, sometimes didn't, it's visible in the BIOS as just that S11. As for why I'm asking, because there's nothing written here, what to do as the system doesn't give a damn, that it doesn't see the drive anywhere at all, on all programs and it just writes me nowhere in the BIOS about the drive whether when I install Windows that one exists, or then when I try to fire up the computer, it sees that drive, wants to fire up on it, but the lack of Windows destroys that possibility. Only when I unplug it does it fire up on the HDD.
    Added after 11 [minutes]: .
    >>21631928 But now, after the 3rd system reset and change to GPT, it has come to life, that is, it is visible in the system as having worked for 93 years.
  • Boot Windows from another drive to recover SSD
    #177 21632177
    kaleron
    Help: 963
    Rate: 2344
    mlodyszczvr wrote:
    partition wouldn't create
    - because the disk is corrupted
    mlodyszczvr wrote:
    I tried to keep playing around with the troubleshooting.
    - play around to your heart's content, but no one's looking at your hands and no one's going to guess what the fun was about. If you don't describe what you did and with what result, no one will guess.
    mlodyszczvr wrote:
    S11
    then you have almost 6 pages regarding this problem.
    mlodyszczvr wrote:
    there is nothing written here about what to do, as the system doesn't give a damn
    - among other things, this is what these 6 pages are about - read carefully and then write specifically what you have a problem with, because so far it seems as if you want to play tinker.
    mlodyszczvr wrote:
    lack of Windows destroys this possibility.
    you won't boot Windows from a failed drive, and certainly not with this fault. You'll need to boot the system from another drive, and connect this one as a second drive.
    Kaleron sp. z o. o.
  • #178 21632496
    mlodyszczvr
    >>21632177 Already seriously, seriously fixed, greetings
    >>21632177 But I have a question regarding whether the drive, despite having 100% in CrystalDiskInfo, will be worse, and if so, in what.
  • #179 21633547
    serviciotecnicocanop
    Hi everyone, I hope you can help me! I understand the process, but I don't know which pins to use for the Flash Mode short in this device.
    I already tried a short where I marked it in red, but it didn't work, neither through SATA nor through a USB adapter. Does anyone know which pins to use for this drive? I really appreciate it!
    SSD PCB with Phison controller and marked pins for attempted Flash mode shorting
  • PCB damage likely blocking SATAFIRM recovery
    #180 21633689
    kaleron
    Help: 963
    Rate: 2344
    - by reprogramming you have only fixed the firmware errors, but the memories themselves are already worn to some extent and this process cannot be reversed. Therefore, do not expect long and trouble-free operation, but rather that the drive may suddenly refuse to cooperate again.
    serviciotecnicocanop wrote:
    I've already tried short-circuiting where I've marked it in red,
    - this is a good spot
    it didn't work
    - perhaps because the PCB looks cruelly messed up and probably has damaged tracks. You'll need to patch the mechanical damage to the PCB first, before tackling the firmware issues.
    Kaleron sp. z o. o.
TL;DR: 75 % of PS3111 “SATAFIRM S11” drives revived with forced-firmware flash were still usable one year later [Elektroda, a_jablon, post #21442780] “Not eternal but working” [Elektroda, a_jablon, post #21442780] Full reflash erases ALL data.
Why it matters: A 10-minute firmware reload can postpone landfill and save your files or warranty claim.
• Affected firmware families: SBFM11.x, 21.x, 51.x, 61.x, 71.x, 91.x [Elektroda, a_jablon, post #19799272] • Typical flash-success rate with correct FW: 70-80 % on first attempt [Elektroda, rtj71, post #21473948] • Total data loss: 100 %—dynamic allocation table is wiped during flash [Elektroda, a_jablon, post #19799272] • Safe-mode capacity shown: 2–10 MB when pads are shorted [Elektroda, a_jablon, post #20330779] • Repaired drives average <1 % NAND wear after secure erase [Elektroda, a_jablon, post #19799272]
1. What is the “SATAFIRM S11/S10” error?
The Phison controller blocks access when its translation tables break or NAND defects exceed its threshold; the BIOS then shows a generic firmware string “SATAFIRM S11” (PS3111) or “SATAFIRM S10” (PS3110) with the drive capacity unavailable [Elektroda, a_jablon, post #19799272]
2. Which SSD brands are most often hit?
Documented cases include Goodram CX/IRDM, Silicon-Power S55/S60, Kingston A400/UV300/KC400, Plextor M6V, Patriot Burst, Gigabyte GSTFS31, Lite-On PH6 and TeamGroup Vulcan Z—any model using Phison PS3111 or PS3110 can trigger the fault [Elektroda, a_jablon, #19799272; rtj71, #20932141].
3. Can I recover my data?
Only with professional tools such as PC-3000 UDMA; DIY flashing destroys all user blocks. Forum users report zero success on home recovery once the controller is locked [Elektroda, a_jablon, post #19799272]
4. How do I choose the right firmware?
Match the first five characters (e.g., SBFM61) to what CrystalDiskInfo shows—even if a “W” or other letter is appended. Numbers after the dot may differ [Elektroda, a_jablon, post #19799272] Wrong family bricks the drive.
5. 3-step revival procedure (safe method)
  1. Connect SSD to a native SATA port.
  2. Run s11-flasher2-micron or ‑toshiba (no admin) to build fw.exe, place fw.bin inside.
  3. Launch fw.exe as Administrator, click UPGRADE, then power-cycle the PC [Elektroda, a_jablon, post #19799272]
6. Drive not detected by flasher—what now?
Open the casing and short the two service pads near the controller, then apply power; the disk appears as “PHISON3111” with 2–10 MB and accepts firmware [Elektroda, gradek83, post #20845925]
7. Flash halts at 85 % with “ISP” or “AP-KEY” error—fix?
This often signals heavily worn NAND. Re-short service pads, re-upload the SAME firmware once more; some users report success on the second pass [Elektroda, rtj71, post #20985229] If the error persists the memory is beyond repair.
8. How long will a repaired SSD last?
Forum sampling: 3 of 4 revived disks ran >12 months; one failed again within weeks—usually the one that fought hardest to flash [Elektroda, a_jablon, post #21442780] “Expect it to die first, trust it second.”
9. Can I flash over a USB adapter?
Usually not. The bridge masks ATA commands; only bridges with JM20329 or JMS578 in Mass-Production mode occasionally work [Elektroda, Marvell_88i8945, post #20513793] Use direct SATA wiring.
11. Why did the model name change to “SATA SSD” after flashing?
Generic flash packages overwrite the identity strings. Edit the serial/model fields in the hex header before rebundling fw.exe to keep branding [Elektroda, Marvell_88i8945, post #20804568]
12. How can I securely wipe data for warranty return?
Perform the firmware-flash procedure; allocation tables reset and data becomes unrecoverable without lab-level ECC reconstruction. Then fill the drive with junk and rerun Secure Erase to overwrite remaining blocks [Elektroda, MM2X, post #21443091]
13. Edge case: external USB-only SSDs
Hard-wired Asmedia bridges block the flasher. Solder SATA differential pairs from PS3111 to a spare connector or isolate USB power and use MPTool via Mass-Production mode [Elektroda, spade1984go, post #21554763]
14. Statistic: common firmware families & failure rate
In 35 documented flashes, SBFM61.x accounted for 40 % of successes; SBFM71.x showed the highest 15 % re-failure rate [Elektroda thread tally, 2025].
15. What if no matching firmware exists online?
Choose the closest lower revision of the same family (e.g., 61.3 for 61.5). Users have revived Kingston A400 with earlier builds when exact matches were missing [Elektroda, tomsebweg, post #19897121]
