Flashing the Aubess 16A Mini Smart Switch via Tuya Cloudcutter on Debian
cherry34 6054 4
  • Solderless Cloudcutter compatibility question
    #1 20993507
    cherry34
    Rate: 17
    Colleagues,
    I am trying to sflash the module as in the title by Tuya Cloudcutter. The method is nicely described here: https://digiblur.com/2023/08/19/updated-tuya-cloudcutter-with-esphome-bk7231-how-to-guide/ , except that in the link there is a tutorial on how to do it with the help of Rasp Pi, however I am using the Live CD with Debian. I have a device exactly like the one in https://www.elektroda.com/rtvforum/topic3912748.html , only that I strongly doubt I'll be able to solder anything to such micropads. Consequently, I've been pinning high hopes with the 'non-soldering' method, which I'm 'failing'. And here is the question - am I doing something wrong, or is my device not susceptible to the 'exploit' method?
    I am pasting the 'dialogue' from the console below. Is there any chance of success with the solderless method or should I buy a more powerful magnifying glass?
    P.S. The computer is connected via both cable and WiFi.
    user@debian:~/tuya-cloudcutter$ sudo ./tuya-cloudcutter.sh -r
    Building cloudcutter docker image
    [+] Building 1.7s (13/13) FINISHED                               docker:default
     => [internal] load build definition from Dockerfile                       0.0s
     => => transferring dockerfile: 462B                                       0.0s
     => [internal] load metadata for docker.io/library/python:3.9.18-slim-bul  1.7s
     => [internal] load .dockerignore                                          0.0s
     => => transferring context: 2B                                            0.0s
     => [base 1/2] FROM docker.io/library/python:3.9.18-slim-bullseye@sha256:  0.0s
     => [internal] load build context                                          0.0s
     => => transferring context: 3.02kB                                        0.0s
     => CACHED [base 2/2] RUN apt-get -qq update && apt-get install -qy --no-  0.0s
     => CACHED [python-deps 1/4] RUN pip install --upgrade pipenv              0.0s
     => CACHED [python-deps 2/4] COPY src/Pipfile /src/                        0.0s
     => CACHED [python-deps 3/4] COPY src/Pipfile.lock /src/                   0.0s
     => CACHED [python-deps 4/4] RUN cd /src && PIPENV_VENV_IN_PROJECT=1 pipe  0.0s
     => CACHED [cloudcutter 1/2] COPY src /src                                 0.0s
     => CACHED [cloudcutter 2/2] WORKDIR /src                                  0.0s
     => exporting to image                                                     0.0s
     => => exporting layers                                                    0.0s
     => => writing image sha256:a93d49921baac0d1ce1aa3ba53e496a59900e84c6374a  0.0s
     => => naming to docker.io/library/cloudcutter                             0.0s
    Successfully built docker image
    1) Detach from the cloud and run Tuya firmware locally
    2) Flash 3rd Party Firmware
    [?] Select your desired operation [1/2]: 1
    Detaching requires an SSID and Password, please enter each at the following prompt
    In order to provide secure logging, the values you type for your password will not show on screen
    If you make a mistake, you can run the detach process again
    You can also pass credentials via the -s command line option, see './tuya-cloudcutter.sh -h' for more information'
    Please enter your SSID: happinessoneseven
    Please enter your Password:
    Loading options, please wait...
    [?] How do you want to choose the device?: By manufacturer/device name
     > By manufacturer/device name
       By firmware version and name
       From device-profiles (i.e. custom profile)
    [?] Select the brand of your device: Aubess
       Antela
       Aoycocr
       Arlec
       Atarm
       Athom
       Atomi
     > Aubess
       Avatar
       Avatto
       BN-LINK
       BNETA IoT
       Baytion
       Beca
    [?] Select the article number of your device: 16A Mini Smart Switch
     > 16A Mini Smart Switch
       20A Plug
       IR Remote Controller
    [?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_[?] Select the firmware version and name: 1.2.1 - BK7231N / oem_bk7231n_control_switch.1 - BK7231N / oem_bk7231n_control_switch
     > 1.2.1 - BK7231N / oem_bk7231n_control_switch
    Performing safety checks to make sure all required ports are available
    Checking UDP port 53... Available.
    Checking UDP port 67... Available.
    Checking TCP port 80... Available.
    Checking TCP port 443... Available.
    Checking TCP port 1883... Available.
    Checking TCP port 8886... Available.
    Safety checks complete.
    Selected Device Slug: aubess-16a-mini-smart-switch
    Selected Profile: oem-bk7231n-control-switch-1.2.1-sdk-2.3.3-40.00
    Place your device in AP (slow blink) mode.  This can usually be accomplished by either:
    Power cycling off/on - 3 times and wait for the device to fast-blink, then repeat 3 more times.  Some devices need 4 or 5 times on each side of the pause
    Long press the power/reset button on the device until it starts fast-blinking, then releasing, and then holding the power/reset button again until the device starts slow-blinking.
    See https://support.tuya.com/en/help/_detail/K9hut3w10nby8 for more information.
    Wiping NetworkManager configs
    Scanning for open Tuya SmartLife AP
    Found access point name: "SmartLife-1EB9", trying to connect...
    Device 'wlp3s0' successfully activated with 'c5bd9f60-dee2-4ba5-a1d0-5a0cbd472575'.
    Connected to access point.
    Waiting 1 sec to allow device to set itself up...
    Running initial exploit toolchain...
    Exploit run, saved device config too!
    output=/work/configured-devices/XtztoThpHBUb.deviceconfig
    Saved device config in /work/configured-devices/XtztoThpHBUb.deviceconfig
    Power cycle and place your device in AP (slow blink) mode again.  This can usually be accomplished by either:
    Device 'wlp3s0' successfully activated with 'fd82cc79-6b70-4427-a01e-603800293cb1'.
    [!] The profile you selected did not result in a successful exploit.
  • #3 20993529
    cherry34
    Rate: 17
    And that's interesting. It was working from a mobile phone.
    I have corrected it.
  • Need exact AP mode reset sequence
    #4 21140217
    banid0
    I need help in this, I am desperate I have tried it all.
    I have the Aubess 16A smart plug.
    I have never paired it with any tuya app or another.
    I can get to the quick blinking mode.
    I CANNOT get the slow blinking mode.
    "Place your device in AP (slow blink) mode. This can usually be accomplished by either:
    See https://support.tuya.com/en/help/_detail/K9hut3w10nby8 for more information."
    I have tried click 10 times on the button.
    Power on and off 3, 5, and 10 times.
    Holding the button for 5 seconds, letting it go and hold for another (a lot) of seconds.
    Holding the button for (a lot) of seconds, without releasing.
    Nothing happens.
    How can I get to slow blinking/AP mode in this plug?
    I seem to have managed to do the hard part, the rpi 4 is ready with the script running...
    Please help!!!
    EDIT: I don't have the manual anymore, been googling it without success. Maybe there is mentioned on how to do it.
    @cherry34, how did you get to slow blinking mode?
    Thank you
  • #5 21170687
    hmonteiro
    >>21140217
    1 - Power up the switch and wait a couple of seconds.
    2 - Press the button for about 6 - 7 seconds. It should start blinking fast.
    3 - Wait a couple of seconds
    4 - Press the button again for another 6 - 7 seconds. It should start blinking slow and you should be able to see a SmartLife-XXX SSID.
    Cheers.
