Flashing Beca BHT-006 Thermostat: Unable to Locate GPIO Configuration
ruiguerra78 1797 3
  • #1 20674476
    ruiguerra78
    Flashed the Beca BHT-006 Thermostat but can't find the GPIO configuration.
  • #2 20674579
    Rate: 12973
    Have you tried getting Tuya partition?
    How device looks like inside?
  • ESPHome datapoint mapping for TuyaMCU thermostat
    #3 20675745
    ruiguerra78
    I did but had no luck,
    "baud":"9600",
    "ap_passwd":"null",
    "country_code":"null",
    "bt_mac":"null",
    "bt_hid":"null",
    "prod_test":"false",
    "fac_pin":"nmf4fnbste87drgc "
    Sorry, no meaningful pins data found. This device may be TuyaMCU or a custom one with no Tuya config data.
    Baud keyword found, this device may be TuyaMCU or BL0942. Baud value is 9600
    No module information found.
    And the Tuya section starts at UNCOMMON POSITION 0
    Now I flashed with ESPHome and I'm labeling all the tuya datapoints.
    I'll post the LibreTiny ESPHome yaml when I'm done, maybe it will help other users.
  • #4 20675801
    Rate: 12973
    Your config indicates it's a TuyaMCU device. OpenBeken supports TuyaMCU without any problems. I will close this topic since it looks like solved, but let me know if you have any other questions.
