[Solved] Decoding Tuya Configuration in Aubess Mini Smart Switch with Onboard Chip - Flasher Issue
mminkov 1632 2
  • Flasher cannot decode Tuya configuration on onboard chip
    #1 20657271
    mminkov
    I see the theme https://www.elektroda.com/rtvforum/topic3912748.html, but it's locked, and I can't post.
    I have aubess mini smart switch with onboard chip, not with module (like this https://www.elektroda.com/rtvforum/topic3912748-30.html#20458111). When performing a backup, my flasher screen looks like the picture. The flasher can't decode tuya configuration Decoding Tuya Configuration in Aubess Mini Smart Switch with Onboard Chip - Flasher Issue
    I can send you my firmware, only for developers, not for all (can be sensitive data)
  • #2 20657279
    Rate: 12914
    Hello, if you want to send me the binary file, please do it via private message here or send it to email: openshwprojects(_at_)gmail.com
    Don't worry about closed topic, we usually prefer to open a new topic for a separate problem/issue. Thank you.
  • #3 21176198
    mminkov
    I try to clese topic
