[BK7231T] Is there a way to enable bluetooth or use it on the chip
whiskeysprinkler 4341 7
  • #1 20594740
    whiskeysprinkler
    I want to pair something to the Bluetooth on the BK7231 chip; a BLE sensor. Has anyone done this yet? What are the steps? Do you have to compile a custom version of the firmware and flash?
    If this is documented someplace, can someone provide a link to it? My searches are all ending up with "the 7231 is Bluetooth capable" and that's it.
  • #2 20595934
    Rate: 12972
    Hello, can you provide more information about the sensor you want to use with BK and about it's protocol/data format?
  • Request to use BK7231T as a BLE button trigger
    #3 20599540
    whiskeysprinkler
    Basically I want to connect a BLE device to it. Similar to how tasmota handles stuff like that. The idea is similar to the flic but not dealing with all the flic issues or api or whatnot.
    I want to be able to push a button on this BLE device and trigger an action. If that means that it really is an MQTT message to home assistant and home assistant executes based on that MQTT then that's good enough for now.
    The end goal is really to have a remote button that triggers an openbeken device to toggle a relay. So even if your smart home network goes down, the button still works. (aka no ZigBee)
    All these chipsets We take advantage of are capable of this. I just think it might be time to start using it
  • #4 20600593
    jitsirakowsk
    Rate: 10
    I would also be interested in this. There are countless directories in the original tuya sdk repo that deal with ble but it is not clear how these functions should be used. There are several functions claiming to be the 'entry point' to ble but what it means escapes me completely. At this point I would be happy to have the device show up on a BT scan.
  • BLE header suggests concurrent BLE and WiFi support
    #5 20600951
    Rate: 12972
    Do you need BLE to run at the same time as WiFi?
    Code: C / C++
    Header indicates that RF uses the same antenna for WiFi and BL and them seemingly can't be used at the same time.
  • Need RivieraWave docs to bring up BLE subsystem
    #6 20601131
    jitsirakowsk
    Rate: 10
    No, I would just like to use WB2L as a BT or BLE device. The ble.h header seems to list the functions to switch the radio to BLE but it is unclear to me how to bring the BLE subsystem up. There should be a way to supply the bdaddr, etc. somewhere, start advertizing...
    Thanks a lot for the reply and all the amazing work on Open_Beken.
    Andy
    Added after 2 [hours] 52 [minutes]:
    Maybe someone who has access to RivieraWave (now CEVA) documents RW-BLE-HOST-SW-FS.pdf and RW-BLE-HOST.pdf can figure it out but I cannot seem to find these anywhere.
  • Missing RT-Thread BLE porting layer
    #7 20603962
    jitsirakowsk
    Rate: 10
    I compiled a default template_demo app from the original Tuya repo (after supplying some empty functions) and removed all the WiFi init code from tuya_device.c. Judging by the diagnostic output I get, Tuya SDK inits the BLE system itself and I can even see 'appm start advertising' appearing in the output but the device still does not show up on any scans. I added ble_switch_rf_to_ble(); but still no cigar. What am I missing? I do not mind combing the assembly output to see what the SDK does after I get something working but right now nothing seems to be happening. Anybody got any ideas?
    Added after 3 [hours] 12 [minutes]:
    My apologies for spamming this thread again but something seems to be missing in the repos (both Tuya's as well as OpenBK). The ble.c file relies on RT-Thread functions like rt_timer_start etc. so it is not directly usable. I am not familiar with RT-Thread and how well it might mix with FreeRTOS code. There are no definitions (or even lib symbols) for these functions anywhere in the code tree so they must be ported to the OS used by the project. Does anyone have a solution or a way around this?
  • #8 20653706
    Rate: 12972
    It seems we have made substantial progress by @lsitkowski. Please see here:
    https://www.elektroda.com/rtvforum/topic3989434.html#20653571
    I will close this topic for now, let's continue in the topic linked above.
The discussion revolves around enabling Bluetooth functionality on the BK7231T chip, specifically for pairing with BLE devices. Users express interest in connecting a BLE sensor to trigger actions, similar to Tasmota's handling of devices. There are inquiries about the necessary steps, including whether a custom firmware compilation is required. Participants share their experiences with the Tuya SDK, noting challenges in utilizing BLE functions and the lack of clear documentation. Some have attempted to initialize BLE but faced issues with device visibility during scans. A link to a related forum thread is provided for further exploration of the topic.
