Setting Up Smart Home: ESP, Occupancy Sensors, Lighting, Heating, Security
lukasz18dg 1101 0
  • Powering ESP32 and LD2410 from PoE module
    #1 20502265
    lukasz18dg
    Help: 11
    Rate: 29
    I'm looking for information, help, guidance or even a negative answer that it's not worth it.
    Situation: bought development flat, no major tenant alterations.
    The height of the flat is about 2.6m.
    Because I have a development flat, I was thinking of using it and pulling all the cables I need and so sooner or later I came across the topic of smart home.
    What I'm trying to achieve:
    Lighting
    Automatic switching off of lights when no one is present ( presence sensor )
    Floor heating ( some Salus, no data on that yet )
    Door opening and closing sensor
    Window opening sensor, balcony doors
    Automatic opening and closing of entrance doors
    Vision viewer ( possibility to suspect by phone who is trying to break into the flat )
    Exterior roller shutters/interior roller shutters? Partner, block of flats
    Monitoring of utilities?
    As you can guess, I have started my combinations with occupancy sensors. I would like to avoid running everything over Zigbee or WiFi, I was thinking of cable versions of the Smart home.
    Unfortunately commercial versions:
    Grenton - I'm afraid of a closed system
    KNX - expensive and no simple document, buy this, that and you'll have what you want.
    Ampio - only for installers, I would like to do as much as possible with my own time
    I came across Hapcan, but unfortunately the shop does not offer too much available stuff, plus from what I understood it is a very old and slow technology.
    I thought that I will create my own module based on ESP32 + LAN ( with POE or not? ) + HLK-LD2410 + sizable switch + proxmox + Home Assistant
    Only I have a few problems:
    1. How to provide power for EPS + HLK-LD2410?
    As I understood correctly ESP works on 3.3 volts, where: HLK-LD2410 operates on 5 volts. Would the use of a board with POE e.g.:
    LILYGO® TTGO T-Internet-POE ESP32 Ethernet Adapter LAN8720A Expansion Module Programmable Hardware
    https://pl.aliexpress.com/item/4001134936204.....0.0.2523452ciAUuzo&mp=1&gatewayAdapt=glo2pol
    solve the problem of powering this?
    I was thinking to flip the results from the HLK-LD2410, via UARTA to the ESP, and the ESP will flip this to: MQTT or somewhere further down to Home Assistant.
    Maybe the question is, why am I starting with a presence sensor?
    I plan to put this contraption in some sort of enclosure and throw it under the false ceiling.
    I was simply thinking of: Zigbee TS0601, but the price scares me, especially as I will need about 4 of these(kitchen, bathroom, living room, room)?
