[Solved] OpenBK MQTT as a device in Homeassistant
schwabelbook 4728 3
This content has been translated flag-de » flag-en View the original version here
  • Need Home Assistant device-level controls for OpenBK
    #1 20579906
    schwabelbook
    Level 4  
    I have some OpenBK devices here and would like to add them as a "device" in Home Assistant, but can only add them there as an "entity" (via configuration.yaml). The background is simply that I would like to set parameters such as "Brightness" or "Status (Off / On) there, as with Tasmota. Unfortunately, if I only have the entity, I cannot set this. This is particularly annoying with automation. If it's not quite clear what I mean, I can add a few more pictures that describe the problem in more detail.
    Rate: 12794
    Hello, can you elaborate on what exactly you mean? Screenshots?
    OpenBeken supports two modes of Home Assistant configuration:
    - you can use Home Assistant Discovery to automatically add the device to HA
    - you can manually write a YAML script and add it to configuration.yaml, then you have full control over all settings
  • #3 20584408
    schwabelbook
    Level 4  
    actually now that I tried it again, the integration worked. Before I only had one entity in my HomeAssistant and no device (had it in the configuration.yaml).
    Now that I have done "HA Discovery" again, I actually have it in.
    Thank you very much!
  • #4 20584454
    Rate: 12794
    Thank you for using our software. If you have any further questions, please feel free to contact us.
    By the way, here is the Hass Discovery Tutorial (English):
    https://www.youtube.com/watch?v=pkcspey25V4
