Connection of Orno meter to Huawei inverter via RS 485: DTSU 666H and monitoring
mcgregory 927 1
  • #1 19843188
    mcgregory
    Rate: 9
    I am looking for help to connect an Orno meter to a Huawei inverter. Both devices have an RS 485 link, and when the devices are connected together the inverter does not see the meter. The original monitoring is built on a DTSU 666H, it also has an RS port
  • #2 19843457
    starob
    Help: 128
    Rate: 137
    And only with such a meter can it get along. A counter is not equal to a counter, a question of register addressing.
    You do not lose much, the information from the counter is not necessary for the inverter to operate, it only adds statistics to the cloud.
    If you are stubborn, you can make your own statistics, but this requires setting up a "server" of some kind.
