Tuya SmartHome valve: Wi-Fi-free operation, communication with water sensors and closing
pdusp 1221 3
  • Clarifying whether Tuya valve closes without Wi-Fi
    #1 20277727
    pdusp
    Rate: 15
    I cannot find an answer to my question regarding the Tuya valve.
    I understand that in order to program it, there must be wifi coverage and access to the server, it must be paired with water sensors.
    Does this mean that if there is no wifi signal then the valve will not close when the water sensor alerts a leak? Or what I would like it to do, the sensor will communicate itself without wifi with the valve and the valve will close?
    Thank you and best regards
    Peter
  • #2 20278455
    emariusz
    If the sensor and valve are on wifi then without coverage it won't work.
    If on zigbee then yes. because they are connected to a gateway and even if there is no internet the valve should close.
  • #3 20278463
    palmus
    Help: 233
    Rate: 752
    But they still need to be within Zigbee range.
  • #4 20278471
    emariusz
    Yes, of course.
