Led strip on/off+dimmer+IR controller CB3S - Remote control not working after flashing OBK
lukapr 1125 1
  • IR receiver pin still unidentified after OBK flash
    #1 20588875
    lukapr
    Hi guys,
    been trying to teardown the following device, bought on Amazon:
    https://www.amazon.de/gp/product/B0B52C6KRQ/ref=ppx_yo_dt_b_asin_image_o06_s00?ie=UTF8&psc=1
    Led strip on/off+dimmer+IR controller CB3S - Remote control not working after flashing OBK Led strip on/off+dimmer+IR controller CB3S - Remote control not working after flashing OBK
    Successfully flashed it, even added a touch button.
    config is:
    - P24(PWM4) Btn-SmartLED_n 0
    - P26(PWM5) PWM 0
    Button works, Home assistant works, what bothers me a little is the smoothness of dimming (if you have any ideas, before it worked smooth) but the real problem is, I can't get the included remote to start working. Tried setting Irrecv on every possible pin, but no success. Can someone help me? :)
    Help appreciated, thanks,
    Luka
  • #2 20589251
    Help: 658
    Rate: 12780
    You can enable smooth led transitions in flags, this may improve the smoothness.
    Which protocol is IR Remote using? Do you have original 2MB dump from the device?
