No response from Obi awning to Dooya 1600 remote control when connected to charger
jaran82 2955 6
  • #1 19949151
    jaran82
    Rate: 47
    Hi.
    I have fitted an awning from Obi, the remote control says Dooya 1600 - not sure if this is the name of the awning.
    I have connected the awning to the charger. When I switch on the lights the charge indication starts to blink and the awning does not move, you can hear the motor running for a while but no effect.
    The manual control works without any problem.
    Help plis
  • #2 19949739
    krzywy1
    Help: 74
    Rate: 119
    Describe in more detail what the problem is, as it's hard to understand what's going on. Is the remote control not working?
  • #3 19951781
    jaran82
    Rate: 47
    The remote control doesn't work, let's start with that.
    It's supposedly in the manual that you have to cut the current to the motor to pair it again, but either I'm doing it wrong or the remote isn't responding.
    The awning has lights regarding charge and it's charged at 3 out of 4, I'm just charging it at max. The remote lights up between buttons as you press the button, so no power problem either.
  • #4 19952064
    krzywy1
    Help: 74
    Rate: 119
    If the manual control works, then the roller shutter is operational. You must pair the remote control accurately as it says in the manual.
  • #5 20007241
    bacspace999
    Have you managed to get it working? I have a similar problem. Apparently the 4 lefts light up red but the roller shutter does not respond to attempts to pair with the remote. I don't have the instructions unfortunately. I discovered a button on the battery housing but this also did nothing with various combinations. Zero response. Does anyone have an instry for this awning???
    Greetings.
  • #6 20064073
    Marek J.
    Help: 526
    Rate: 950
    What about Obi? What did they say about the symptoms of awnings not working? Did you make a complaint? Every self-respecting company has a helpline, technical advisors or certified representatives who are happy to help with problems after purchase.
    A while ago I even saw an advert and the words " You do it with Obi !".
  • #7 21525190
    Filip Steinke
    >>20007241 Hey buddy did you manage to solve the problem ? Did you find the instructions for this awning ? I have a similar problem
✨ An Obi awning equipped with a Dooya 1600 remote control fails to respond when connected to the charger. The awning motor runs without effect, and the charge indicator blinks, while manual control operates correctly. The remote control powers on and shows button illumination but does not control the awning. Pairing the remote requires cutting power to the motor as per the manual, but attempts to re-pair have been unsuccessful. Similar issues reported include unresponsive roller shutters and ineffective pairing despite pressing a button on the battery housing. No official Obi support or detailed instructions have been provided, and users seek guidance on remote pairing procedures and troubleshooting steps for the awning’s motor and remote control communication.
