[Solved] Openbeken BK7231N Chip: Smart Switch WiFi Connection Failure - SSID and Password Correct
btmerz 7359 36
Why does my BK7231N smart switch show the correct SSID and password in OpenBeken but fail to connect to my Wi‑Fi router?
The connection problem was caused by the Wi‑Fi mesh setup in the Fritz!Box network; after resetting the repeaters and rebuilding the mesh, all devices connected normally [#20593364][#20593442] During troubleshooting, the module was confirmed to work with a mobile hotspot but not with the router/guest WLAN, which pointed away from OpenBeken or the BK7231N firmware itself [#20581563][#20581859] The thread also suggested checking that the network is really 2.4 GHz, trying the device very close to the router, and verifying channel/security settings and MAC filtering [#20587967][#20588978][#20586384]
    torrijo
    Rate: 8
    it is important to make sure that the wifi network is 2.4GHz in 5GHz it does not work
    Rate: 12914
    Hmm, I must admit, it's a very good and basic point, that I totally forgot to bring up here. Even Tuya product sellers remind about it repeatedly.
    @btmerz , is your WiFi 2.4GHz?
    torrijo
    Rate: 8
    It can also pass the complexity of the password if it is very difficult with many characters it can also fail
    I have ever had to create a user for Wi-Fi guests on the router to be able to connect a device, also the operating system of the phone if it is iOS or Android
  • #34 20588971
    btmerz
    Level 4  
    >>20587973
    Yes, I used a 2.4 GHz Wi-Fi.
    And as I mentioned in my first post, I already was able to successfully connect another similar module to my Wi-Fi.
    Rate: 12914
    @btmerz does it work if you try to move the problematic module next to your router? Very, very close?
    I apologize, as of today, I have no other ideas what might be wrong. Maybe there is some kind of advanced tool around for router to analyze the WPA packets or something, that could help, theoretically...
    EDIT: which channel is your WiFi on? Have you tried changing WiFi channel?
  • Mesh repeater reset fixed Wi-Fi pairing
    #36 20593364
    btmerz
    Level 4  
    Hello all,
    meanwhile I'm happy to announce, that I was able to get all my devices to connect to my wifi.
    The problem was in my WiFi Mesh. I had three Fritz boxes in a mesh. But somehow there was something mixed up somehow.
    So I resetted all my Repeaters and connected the new to the mesh.
    Now it is working. Why I had no problem with my ESPs and Tasmota, I don't know.
    But the main thing is that it is working now.
    Thanks to all for your great support.
    Now I only have to figure out my pin connection for the switches, relays LEDs and Power sensor on my aubess mini power monitor switch.
    Do you have some examples here?
    Hinzugefügt nach 57 [Minuten]:
    I got the Switches and BL0942 Power sensor to work!
    Thanks again!
  • #37 20593442
    btmerz
    Level 4  
    I had some problems with my wifi mesh setup of my three Fritz-Boxes.
    I set up the mesh new and now all works as expected.
    Thanks all for the support.
    Bernd
The discussion revolves around a user experiencing WiFi connection issues with a smart switch utilizing the BK7231N chip after flashing the latest firmware. Despite correct SSID and password configurations, the device fails to connect to the router, although it successfully connects to a mobile hotspot. Various troubleshooting steps are suggested, including restoring RF settings, checking MAC address duplication, and ensuring the WiFi network operates on the 2.4GHz band. Ultimately, the user resolves the issue by reconfiguring their WiFi mesh setup, which had caused connectivity problems, while other devices like ESPs and Tasmota were unaffected.
TL;DR: For 5 OpenBeken BK7231N/CB2S switches, “same SSID+Password” worked on a phone hotspot but failed on a Fritz!Box router; the fix was resetting 3 Fritz!Box mesh repeaters and rebuilding the mesh. This FAQ helps smart-switch users diagnose correct-credential WiFi failures after flashing. [#20593364]
Why it matters: Correct SSID and password do not prove the router, mesh, RF data, or scan path is healthy.
Alternative Result in the thread Key difference
Phone hotspot Connected Same SSID Bernd, password 12345678, channel 6 in one test
Fritz!Box guest WiFi Failed Same SSID and password, scan returned get_scan_rst_null
Rebuilt Fritz!Box mesh Connected 3 Fritz!Box devices reset and re-added to mesh
Key insight: If OpenBeken connects to a hotspot but not to a Fritz!Box using identical credentials, investigate the router or mesh before scrapping the BK7231N module.
  • The failing device used a CB2S module with a BK7231N chip, and the user had a 2 MB original firmware backup before flashing. [#20581033]
  • The UART log showed WIFI_STA_AUTH_FAILED - 3 after sm_deauth_handler reason=1, even though the SSID and password appeared correctly. [#20578696]
  • The working hotspot log reached WIFI_STA_CONNECTED - 4 and received IP 192.168.133.113 with gateway 192.168.133.223. [#20581859]
  • The router-side failure showed get_scan_rst_null and RL_STATUS_STA_SCAN_VAIN, meaning the scan returned no matching AP result. [#20581859]
  • The final fix was rebuilding a mesh of 3 Fritz!Box devices; after that, all OpenBeken devices connected normally. [#20593442]
Why does an OpenBeken BK7231N smart switch show the correct SSID and password in the UART log but still fail to connect to WiFi?
The SSID and password can be correct while the device still fails at scan, authentication, or router mesh handling. In the first log, OpenBeken printed the SSID and key, then reached WIFI_STA_AUTH_FAILED - 3. Later tests proved the same credentials worked on a phone hotspot. The router mesh, not the typed password, caused the final failure. The user fixed all devices by resetting 3 Fritz!Box mesh nodes and rebuilding the mesh. [#20593364]
How do I use the BK7231GUIFlashTool Restore RF button after flashing OpenBeken on a BK7231N or CB2S module?
Make a 2 MB flash backup first, then use Restore RF in BK7231GUIFlashTool.
  1. Create a full 2 MB backup in the flasher.
  2. Flash OpenBeken, then press Restore RF.
  3. If needed, restore the original backup or test Tuya again.
    The thread expert warned that the backup lets you return to the original version. Restore RF did not solve this case, but it solves similar reports. [#20578737]
What does the OpenBeken log message WIFI_STA_AUTH_FAILED mean on a BK7231N smart switch?
WIFI_STA_AUTH_FAILED means the station tried to join WiFi but failed during authentication or association. In the first log, it followed sm_auth_send:1, repeated sm_deauth_handler reason=1, and SM_CONNECT_IND_fail. The failure appeared at status code 3. This does not prove the password is wrong, because the same device later connected to a phone hotspot with valid WPA2 credentials. [#20578696]
What does get_scan_rst_null mean in BK7231N WiFi logs when connecting to a Fritz!Box router?
get_scan_rst_null means the BK7231N scan returned no usable result for the target SSID. The thread expert interpreted it as “no AP of given SSID was found.” In the failing Fritz!Box guest WiFi log, get_scan_rst_null appeared with RL_STATUS_STA_SCAN_VAIN. In the working hotspot log, the same point showed wpa_get_scan_rst:1, then association succeeded. [#20582079]
How can a Fritz!Box WiFi Mesh setup prevent OpenBeken BK7231N devices from connecting while ESP/Tasmota devices still work?
A misconfigured Fritz!Box mesh can block OpenBeken BK7231N scanning or association while ESP/Tasmota still connects. The user had 3 Fritz!Box units in a mesh and saw OpenBeken fail against the router. ESP/Tasmota devices had no connection problem. After resetting all repeaters and adding them back to the mesh, all OpenBeken devices connected. The exact mesh fault was not identified. [#20593364]
What WiFi settings should I check on a Fritz!Box when OpenBeken connects to a mobile hotspot but not to the router?
Check 2.4 GHz mode, WPA2 security, MAC filtering, channel, SSID, password, and mesh state. The thread tested WPA2 on both networks, disabled MAC filtering, tried the same SSID Bernd, and used password 12345678. It also compared router channel settings with the phone hotspot. The final fix was not a password change; it was rebuilding the Fritz!Box mesh. [#20581859]
How do I troubleshoot OpenBeken devices that connect to a phone hotspot but fail on a WPA2 2.4 GHz router network?
Treat the phone hotspot as proof that the module and firmware can work. First, copy the same SSID and password to the router. Second, verify 2.4 GHz, WPA2, channel, and MAC filtering. Third, rebuild router mesh or test another router. In the thread, the same SSID and password worked on a phone but failed on Fritz!Box until 3 mesh devices were reset. [#20585638]
What is a CB2S module, and how is it related to the BK7231N chip used in Tuya smart switches?
A CB2S module is the small WiFi module inside the smart switch that carried the BK7231N chip in this case. “CB2S is a WiFi module that hosts the BK7231N chip, providing the wireless microcontroller platform used by some Tuya smart switches.” The user identified the module as CB2S and had made an original firmware backup before flashing OpenBeken. [#20581033]
What is RF calibration data or Restore RF in BK7231 flashing, and why can losing it break WiFi connectivity?
RF calibration data stores radio-specific settings, including values tied to WiFi operation and MAC handling. “Restore RF is a flasher function that restores radio-frequency calibration data, preserving device-specific wireless settings after erase or flash operations.” The expert suggested Restore RF after a 2 MB backup. He also warned that clearing flash without restoring RF can cause MAC-related problems. [#20581702]
What is UART logging, and how can it help diagnose OpenBeken WiFi connection failures?
UART logging is serial output from the device that exposes boot and WiFi driver messages. “UART logging is a serial diagnostic method that reads startup and runtime logs through UART pins, showing scan, authentication, DHCP, and WiFi status transitions.” In this thread, UART 2 revealed WIFI_STA_AUTH_FAILED, get_scan_rst_null, and the working IP 192.168.133.113. [#20578696]
What is WPA2, and which WPA2 router settings can affect BK7231N or Tuya smart switch connectivity?
WPA2 is the WiFi security mode used on both tested networks. “WPA2 is a WiFi security standard that authenticates clients and encrypts traffic, but router implementation, MAC filtering, band, channel, and mesh behavior can still affect joins.” The thread checked WPA2 on phone and router, verified 2.4 GHz, and ruled out MAC filtering. Mesh reset fixed the issue. [#20586420]
What is a WiFi mesh network, and why can resetting Fritz!Box repeaters fix smart home device connection problems?
A WiFi mesh network uses multiple access points under one coordinated network name. “A WiFi mesh network is a multi-node wireless setup that extends coverage by coordinating routers or repeaters, while presenting one roaming network to clients.” In this case, 3 Fritz!Box mesh devices had a bad state. Resetting the repeaters and reconnecting them to the mesh restored OpenBeken connectivity. [#20593442]
OpenBeken vs Tasmota on smart switches: which is better for BK7231N, CB2S, and ESP-based modules?
Use OpenBeken for BK7231N/CB2S modules and Tasmota for ESP modules. The thread used OpenBeken on CB2S with BK7231N. The user already had ESP/Tasmota devices that connected without trouble. The expert also noted that replacing CB2S with an ESP module was possible, which would enable Tasmota instead of OpenBeken. [#20581040]
How can I replace a CB2S BK7231N module with an ESP module for Tasmota in a smart switch?
Replace the CB2S only if you can map power, relay, button, LED, and sensor pins safely. The thread expert said a CB2S could be replaced cheaply with an ESP module. The user had already considered ESP and Tasmota. The thread did not provide wiring diagrams, voltage values, or pin mappings for the replacement, so use the original backup and board tracing before removal. [#20581040]
How do I configure pins for switches, relays, LEDs, and a BL0942 power sensor on an Aubess mini power monitor switch in OpenBeken?
Configure each OpenBeken pin by matching the Aubess switch functions to relay, switch, LED, and BL0942 roles. The thread confirms the device was an Aubess mini power monitor switch and that the switches plus BL0942 power sensor were eventually working. It does not list the exact GPIO map. Use UART logs and board tracing to verify every pin before applying mains power. [#20593364]
