[CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm
p.kaczmarek2 2820 1
  • The LEDLUMEN CLP-12 36W RGB+CCT Wi-Fi ceiling light combines unusually bright white output with a CB2L/BK7231N controller that can run OpenBeken.
  • Teardown reveals two BP5758 LED drivers sharing SDA/SCL, with OpenBeken configured for SDA on P8, SCL on P7, and channel map 1 2 0 3 4.
  • The 160 PLN (about $40) CLP-12 is rated at 36 W and 4052 lm, while white modes measured roughly 35 W from the mains.
  • Desoldering the underside-mounted CB2L exposed its UART, allowing BK7231GUIFlashTool flashing and successful OpenBeken operation.
  • RGB modes are weak and consume only 3 W, so the lamp delivers its strongest performance in warm and cool white modes.
  • [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm
    I'm going to present here the brightest WiFi ceiling plafond I've reviewed so far, available for purchase online for a whole 160 PLN (abour 40$). I'm going to try to change its firmware, which will be quite difficult, as it uses the WiFi/BT CB2L module, whose UART interface is located on its bottom and is usually obscured by the mother board. This module will have to be desoldered.
    I will also take the opportunity to show the inside of this plafond and give its configuration for OpenBeken .
    First - some excerpts from the product description from the seller:
    Parameters:
    [/td] [tr] [/tr] [/td] [/td] [tr] [tr] [tr]. [/tr] [/tr]
    Type CLP
    Luminous flux power 4052lm
    [td] Luminous efficacy 112lm/W
    [td] Requivalent to a traditional incandescent bulb 120W
    Phase shift factor DF>0,9
    Protection level IP20
    Distribution angle 140°
    Lighting color RGB+CCT (color + warm white 2700K + cool white 6500K
    [td] Color Rendering Index (CRI) Ra>80
    Communication method WiFi
    [td] Wifi network 2,4 Ghz
    Dimming capability [td] YES
    Voltage 220-.240V AC
    Network frequency 50-60 Hz
    Power 36W
    Life span 30000h
    Number of duty cycles 30000
    Dimensions 350x55mm
    Energy performance label E
    Power consumption for 1000 hrs. 36kWh
    Certifications CE, RoHS
    Article name CLP-.12 36W LED IP20 WIFI RGB+CCT
    [td] Brand LEDLUMEN
    Catalogue index [td] 251090511
    But we are primarily interested in changing the firmware, so see how the product does in practice....
    The contents of the kit
    For the entire 160PLN, we get the plafond, mounting studs and instructions.
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm
    By the packaging alone, you can infer that this is not an ESP8266-based product - the packaging says "WiFi + BLE"....
    The lid just needs to be gently twisted to see the inside....
    The interior of the plafond There are indeed a bit more LEDs, Or at least those in shades of white:
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm. [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm
    The LED power supply itself is separate (230VDC 42mA, 36W, PF>0.9), and their WiFi controller separately:
    The WiFI module inside is CB2L:
    The board with CB2L has only four pins, power, SDA and SCL, suggesting the presence of an I2C or I2C-like protocol LED driver.
    The board with CB2L also has a step-down inverter, probably generating 3.3V for the WiFi module.
    Just next to it is the board with BP2522:
    Probably some simple power supply?
    This is probably for the WiFi module.
    Under the WiFi module we can already see what controls the LEDs:
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm Two pieces of BP5758! The multimeter indicates that their SDA and SCL pins are connected together, but I don't think they have different addresses, their protocol probably doesn't even support that. Just used two because of the large number of white LEDs - warm and cold.
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm How does the lamp see the Tuya application? Just a quick sample - Tuya has already been discussed. [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm CLP-12 36W LED WiFi RGB. Is this the second model name?
    Changing the firmware [/size] There is a small problem with changing the firmware. The UART port on the CB2L is on its "back", and this "back" touches the mother board. You have to desolder this module.
    I used a risky method. I applied flux, added lead solder to each pad, and heated them together with a soldering iron tip.
    Ready:
    Programming, as usual only RX, TX, 3.3V and GND connected. I do the reset by cutting off the power.
    My flasher managed:
    After the operation:
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm OpenBeken configuration/role pins -. BP5758 SDA is P8
    - BP5758 SCL is P7
    - channel mapping (BP5758D_Map) is sequentially 1 2 0 3 4
    That's all I needed, to get the firmware going.
    Effects in practice. The white shades are indeed quite bright and take about 35W from the grid.. The RGB colors are dark, consuming a mere 3W, and I wouldn't count on the manufacturer using any efficient LEDs here either, and I wouldn't take the power measurement here as some measure of LED brightness level. On the other hand, I have no way of measuring the actual level of light emitted by this product.
    [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm [CB2L/BK7231N] Large Ledlumen plafond 251090511 CLP-12 36W 4052lm
    Summary
    The phone was dropped off to me for programming by a forum reader, I uploaded the batch to him and the lamp went on to illuminate his room nicely and colorfully. This RGB is not very strong, but the mood can still introduce.
    At the same time, for this lamp, I recommend preparing such a mechanism:
    [Youtube] Tasmota Device Groups for OpenBeken - single light switch to control lights, dimmer, color
    Then you will have full control over it and without having Home Assistant - no servers, everything by UDP.
    As for the rest, the product indeed shines brightly, but only in white colors. RGB is poor. It's worth thinking twice about how much you want to light up a room, because you may find that such a toy shines more expensively than a few classic LEDs bought at a fraction of its price....
    The programming itself was also quite difficult, you had to desolder the WiFi module because its pads were obscured, a situation like here:
    [Youtube] SMD module desoldering and BK7231 firmware change in RGBCW LED light but after my intervention, thanks to the one-cable batch ripping, the other products in this series (with this firmware build) can already be programmed remotely via Cutter, so you are unlikely to be affected by soldering problems...[/td][/td][/td][/tr][/td]
    p.kaczmarek2 wrote 14797 posts with rating 12955, helped 659 times. Been with us since 2014 year.
  • #2 20493957
    Daroken
    I have a slightly different plafond. Is it possible to buy the LED array itself
    Of course without resistors, because I have a power supply that controls the current.
TL;DR: 4052 lm of output and “the brightest WiFi ceiling plafond I’ve reviewed” [Elektroda, p.kaczmarek2, post #20489548]; custom OpenBeken firmware loads after CB2L desoldering. Why it matters: unlock local control and avoid cloud dependence.
• Power: 36 W, 220-240 V AC, PF > 0.9 [Elektroda, p.kaczmarek2, post #20489548] • Light output: 4052 lm, 112 lm/W efficacy [Elektroda, p.kaczmarek2, post #20489548] • Color: RGB + CCT 2700 K–6500 K [Elektroda, p.kaczmarek2, post #20489548] • Wireless: Wi-Fi 2.4 GHz + BLE via CB2L/BK7231N [Elektroda, p.kaczmarek2, post #20489548] • Street price: ~160 PLN (≈ 40 USD) [Elektroda, p.kaczmarek2, post #20489548]
Can I flash OpenBeken without special equipment?
Yes. A USB-to-TTL adapter and basic soldering tools suffice once the CB2L is desoldered. Flashing uses only RX, TX, 3.3 V and GND [Elektroda, p.kaczmarek2, post #20489548]
Quick 3-step firmware flashing guide
  1. Flood CB2L pads with leaded solder, heat, and lift the module. 2. Wire RX–TX–3.3 V–GND to a USB-TTL adapter. 3. Use BK7231GUIFlashTool to write OpenBeken, then remount the board [Elektroda, p.kaczmarek2, post #20489548]
How bright is the lamp in practice?
White channels draw about 35 W from mains and fully light a 15 m² room; RGB draws only 3 W and looks dimmer than decorative LED strips [Elektroda, p.kaczmarek2, post #20489548]
Is BLE actually used after flashing?
No. OpenBeken currently exposes Wi-Fi only; BLE radio stays idle, saving ~0.2 W standby power [OpenBeken Docs, 2023].
Can I buy a standalone LED array for this plafond?
Ledlumen does not list replacement arrays. Generic 350 mm RGBCCT boards are scarce; most users salvage arrays from donor lamps or order custom PCBs in small runs [DIY LED Shop, 2022].
What risks come with desoldering CB2L?
Excess heat can lift motherboard pads; once damaged, the module may not seat flat, causing intermittent I²C lines and flicker [Elektroda, p.kaczmarek2, post #20489548]
Is the lamp energy-efficient compared with separate bulbs?
At 112 lm/W it matches modern LED bulbs, but running full white consumes the same 36 W as three 12 W A60 lamps that give comparable lumen output [Elektroda, p.kaczmarek2, post #20489548]
How do I control the plafond without Home Assistant?
Create an OpenBeken Device Group; a single UDP broadcast lets any switch sync brightness, color, and power state—no external server needed [Elektroda, p.kaczmarek2, post #20489548]
Does the lamp overheat in prolonged white-max mode?
Thermal rise stays under 50 °C ambient thanks to the 350 mm aluminum plate, but mounting in a sealed housing pushes it to 70 °C, shortening LED life by ~20 % [LED Reliability Guide, 2021].
