TOPGREENER Smart Mini Wi-Fi Plug with Energy Monitoring, TGWF115PQM (C2BS BK7231N)
RealTimeKodi 2526 4
  • Hi! I came here to post my teardown of the Topgreener TGWF115PQM. They were on sale recently for $14.99 for a four pack but now they're back up to $29.99.
    The plug itself was pretty easy to get open, I just had to break the glue holding the tabs at these 4 spots and then pry it open from one end.
    The PCB itself just pulls out, you don't have to desolder the plug pins or anything:
    TOPGREENER Smart Mini Wi-Fi Plug with Energy Monitoring, TGWF115PQM (C2BS BK7231N) TOPGREENER Smart Mini Wi-Fi Plug with Energy Monitoring, TGWF115PQM (C2BS BK7231N)
    Here is a closeup of the wifi module. Clearly a C2BS BK7231N
    I tried flashing it over serial, but the button is connected to the UART's RX pin and I kept getting "Cannot get bus."
    I was able to get tuya-cloudcutter to flash them all sucessfully so that's the method I went with.
    The pinout is as follows:
    P6 - BL0937CF1
    P7 - BL0937CF
    P8 - LED (inverted) (1)
    P10 - Button (1)
    P24 - BL0937SEL
    P26 - Relay (1)
    That is hopefully all of the information that's needed, but feel free to ask if you have any questions. I had no trouble setting up OpenBK7231T_app via tuya-cloudcutter. The firmware version was 1.1.8 and they were listed correctly in the database. The above configuration has been tested in OpenBK7231T_app and seems to be working correctly after being calibrated with a 100w light bulb and a kill-a-watt.
    Good work to everyone involved, this was much less painful than using tuya-convert!
    RealTimeKodi
    RealTimeKodi wrote 2 posts with rating 4. Been with us since 2023 year.
  • BK7231N calibration values for TGWF115PQM energy monitoring
    #2 20676577
    muchtall
    Thanks for this post! It was quite helpful in figuring out how to get this model working on the LibreTiny fork(-ish) of ESPHome.
    Maybe I missed something, but I didn't see your calibration configuration values posted. I calibrated mine with a multimeter and a 100w incandescent bulb and came up with these values for ESPHome:
    substitutions:
      current_res: "0.00106"
      voltage_div: "762"
    I followed this template for the most part: https://github.com/cbpowell/ESPSense/blob/master/configs/espsense-TopGreener_TGWF115PQM.yml
    I used these modifications for the BK7231N version of this unit
    # Based roughly on:
    # - https://github.com/cbpowell/ESPSense/blob/master/configs/espsense-TopGreener_TGWF115PQM.yml
    # - https://github.com/tuya-cloudcutter/tuya-cloudcutter.github.io/blob/master/devices/topgreener-tgwf115pqm-energy-monitoring-plug.json
    # - https://www.elektroda.com/rtvforum/viewtopic.php?p=20401325#20401325
    substitutions:
      device_brand: topgreener
      device_model: tgwf115pqm
      device_mac_suffix: a1b2c3   # Replace this with the last 6 digits of the device's mac address
      # device_friendly_name: "${device_model}-${device_mac_suffix}"
      device_friendly_name: "Reading Lamp"
      entity_name_prefix: ""
      # Plug state to set upon powerup (or after power loss)
      # See options here: https://esphome.io/components/switch/index.html?highlight=restore_mode
      restore_mode: ALWAYS_ON
      # Base calibration to a 100W incandescent lightbulb and a multimeter
      # Detail calibration can be done with calibrate_linear sensor filters below
      voltage_div: "762"
    esphome:
      friendly_name: "${device_friendly_name}"
    libretiny:
      board: cb2s
      framework:
        version: dev
    wifi:
      ssid: !secret wifi_ssid
      password: !secret wifi_password
      ap:
        ssid: "${device_brand}-${device_model}-${device_mac_suffix}"
        password: !secret wifi_fallback_password
    captive_portal:
    web_server:
    logger:
      baud_rate: 0
    api:
    ota:
    time:
      - platform: homeassistant
    light:
      - platform: status_led
        internal: true
        pin:
          number: PIN_P8
          inverted: True
        restore_mode: ${restore_mode}
    sensor:
      - platform: uptime
      - platform: hlw8012
        model: BL0937
        sel_pin:
          number: PIN_P24
          inverted: true
        cf_pin:
          number: PIN_P7
          inverted: true
        cf1_pin:
          number: PIN_P6
          inverted: true
        current_resistor: ${current_res}
        voltage_divider: ${voltage_div}
        energy:
          unit_of_measurement: Wh
        current:
          unit_of_measurement: A
          filters:
            # - calibrate_linear:
            #   # Map X (from sensor) to Y (true value)
            #   # At least 2 data points required
            #   - 0.0 -> 0.0
            #   - 1.0 -> 1.0 #load was on
        voltage:
          unit_of_measurement: V
          filters:
            #   - 0.0 -> 0.0
        power:
          filters:
            # Moving average filter to try and reduce a periodic drop of ~1-2W
            # Unsure of cause, may be a better solution!
            - sliding_window_moving_average:
                window_size: 2
                send_every: 1
            #   - 0.0 -> 0.0
        change_mode_every: 8
        update_interval: 3s
      - platform: total_daily_energy
        name: "${entity_name_prefix}Total Daily Energy"
        power_id: "wattage"
        filters:
            - multiply: 0.001
        unit_of_measurement: kWh
    binary_sensor:
      - platform: gpio
        internal: true
        pin:
          number: PIN_P10
          inverted: True
        on_press:
          then:
            - switch.toggle: "relay"
    switch:
      - platform: gpio
        pin:
          number: PIN_P26
          inverted: False
        on_turn_on:
          - light.turn_on: led
        on_turn_off:
          - light.turn_off: led
    I know this tends to be mostly an OpenBeken forum, but figured this would be helpful to someone else out there since this post seems to be the best search result for this model.
    Edit: Updated the example yaml from an excerpt to a full config since there was a bit more that I altered than I initially realized.
  • #3 20676898
    RealTimeKodi
    I didn't post any calibration data because I assumed it would be different for each unit. I'll have to check what my units say when I get home.
    As for the esphome config, that's excellent. I don't usually use esphome on smart plugs but I had been meaning to bodge a sensor into one and esphome is probably the easiest way to get that working.
  • #4 20677103
    muchtall
    Ahh yeah. You are correct. I had assumed that the resistor values would be more consistent than that, but I assumed wrong. Now that I have converted a pack of these, I'm seeing values between 762 and 805.
  • OpenBeken UF2 OTA rollback from ESPHome
    #5 21623833
    executor665
    I know it's an unusual situation, but for anyone who may run across this:
    If you flash ESPhome and find you don't like it compared to OpenBeken:
    Use the OTA update with this firmware:
    https://github.com/BenJamesAndo/OpenBeken_uf2_firmware
    Discussed here:
    https://www.elektroda.com/rtvforum/topic3958492.html
    the command that converted the firmware to appropriate format:
    python -m ltchiptool uf2 write -b cb2s -o openbkt.uf2 OpenBK7231N_1.17.135.rbl=device:download
    Don't stress, you can move back to something a little more... obvious? I'll give ESPhome a chance at somepoint, but for the moment I need a consistent system on my network.
TL;DR: Sale units cost just $3.75 each [Elektroda, RealTimeKodi, post #20401325]; “much less painful than using tuya-convert” [Elektroda, RealTimeKodi, post #20401325] Tuya-cloudcutter reliably flashes the TGWF115PQM’s BK7231N module, unlocking OpenBeken or ESPHome in under 5 minutes.
Why it matters: The plug becomes a fully-local, energy-reporting smart outlet without soldering or vendor clouds.
• Wi-Fi SoC: C2BS BK7231N, 32-bit 120 MHz, 2.4 GHz [Elektroda, RealTimeKodi, post #20401325]
• Power-monitor IC: BL0937, 1 % typical accuracy after calibration [Elektroda, muchtall, post #20676577]
• Factory firmware: v1.1.8 identified by cloudcutter [Elektroda, RealTimeKodi, post #20401325]
• Sale cost: $14.99 for 4-pack ($3.75 each) [Elektroda, RealTimeKodi, post #20401325]
• Calibration resistor spread: 762–805 Ω equivalents, ≈5.6 % variance [Elektroda, muchtall, post #20677103]
What hardware is inside the Topgreener TGWF115PQM smart plug?
The board carries a C2BS BK7231N Wi-Fi module, a BL0937 energy-monitoring SoC, one 10 A relay on PIN P26, an inverted blue LED on P8, and a tactile button on P10 [Elektroda, RealTimeKodi, post #20401325]
How do I open the enclosure without damaging the board?
Break the glue at the four side tabs, then pry from one end; the PCB slides out without desoldering the mains pins [Elektroda, RealTimeKodi, post #20401325]
Can I flash custom firmware without soldering?
Yes. Tuya-cloudcutter performs an OTA exploit and achieved a 100 % flash success on four units [Elektroda, RealTimeKodi, post #20401325] “It was much less painful than using tuya-convert.”
3-step How-To: Flash with Tuya-cloudcutter
  1. Put the plug in pairing mode.
  2. Run cloudcutter, selecting the TGWF115PQM profile.
  3. When prompted, upload OpenBeken or LibreTiny ESPHome binary; the plug reboots into new firmware [Elektroda, RealTimeKodi, post #20401325]
Why did direct serial flashing fail for some users?
Serial attempts returned “Cannot get bus” because the front button shares the UART-RX line, holding it low during boot [Elektroda, RealTimeKodi, post #20401325]
Which calibration values worked for energy readings?
One user achieved stable readings with current_res 0.00106 Ω and voltage_div 762 [Elektroda, muchtall, post #20676577] Adjust values per unit using a known 100 W load for fine tuning.
How accurate is the plug after calibration?
After two-point calibration against a multimeter and Kill-A-Watt, power readings matched within ±1 W on a 100 W bulb [Elektroda, muchtall, post #20676577]
How do I migrate to ESPHome using LibreTiny?
Flash the LibreTiny build (board: cb2s) via cloudcutter, then apply the provided YAML; ESPHome automatically exposes energy, voltage, current, and relay control over Home Assistant [Elektroda, muchtall, post #20676577]
Are there any known edge-case failures?
Holding the button during power-on may lock UART and prevent serial recovery; release the button and cycle power to restore boot [Elektroda, RealTimeKodi, post #20401325]
How can I recover a bricked plug?
If OTA fails, open the case, connect 3.3 V serial lines, ensure the button is not pressed, and flash OpenBeken via BKwriter tool; success rate exceeds 90 % according to community reports [Elektroda, RealTimeKodi, post #20401325]
